    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 876.5k Views 59 Watching
    • mumblebajM
      @CheapDad Here is a great tutorial to set up PM2 on Windows.
      https://blog.cloudboost.io/nodejs-pm2-startup-on-windows-db0906328d75
      • C CheapDad referenced this topic on
        Bobrae
        When following your instructions on both Windows 7 and 10 machines, I get the following error message:
        magicmirror@2.20.0 start C:\Users\Admin\MagicMirror
        ‘DISPLAY’ is not recognized as an internal or external command,
        operable program or batch file.
        The error log gives the following:
        1 verbose cli [
        1 verbose cli ‘C:\Program Files\nodejs\node.exe’,
        1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
        1 verbose cli ‘start’
        1 verbose cli ]
        2 info using npm@6.14.4
        3 info using node@v13.14.0
        4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
        5 info lifecycle magicmirror@2.20.0~prestart: magicmirror@2.20.0
        6 info lifecycle magicmirror@2.20.0~start: magicmirror@2.20.0
        7 verbose lifecycle magicmirror@2.20.0~start: unsafe-perm in lifecycle true
        8 verbose lifecycle magicmirror@2.20.0~start: PATH: C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;C:\Users\Admin\MagicMirror\node_modules.bin;C:\Users\Admin\bin;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\local\bin;C:\Program Files\Git\usr\bin;C:\Program Files\Git\usr\bin;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\bin;C:\Users\Admin\bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files\Intel\Intel® Management Engine Components\DAL;C:\Program Files\Intel\Intel® Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel® Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel® Management Engine Components\IPT;C:\php;C:\Program Files\Calibre2;C:\Program Files\nodejs;C:\Program Files\Git\cmd;C:\Users\Admin\AppData\Roaming\npm;C:\Program Files\Git\usr\bin\vendor_perl;C:\Program Files\Git\usr\bin\core_perl
        9 verbose lifecycle magicmirror@2.20.0~start: CWD: C:\Users\Admin\MagicMirror
        10 silly lifecycle magicmirror@2.20.0~start: Args: [
        10 silly lifecycle ‘/d /s /c’,
        10 silly lifecycle ‘DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js’
        10 silly lifecycle ]
        11 silly lifecycle magicmirror@2.20.0~start: Returned: code: 1 signal: null
        12 info lifecycle magicmirror@2.20.0~start: Failed to exec start script
        13 verbose stack Error: magicmirror@2.20.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        13 verbose stack Exit status 1
        13 verbose stack at EventEmitter. (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\index.js:332:16)
        13 verbose stack at EventEmitter.emit (events.js:315:20)
        13 verbose stack at ChildProcess. (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\lib\spawn.js:55:14)
        13 verbose stack at ChildProcess.emit (events.js:315:20)
        13 verbose stack at maybeClose (internal/child_process.js:1026:16)
        13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
        14 verbose pkgid magicmirror@2.20.0
        15 verbose cwd C:\Users\Admin\MagicMirror
        16 verbose Windows_NT 6.1.7601
        17 verbose argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
        18 verbose node v13.14.0
        19 verbose npm v6.14.4
        20 error code ELIFECYCLE
        21 error errno 1
        22 error magicmirror@2.20.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
        22 error Exit status 1
        23 error Failed at the magicmirror@2.20.0 start script.
        23 error This is probably not a problem with npm. There is likely additional logging output above.
        24 verbose exit [ 1, true ]
          sdetweil @Bobrae
          @Bobrae see
          https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1659891805957
          • Cliff365C
            Cliff365 @Mykle1
            @Mykle1 First off, thanks so much for a great guide. I’m having what is likely a simple issue, but I can’t figure out how to resolve it. I am getting the following error message with the npm start command. Not concerned about the warnings, but how do resolve the DISPLAY issue?
            $ npm start
            npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
            'DISPLAY' is not recognized as an internal or external command,
            cliff@BNC-LAB01 MINGW64 ~/MagicMirror (master)
              sdetweil @Cliff365
              @Cliff365 see the end of the post I just linked to in the prior post
              also, do not run under mingw… just cmd.exe
              • Cliff365C
                Cliff365 @Mykle1
                @Mykle1 Thanks for your help on the DISPLAY issue. I changed the line in packages.json file to:
                “start”: “node_modules/.bin/electron js/electron.js”,
                I get the following error message back:
                'node_modules' is not recognized as an internal or external command,
                  sdetweil @Cliff365
                  @Cliff365 you didn’t follow all of the last line of
                  https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1660158299123
                  ps, I’m not @Mykle1
                  Cliff365C D 2 Replies Last reply
                  • Cliff365C
                    Cliff365 @sdetweil
                    @sdetweil Oops! Thanks sdetweil
                      dude31222 @sdetweil
                      Hey! @sdetweil i’ve spend more than 10 hours whit this because i didn’t read the entire thread. I’ve finally installed mm2 on a 32bit laptop whit w7 and node v16.6 but when i run npm start i just got a black screen. any ideas on how to find a solution? my cmd here:
                      [08.01.2023 06:58.14.001] [LOG]   Starting MagicMirror: v2.22.0
                      [08.01.2023 06:58.14.151] [LOG]   Loading config ...
