    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 855.8k Views 59 Watching
      sdetweil @Bobrae
      @Bobrae see
      https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1659891805957
      • Cliff365C Offline
        Cliff365 @Mykle1
        @Mykle1 First off, thanks so much for a great guide. I’m having what is likely a simple issue, but I can’t figure out how to resolve it. I am getting the following error message with the npm start command. Not concerned about the warnings, but how do resolve the DISPLAY issue?
        $ npm start
        npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
        > magicmirror@2.20.0 start
        'DISPLAY' is not recognized as an internal or external command,
        operable program or batch file.
        cliff@BNC-LAB01 MINGW64 ~/MagicMirror (master)
          sdetweil @Cliff365
          @Cliff365 see the end of the post I just linked to in the prior post
          also, do not run under mingw… just cmd.exe
          • Cliff365C Offline
            Cliff365 @Mykle1
            @Mykle1 Thanks for your help on the DISPLAY issue. I changed the line in packages.json file to:
            “start”: “node_modules/.bin/electron js/electron.js”,
            I get the following error message back:
            'node_modules' is not recognized as an internal or external command,
              sdetweil @Cliff365
              @Cliff365 you didn’t follow all of the last line of
              https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1660158299123
              ps, I’m not @Mykle1
              Cliff365C D 2 Replies Last reply Reply Quote 0
              • Cliff365C Offline
                Cliff365 @sdetweil
                @sdetweil Oops! Thanks sdetweil
                  dude31222 @sdetweil
                  Hey! @sdetweil i’ve spend more than 10 hours whit this because i didn’t read the entire thread. I’ve finally installed mm2 on a 32bit laptop whit w7 and node v16.6 but when i run npm start i just got a black screen. any ideas on how to find a solution? my cmd here:
                  [08.01.2023 06:58.14.001] [LOG]   Starting MagicMirror: v2.22.0
                  [08.01.2023 06:58.14.151] [LOG]   Loading config ...
                  [08.01.2023 06:58.14.201] [LOG]   Loading module helpers ...
                  [08.01.2023 06:58.14.231] [LOG]   No helper found for module: alert.
                  [08.01.2023 06:58.14.361] [LOG]   Initializing new module helper ...
                  [08.01.2023 06:58.14.371] [LOG]   Module helper loaded: updatenotification
                  [08.01.2023 06:58.14.395] [LOG]   No helper found for module: clock.
                  [08.01.2023 06:58.17.473] [LOG]   Initializing new module helper ...
                  [08.01.2023 06:58.17.477] [LOG]   Module helper loaded: calendar
                  [08.01.2023 06:58.17.497] [LOG]   No helper found for module: compliments.
                  [08.01.2023 06:58.17.497] [LOG]   No helper found for module: weather.
                  [08.01.2023 06:58.17.839] [LOG]   Initializing new module helper ...
                  [08.01.2023 06:58.17.839] [LOG]   Module helper loaded: newsfeed
                  [08.01.2023 06:58.17.849] [LOG]   No helper found for module: facts.
                  [08.01.2023 06:58.17.849] [LOG]   All module helpers loaded.
                  [08.01.2023 06:58.19.559] [LOG]   Starting server on port 8080 ...
                  [08.01.2023 06:58.23.451] [LOG]   Launching application.
                  [08.01.2023 06:58.29.838] [LOG]   Server started ...
                  [08.01.2023 06:58.29.848] [LOG]   Connecting socket for: updatenotification
                  [08.01.2023 06:58.29.848] [LOG]   Starting module helper: updatenotification
                  [08.01.2023 06:58.29.848] [LOG]   Connecting socket for: calendar
                  [08.01.2023 06:58.29.848] [LOG]   Starting node helper for: calendar
                  [08.01.2023 06:58.29.858] [LOG]   Connecting socket for: newsfeed
                  [08.01.2023 06:58.29.858] [LOG]   Starting node helper for: newsfeed
                  [08.01.2023 06:58.29.858] [LOG]   Sockets connected & modules started ...
