    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 886.4k Views 59 Watching
    • swvalentiS
      swvalenti Project Sponsor
      @sdetweil the only thing that isn’t working now is when I run npm init-y in each module folder the module in the dev window is still asking for replace instead of request
      S 2 Replies Last reply
      Reply Quote -1
        sdetweil @swvalenti
        @swvalenti you don’t run npm init unless u need to. only if u need to install a library that mm doesn’t reference anymore
          sdetweil @swvalenti
          @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
          what?
          words not clear
          swvalentiS 1 Reply Last reply
          • swvalentiS
            swvalenti Project Sponsor @sdetweil
            @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
            what?
            words not clear
            Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                at cmpVersions (module.js:525)
                at Function.Module.register (module.js:502)
                at MMM-OpenWeatherForecast.js:41
            I did what you said but still get this error for some reason
              sdetweil @swvalenti
              @swvalenti ok, sometimes this is because of a typo in the config position for the module
                DanClarkCBET3
                  DanClarkCBET3
                    sdetweil @DanClarkCBET3
                    @DanClarkCBET3 see
                      DanClarkCBET3
                      Is there a way to make a desktop shortcut to start MagicMirror?
                        @DanClarkCBET3 sure. create a batch file
                        mm.cmd
                        in the installers folder, and then use that for the shortcut
                        mm.cmd should do
                        @npm start
                          CheapDad
                          My apologies if the answer to my question is located somewhere in this long thread. As a quick method of bringing some MM functionality to my kids in college, I’d like to install MM onto their laptops and have it autorun at start (like a batch file) and run in a small window.
                          I see that I can install it on their laptops and I know how to create a batch file, but what I don’t know is how to ensure that a linux program starts in a windows batch file and how to get it to autosize to a small window.
                          Has anyone done that?
                            sdetweil @CheapDad
                            @CheapDad use PM2 to auto launch
                            this is a node application
                            mumblebajM 1 Reply Last reply
                            • mumblebajM
                              @sdetweil Don’t think it is an easy straight forward setup for PM2 on Windows to launch the mirror or am I mistaken? Would he have to setup pm2-windows-service and then perform some other setups to get PM2 to work to launch MM on Windows at startup?
                                sdetweil @mumblebaj
                                @mumblebaj pm2 setup does all that …
                                • mumblebajM
                                  @sdetweil :thumbs_up:
                                    sdetweil @mumblebaj
                                    @mumblebaj I was wrong for windows, and setup
                                    see here
                                    https://stackoverflow.com/questions/42758985/windows-auto-start-pm2-and-node-apps
                                    still pm2 is the easiest and same on every platform…
                                    • mumblebajM
                                      @CheapDad Here is a great tutorial to set up PM2 on Windows.
                                      https://blog.cloudboost.io/nodejs-pm2-startup-on-windows-db0906328d75
                                      • C CheapDad referenced this topic on
                                        Bobrae
                                        When following your instructions on both Windows 7 and 10 machines, I get the following error message:
                                        magicmirror@2.20.0 start C:\Users\Admin\MagicMirror
                                        ‘DISPLAY’ is not recognized as an internal or external command,
                                        operable program or batch file.
                                        The error log gives the following:
                                        1 verbose cli [
                                        1 verbose cli ‘C:\Program Files\nodejs\node.exe’,
                                        1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
                                        1 verbose cli ‘start’
                                        1 verbose cli ]
                                        2 info using npm@6.14.4
                                        3 info using node@v13.14.0
                                        4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                                        5 info lifecycle magicmirror@2.20.0~prestart: magicmirror@2.20.0
                                        6 info lifecycle magicmirror@2.20.0~start: magicmirror@2.20.0
                                        7 verbose lifecycle magicmirror@2.20.0~start: unsafe-perm in lifecycle true
                                        8 verbose lifecycle magicmirror@2.20.0~start: PATH: C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;C:\Users\Admin\MagicMirror\node_modules.bin;C:\Users\Admin\bin;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\local\bin;C:\Program Files\Git\usr\bin;C:\Program Files\Git\usr\bin;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\bin;C:\Users\Admin\bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files\Intel\Intel® Management Engine Components\DAL;C:\Program Files\Intel\Intel® Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel® Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel® Management Engine Components\IPT;C:\php;C:\Program Files\Calibre2;C:\Program Files\nodejs;C:\Program Files\Git\cmd;C:\Users\Admin\AppData\Roaming\npm;C:\Program Files\Git\usr\bin\vendor_perl;C:\Program Files\Git\usr\bin\core_perl
                                        9 verbose lifecycle magicmirror@2.20.0~start: CWD: C:\Users\Admin\MagicMirror
                                        10 silly lifecycle magicmirror@2.20.0~start: Args: [
                                        10 silly lifecycle ‘/d /s /c’,
                                        10 silly lifecycle ‘DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js’
                                        10 silly lifecycle ]
                                        11 silly lifecycle magicmirror@2.20.0~start: Returned: code: 1 signal: null
                                        12 info lifecycle magicmirror@2.20.0~start: Failed to exec start script
                                        13 verbose stack Error: magicmirror@2.20.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                        13 verbose stack Exit status 1
                                        13 verbose stack at EventEmitter. (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\index.js:332:16)
                                        13 verbose stack at EventEmitter.emit (events.js:315:20)
                                        13 verbose stack at ChildProcess. (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\lib\spawn.js:55:14)
                                        13 verbose stack at ChildProcess.emit (events.js:315:20)
                                        13 verbose stack at maybeClose (internal/child_process.js:1026:16)
                                        13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                                        14 verbose pkgid magicmirror@2.20.0
                                        15 verbose cwd C:\Users\Admin\MagicMirror
                                        16 verbose Windows_NT 6.1.7601
                                        17 verbose argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
                                        18 verbose node v13.14.0
                                        19 verbose npm v6.14.4
                                        20 error code ELIFECYCLE
                                        21 error errno 1
                                        22 error magicmirror@2.20.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                        22 error Exit status 1
                                        23 error Failed at the magicmirror@2.20.0 start script.
                                        23 error This is probably not a problem with npm. There is likely additional logging output above.
                                        24 verbose exit [ 1, true ]
                                          sdetweil @Bobrae
                                          @Bobrae see
                                          https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1659891805957
                                          • Cliff365C
                                            Cliff365 @Mykle1
                                            @Mykle1 First off, thanks so much for a great guide. I’m having what is likely a simple issue, but I can’t figure out how to resolve it. I am getting the following error message with the npm start command. Not concerned about the warnings, but how do resolve the DISPLAY issue?
                                            $ npm start
                                            npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
                                            'DISPLAY' is not recognized as an internal or external command,
                                            cliff@BNC-LAB01 MINGW64 ~/MagicMirror (master)
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
