    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.4k Views 59 Watching
      sdetweil @swvalenti
      @swvalenti come on
      remove the display and the leading
      "start":"node_modules/.bin/electron js/electron.js",
      swvalentiS 1 Reply Last reply
      • swvalentiS
        swvalenti Project Sponsor @sdetweil
        @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
        “start”:“node_modules/.bin/electron js/electron.js”,
        I did that sam still doesn’t work sorry to be a bother
          sdetweil @swvalenti
          @swvalenti and what is the message?
          what npm version are u running?
          npm -v
          • swvalentiS
            npm -v
            this is what i get and below is version
            C:\Users\Svale\MagicMirror>npm start
            > magicmirror@2.18.0 start C:\Users\Svale\MagicMirror
            > electron js\electron.js
            'electron' is not recognized as an internal or external command,
            operable program or batch file.
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! magicmirror@2.18.0 start: `electron js\electron.js`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the magicmirror@2.18.0 start script.
            npm ERR!     C:\Users\Svale\AppData\Roaming\npm-cache\_logs\2022-03-21T22_10_23_329Z-debug.log
            C:\Users\Svale\MagicMirror>npm -v
            6.14.0
              sdetweil @swvalenti
              @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
              u still have it wrong
              “node_modules/.bin/electron electron.js”
              electron is not in the path, so you have to give it the path to the executable
              once again different versions of node and npm require slightly different solutions…
              this is not an MM problem… they keep messing it up (in my opinion)
              https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
              • swvalentiS
                @sdetweil oh well I give up I tried all the steps, thanks for all the help and patience
                • swvalentiS
                  • swvalentiS
                    @sdetweil the only thing that isn’t working now is when I run npm init-y in each module folder the module in the dev window is still asking for replace instead of request
                    S 2 Replies Last reply
                    Reply Quote -1
                      sdetweil @swvalenti
                      @swvalenti you don’t run npm init unless u need to. only if u need to install a library that mm doesn’t reference anymore
                        sdetweil @swvalenti
                        what?
                        words not clear
                        • swvalentiS
                          what?
                          words not clear
                          Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                              at cmpVersions (module.js:525)
                              at Function.Module.register (module.js:502)
                              at MMM-OpenWeatherForecast.js:41
                          I did what you said but still get this error for some reason
                            sdetweil @swvalenti
                            @swvalenti ok, sometimes this is because of a typo in the config position for the module
                              DanClarkCBET3
                                DanClarkCBET3
                                  sdetweil @DanClarkCBET3
                                  @DanClarkCBET3 see
                                    DanClarkCBET3
                                    Is there a way to make a desktop shortcut to start MagicMirror?
                                      @DanClarkCBET3 sure. create a batch file
                                      mm.cmd
                                      in the installers folder, and then use that for the shortcut
                                      mm.cmd should do
                                      @npm start
                                        CheapDad
                                        My apologies if the answer to my question is located somewhere in this long thread. As a quick method of bringing some MM functionality to my kids in college, I’d like to install MM onto their laptops and have it autorun at start (like a batch file) and run in a small window.
                                        I see that I can install it on their laptops and I know how to create a batch file, but what I don’t know is how to ensure that a linux program starts in a windows batch file and how to get it to autosize to a small window.
                                        Has anyone done that?
                                          sdetweil @CheapDad
                                          @CheapDad use PM2 to auto launch
                                          this is a node application
                                          mumblebajM 1 Reply Last reply
                                          • mumblebajM
                                            @sdetweil Don’t think it is an easy straight forward setup for PM2 on Windows to launch the mirror or am I mistaken? Would he have to setup pm2-windows-service and then perform some other setups to get PM2 to work to launch MM on Windows at startup?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
