    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 874.0k Views 59 Watching
      sdetweil @swvalenti
      @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
      is still asking for replace instead of request
      what?
      words not clear
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS
        swvalenti Project Sponsor @sdetweil
        @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
        what?
        words not clear
        Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
            at cmpVersions (module.js:525)
            at Function.Module.register (module.js:502)
            at MMM-OpenWeatherForecast.js:41
        I did what you said but still get this error for some reason
          sdetweil @swvalenti
          @swvalenti ok, sometimes this is because of a typo in the config position for the module
            DanClarkCBET3
              DanClarkCBET3
                sdetweil @DanClarkCBET3
                @DanClarkCBET3 see
                  DanClarkCBET3
                  Is there a way to make a desktop shortcut to start MagicMirror?
                    @DanClarkCBET3 sure. create a batch file
                    mm.cmd
                    in the installers folder, and then use that for the shortcut
                    mm.cmd should do
                    @npm start
                      CheapDad
                      My apologies if the answer to my question is located somewhere in this long thread. As a quick method of bringing some MM functionality to my kids in college, I’d like to install MM onto their laptops and have it autorun at start (like a batch file) and run in a small window.
                      I see that I can install it on their laptops and I know how to create a batch file, but what I don’t know is how to ensure that a linux program starts in a windows batch file and how to get it to autosize to a small window.
                      Has anyone done that?
                        sdetweil @CheapDad
                        @CheapDad use PM2 to auto launch
                        this is a node application
                        • mumblebajM
                          @sdetweil Don’t think it is an easy straight forward setup for PM2 on Windows to launch the mirror or am I mistaken? Would he have to setup pm2-windows-service and then perform some other setups to get PM2 to work to launch MM on Windows at startup?
                            sdetweil @mumblebaj
                            @mumblebaj pm2 setup does all that …
                            • mumblebajM
                              @sdetweil :thumbs_up:
                                sdetweil @mumblebaj
                                @mumblebaj I was wrong for windows, and setup
                                see here
                                https://stackoverflow.com/questions/42758985/windows-auto-start-pm2-and-node-apps
                                still pm2 is the easiest and same on every platform…
                                • mumblebajM
                                  @CheapDad Here is a great tutorial to set up PM2 on Windows.
                                  https://blog.cloudboost.io/nodejs-pm2-startup-on-windows-db0906328d75
                                  • C CheapDad referenced this topic on
                                    Bobrae
                                    When following your instructions on both Windows 7 and 10 machines, I get the following error message:
                                    magicmirror@2.20.0 start C:\Users\Admin\MagicMirror
                                    ‘DISPLAY’ is not recognized as an internal or external command,
                                    operable program or batch file.
                                    The error log gives the following:
                                    1 verbose cli [
                                    1 verbose cli ‘C:\Program Files\nodejs\node.exe’,
                                    1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
                                    1 verbose cli ‘start’
                                    1 verbose cli ]
                                    2 info using npm@6.14.4
                                    3 info using node@v13.14.0
                                    4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                                    5 info lifecycle magicmirror@2.20.0~prestart: magicmirror@2.20.0
                                    6 info lifecycle magicmirror@2.20.0~start: magicmirror@2.20.0
                                    7 verbose lifecycle magicmirror@2.20.0~start: unsafe-perm in lifecycle true
                                    8 verbose lifecycle magicmirror@2.20.0~start: PATH: C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;C:\Users\Admin\MagicMirror\node_modules.bin;C:\Users\Admin\bin;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\local\bin;C:\Program Files\Git\usr\bin;C:\Program Files\Git\usr\bin;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\bin;C:\Users\Admin\bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files\Intel\Intel® Management Engine Components\DAL;C:\Program Files\Intel\Intel® Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel® Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel® Management Engine Components\IPT;C:\php;C:\Program Files\Calibre2;C:\Program Files\nodejs;C:\Program Files\Git\cmd;C:\Users\Admin\AppData\Roaming\npm;C:\Program Files\Git\usr\bin\vendor_perl;C:\Program Files\Git\usr\bin\core_perl
                                    9 verbose lifecycle magicmirror@2.20.0~start: CWD: C:\Users\Admin\MagicMirror
                                    10 silly lifecycle magicmirror@2.20.0~start: Args: [
                                    10 silly lifecycle ‘/d /s /c’,
                                    10 silly lifecycle ‘DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js’
                                    10 silly lifecycle ]
                                    11 silly lifecycle magicmirror@2.20.0~start: Returned: code: 1 signal: null
                                    12 info lifecycle magicmirror@2.20.0~start: Failed to exec start script
                                    13 verbose stack Error: magicmirror@2.20.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                    13 verbose stack Exit status 1
                                    13 verbose stack at EventEmitter. (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\index.js:332:16)
                                    13 verbose stack at EventEmitter.emit (events.js:315:20)
                                    13 verbose stack at ChildProcess. (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\lib\spawn.js:55:14)
                                    13 verbose stack at ChildProcess.emit (events.js:315:20)
                                    13 verbose stack at maybeClose (internal/child_process.js:1026:16)
                                    13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                                    14 verbose pkgid magicmirror@2.20.0
                                    15 verbose cwd C:\Users\Admin\MagicMirror
                                    16 verbose Windows_NT 6.1.7601
                                    17 verbose argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
                                    18 verbose node v13.14.0
                                    19 verbose npm v6.14.4
                                    20 error code ELIFECYCLE
                                    21 error errno 1
                                    22 error magicmirror@2.20.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                    22 error Exit status 1
                                    23 error Failed at the magicmirror@2.20.0 start script.
                                    23 error This is probably not a problem with npm. There is likely additional logging output above.
                                    24 verbose exit [ 1, true ]
                                      sdetweil @Bobrae
                                      @Bobrae see
                                      https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1659891805957
                                      • Cliff365C
                                        Cliff365 @Mykle1
                                        @Mykle1 First off, thanks so much for a great guide. I’m having what is likely a simple issue, but I can’t figure out how to resolve it. I am getting the following error message with the npm start command. Not concerned about the warnings, but how do resolve the DISPLAY issue?
                                        $ npm start
                                        npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
                                        'DISPLAY' is not recognized as an internal or external command,
                                        cliff@BNC-LAB01 MINGW64 ~/MagicMirror (master)
                                          sdetweil @Cliff365
                                          @Cliff365 see the end of the post I just linked to in the prior post
                                          also, do not run under mingw… just cmd.exe
                                          • Cliff365C
                                            Cliff365 @Mykle1
                                            @Mykle1 Thanks for your help on the DISPLAY issue. I changed the line in packages.json file to:
                                            “start”: “node_modules/.bin/electron js/electron.js”,
                                            I get the following error message back:
                                            'node_modules' is not recognized as an internal or external command,
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
