    Need help using an API
    Scheduled Pinned Locked Moved Feature Requests
    6 Posts 3 Posters 4.9k Views 3 Watching
    • bheplerB Offline
      bhepler Module Developer
      You should be able to use the default Calendar module that comes with the stock Magic Mirror installation. So long as you can get your calendar available to you as an ICS feed, you should be good to go. Flipping through the Amion website, I did find a reference to ICS format, so I know they’re capable of producing it.
      It seems like you should be able to tie in with little trouble.
      On the off chance you missed it, here is the link to the Calendar module documentation.
      • T Offline
        Thornwalker
        Awesome! I hopefully I will get my pi up and running tomorrow night and I can try it out.
        Thanks. I will report back if it indeed works!
        • T Offline
          Thornwalker
          the amazon shipment got here late tonight. Gonna get raspbian up and running and go from there. Will update in a day or two. Thanks!
            jc21
            A quick look on that website and I found an API they provide. When you get more advanced you can hook into that.
            • T Offline
              Thornwalker
              Just FYI for anyone who tries this later. It worked flawlessly! I had to mess around with exactly what info I needed to pull. But now my mirror shows when i’m on call.
              Thanks for the help!
