    MMM-Flights
    47 Posts 7 Posters 24.0k Views 7 Watching
    • karsten13K Offline
      karsten13
      A new module showing flights in a defined area.
      I know there are at least 2 modules out using the same api, but this one additionally shows the planes on a map.
      Git Repo: https://gitlab.com/khassel/MMM-Flights
      For installation instructions and config options visit the above url.
      K 1 Reply Last reply Reply Quote 3
        MajorC Project Sponsor
        That’s so cool. I need more space on my screen for all the nice things out there.
          karsten13 @MajorC
          @majorc
          Thanks! I can confirm that space is a problem ;)
          • K Offline
            KI6UVE @karsten13
            @karsten13
            Is this still an active module? I cannot seem to get it working.
            karsten13K 1 Reply Last reply Reply Quote 1
              karsten13 @KI6UVE
              @KI6UVE
              yes, still works on my side. Need more infos to help.
              K 2 Replies Last reply Reply Quote 0
              • K Offline
                KI6UVE @karsten13
                  sdetweil @KI6UVE
                  @KI6UVE he was showing you WHERE it went… NOT the whole thing
                  a module defintion is { to }
                  inside the modules: [] list
                        module: "MMM-Flights",
                          laMin: 50.0,
                          laMax: 50.21,
                          loMin: 8.4,
                          loMax: 8.8,
                  • K Offline
                    KI6UVE @sdetweil
                      sdetweil @KI6UVE
                      @KI6UVE as I said, a (every) module entry starts with { and ends with }
                      read and practice the topics in my signature below, others wrote the posts, but they are super helpful for beginners
                      • K Offline
                        KI6UVE @sdetweil
                        S 2 Replies Last reply Reply Quote 1
                          sdetweil @KI6UVE
                          @KI6UVE which pi os are u running
                          Show output of
                          uname -a
                          lsb_release -a
                          • K Offline
                            KI6UVE @sdetweil
                              sdetweil @KI6UVE
                              @KI6UVE said in MMM-Flights:
                              MESA-LOADER: failed to open kms_swrast: /user/lib/dri/kms_swrast_dri.so: cannot open shared object file
                              this seems to be related to the new default user setup on pi…
                              another user said this worked
                              sudo usermod -a -G render pi
                              (add user pi to the render group)
                              • K Offline
                                KI6UVE @sdetweil
                                • K Offline
                                  KI6UVE @sdetweil
                                    sdetweil @KI6UVE
                                    @KI6UVE turn off using the gpu
                                    set environment variable
                                    export ELECTRON_DISABLE_GPU=1
                                    in the script used to launch mm…
                                    if using my install script and pm2,.
                                    that file is MagicMirror/installers/mm.sh
                                    • K Offline
                                      KI6UVE @sdetweil
                                        sdetweil @KI6UVE
                                        @KI6UVE no, just restart mm
                                        • K Offline
                                          KI6UVE @karsten13
                                          @karsten13
                                          Is there a way to configure the flight data output to make the units Imperial instead of metric?
                                            karsten13 @KI6UVE
                                            @KI6UVE
                                            no, but should not be a big thing to implement this.
                                            I see the m for the height and km/h for speed, so what are the correct imperial units?
                                            ft for m?
                                            mph for km/h?
