    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 855.8k Views 59 Watching
      sdetweil @swvalenti
      @swvalenti the module is missing ‘request’
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS Offline
        swvalenti Project Sponsor @sdetweil
        @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
        npm install request in the MM folder?
          sdetweil @swvalenti
          @swvalenti no,. read the 1st post of the link I posted for black screen
            ok we are getting somewhere pga now works, openweather forecast still doesn’t work no error in console
              sdetweil @swvalenti
              @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
              sorry, no idea there
                sam whatever you told me to not which step I got it all working. Only issue now is two modules are not centered correctly even when using top_center…how or if you can use css for that?
                  sdetweil @swvalenti
                  maybe… depends on the module
                  see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1647717794860
                    @sdetweil any ideas on this one just showed up…It asked me that npm needed major update now it doesn’t work
                    C:\Users\Svale\MagicMirror>npm start
                    > magicmirror@2.18.0 start
                    > ./node_modules/.bin/electron js/electron.js
                    '.' is not recognized as an internal or external command,
                    operable program or batch file.
                      sdetweil @swvalenti
                      ./node_modules
                      yes, you cannot have the ./ in front… windows doesn’t understand that …
                      read the instructions again
                        sdetweil @swvalenti
                        @swvalenti you shouldn’t update things unless u know why you are doing it…
                        we test with certain runtimes and release every 3 months
                          ./node_modules
                          now I get this error…will never update again lesson learned
                          > magicmirror@2.18.0 start C:\Users\Svale\MagicMirror
                          'electron' is not recognized as an internal or external command,
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno 1
                          npm ERR! magicmirror@2.18.0 start: `electron js/electron.js`
                          npm ERR! Exit status 1
                          npm ERR!
                          npm ERR! Failed at the magicmirror@2.18.0 start script.
                          npm ERR!     C:\Users\Svale\AppData\Roaming\npm-cache\_logs\2022-03-21T21_48_27_176Z-debug.log
                            sdetweil @swvalenti
                            @swvalenti come on
                            remove the display and the leading
                            "start":"node_modules/.bin/electron js/electron.js",
                              “start”:“node_modules/.bin/electron js/electron.js”,
                              I did that sam still doesn’t work sorry to be a bother
                                sdetweil @swvalenti
                                @swvalenti and what is the message?
                                what npm version are u running?
                                npm -v
                                  npm -v
                                  this is what i get and below is version
                                  > electron js\electron.js
                                  npm ERR! errno 1
                                  npm ERR! magicmirror@2.18.0 start: `electron js\electron.js`
                                  npm ERR!
                                  npm ERR!     C:\Users\Svale\AppData\Roaming\npm-cache\_logs\2022-03-21T22_10_23_329Z-debug.log
                                  C:\Users\Svale\MagicMirror>npm -v
                                  6.14.0
                                    sdetweil @swvalenti
                                    u still have it wrong
                                    “node_modules/.bin/electron electron.js”
                                    electron is not in the path, so you have to give it the path to the executable
                                    once again different versions of node and npm require slightly different solutions…
                                    this is not an MM problem… they keep messing it up (in my opinion)
                                    https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
                                      @sdetweil oh well I give up I tried all the steps, thanks for all the help and patience
                                          @sdetweil the only thing that isn’t working now is when I run npm init-y in each module folder the module in the dev window is still asking for replace instead of request
                                          S 2 Replies Last reply Reply Quote -1
                                            sdetweil @swvalenti
                                            @swvalenti you don’t run npm init unless u need to. only if u need to install a library that mm doesn’t reference anymore
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