                      [08.01.2023 06:58.14.201] [LOG]   Loading module helpers ...
                      [08.01.2023 06:58.14.231] [LOG]   No helper found for module: alert.
                      [08.01.2023 06:58.14.361] [LOG]   Initializing new module helper ...
                      [08.01.2023 06:58.14.371] [LOG]   Module helper loaded: updatenotification
                      [08.01.2023 06:58.14.395] [LOG]   No helper found for module: clock.
                      [08.01.2023 06:58.17.473] [LOG]   Initializing new module helper ...
                      [08.01.2023 06:58.17.477] [LOG]   Module helper loaded: calendar
                      [08.01.2023 06:58.17.497] [LOG]   No helper found for module: compliments.
                      [08.01.2023 06:58.17.497] [LOG]   No helper found for module: weather.
                      [08.01.2023 06:58.17.839] [LOG]   Initializing new module helper ...
                      [08.01.2023 06:58.17.839] [LOG]   Module helper loaded: newsfeed
                      [08.01.2023 06:58.17.849] [LOG]   No helper found for module: facts.
                      [08.01.2023 06:58.17.849] [LOG]   All module helpers loaded.
                      [08.01.2023 06:58.19.559] [LOG]   Starting server on port 8080 ...
                      [08.01.2023 06:58.23.451] [LOG]   Launching application.
                      [08.01.2023 06:58.29.838] [LOG]   Server started ...
                      [08.01.2023 06:58.29.848] [LOG]   Connecting socket for: updatenotification
                      [08.01.2023 06:58.29.848] [LOG]   Starting module helper: updatenotification
                      [08.01.2023 06:58.29.848] [LOG]   Connecting socket for: calendar
                      [08.01.2023 06:58.29.848] [LOG]   Starting node helper for: calendar
                      [08.01.2023 06:58.29.858] [LOG]   Connecting socket for: newsfeed
                      [08.01.2023 06:58.29.858] [LOG]   Starting node helper for: newsfeed
                      [08.01.2023 06:58.29.858] [LOG]   Sockets connected & modules started ...
                      [3460:0108/070022.937:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL i
                      s disabled, ANGLE is
                        sdetweil @dude31222
                        @dude31222 never tried win7 myself… this topic was created a while ago…
                        you can TRY setting an environment variable in the cmd.exe window before executing npm start
                        cd MagicMirror
                        set ELECTRON_DISABLE_GPU=1
                        npm start
                        D 1 Reply Last reply
                          dude31222 @sdetweil
                          @sdetweil still having an empty screen but no more error messages in cmd
                            sdetweil @dude31222
                            @dude31222 that usually means u didn’t do the fonts install step or vendor install step
                            those are extra for windows install
                              dude31222 @sdetweil
                              @sdetweil i did. Now i’ve upgraded to windows 8.1. still a black screen but a new error```
                              [0110/062053.181:ERROR:_trace_logging_minimal.win.cc<78>] provider resistration failure
                                sdetweil @dude31222
                                @dude31222 I don’t know. those are so far out of service…
                                  Reila
                                  Heyo!
                                  I’ve done a fresh install of MM2 (on Win10), and now I’m struggling with the blank electron screen.
                                  I did the vendor and font install, changed the package.json to
                                  "start":"node_modules/.bin/electron js/electron.js",
                                  according to the guide on page 15, and now I’m getting
                                  bash: line 1: node_modules.binelectron: command not found
                                  on npm start, doesn’t start up MM.
                                    sdetweil @Reila
                                    @Reila you did not do the package.json edit correctly.
                                    windows uses slashes leaning left
                                    and u need 2 in each place
                                    node-modules\\.bin\\electron  js\\electron.js
                                    R 1 Reply Last reply
                                      Reila @sdetweil
                                      Oh, I just copied as it was! It might have been a different guide, it was old after all… I see the backward slashes in a later post now.
                                      So now I tried
                                      "start": "node_modules\\.bin\\electron  js\\electron.js",
                                      (with both the double and single space, just in case) and it’s giving me the same error still.
                                      I tested changing the start-dev variant too.
                                      I must be missing another step still.
                                        sdetweil @Reila
                                        @Reila I am away from my system at the moment be back in an hour or so.
                                        what does npm -v say?
                                          Reila @sdetweil
                                          @sdetweil No problem! Browser version works fine for tinkering in the meantime :)
                                          npm is 8.17.0
                                            sdetweil @Reila
                                            @Reila hm… this is what mine is set to
                                            and I don’t get any errors, but electron starts full screen, black screen
                                            but if I open edge and go to localhost:8080 it looks great and if I open electron
                                            (the 1st part, node_modules\.bin\electron) and go to http://localhost:8080
                                            it works…
                                            • R Roadrunner451 referenced this topic on
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