                  [3460:0108/070022.937:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL i
                  s disabled, ANGLE is
                    sdetweil @dude31222
                    @dude31222 never tried win7 myself… this topic was created a while ago…
                    you can TRY setting an environment variable in the cmd.exe window before executing npm start
                    cd MagicMirror
                    set ELECTRON_DISABLE_GPU=1
                    npm start
                      dude31222 @sdetweil
                      @sdetweil still having an empty screen but no more error messages in cmd
                        sdetweil @dude31222
                        @dude31222 that usually means u didn’t do the fonts install step or vendor install step
                        those are extra for windows install
                          dude31222 @sdetweil
                          @sdetweil i did. Now i’ve upgraded to windows 8.1. still a black screen but a new error```
                          [0110/062053.181:ERROR:_trace_logging_minimal.win.cc<78>] provider resistration failure
                            sdetweil @dude31222
                            @dude31222 I don’t know. those are so far out of service…
                              Reila
                              Heyo!
                              I’ve done a fresh install of MM2 (on Win10), and now I’m struggling with the blank electron screen.
                              I did the vendor and font install, changed the package.json to
                              "start":"node_modules/.bin/electron js/electron.js",
                              according to the guide on page 15, and now I’m getting
                              bash: line 1: node_modules.binelectron: command not found
                              on npm start, doesn’t start up MM.
                                sdetweil @Reila
                                @Reila you did not do the package.json edit correctly.
                                windows uses slashes leaning left
                                and u need 2 in each place
                                node-modules\\.bin\\electron  js\\electron.js
                                  Reila @sdetweil
                                  Oh, I just copied as it was! It might have been a different guide, it was old after all… I see the backward slashes in a later post now.
                                  So now I tried
                                  "start": "node_modules\\.bin\\electron  js\\electron.js",
                                  (with both the double and single space, just in case) and it’s giving me the same error still.
                                  I tested changing the start-dev variant too.
                                  I must be missing another step still.
                                    sdetweil @Reila
                                    @Reila I am away from my system at the moment be back in an hour or so.
                                    what does npm -v say?
                                      Reila @sdetweil
                                      @sdetweil No problem! Browser version works fine for tinkering in the meantime :)
                                      npm is 8.17.0
                                        sdetweil @Reila
                                        @Reila hm… this is what mine is set to
                                        and I don’t get any errors, but electron starts full screen, black screen
                                        but if I open edge and go to localhost:8080 it looks great and if I open electron
                                        (the 1st part, node_modules\.bin\electron) and go to http://localhost:8080
                                        it works…
                                        • R Roadrunner451 referenced this topic on
                                        • 1 Offline
                                          1a2a3a
                                          hi i need some help here. when i ran npm start, im getting this message.
                                          Starting MagicMirror: v2.23.0
                                          [28.06.2023 13:36.52.647] [LOG] Loading config …
                                          [28.06.2023 13:36.52.648] [DEBUG] config template file not exists, no envsubst
                                          [28.06.2023 13:36.52.650] [LOG] Loading module helpers …
                                          [28.06.2023 13:36.52.650] [LOG] No helper found for module: alert.
                                          [28.06.2023 13:36.52.655] [LOG] Initializing new module helper …
                                          [28.06.2023 13:36.52.655] [LOG] Module helper loaded: updatenotification
                                          [28.06.2023 13:36.52.656] [LOG] No helper found for module: clock.
                                          [28.06.2023 13:36.52.717] [LOG] Initializing new module helper …
                                          [28.06.2023 13:36.52.717] [LOG] Module helper loaded: calendar
                                          [28.06.2023 13:36.52.718] [LOG] No helper found for module: compliments.
                                          [28.06.2023 13:36.52.718] [LOG] No helper found for module: weather.
                                          [28.06.2023 13:36.52.732] [LOG] Initializing new module helper …
                                          [28.06.2023 13:36.52.733] [LOG] Module helper loaded: newsfeed
                                          [28.06.2023 13:36.52.733] [LOG] All module helpers loaded.
                                          [28.06.2023 13:36.52.737] [LOG] Starting server on port 8080 …
                                          [28.06.2023 13:36.52.779] [LOG] Launching application.
                                          [28.06.2023 13:36.52.812] [LOG] Server started …
                                          [28.06.2023 13:36.52.818] [LOG] Connecting socket for: updatenotification
                                          [28.06.2023 13:36.52.818] [LOG] Starting module helper: updatenotification
                                          [28.06.2023 13:36.52.818] [LOG] Connecting socket for: calendar
                                          [28.06.2023 13:36.52.819] [LOG] Starting node helper for: calendar
                                          [28.06.2023 13:36.52.819] [LOG] Connecting socket for: newsfeed
                                          [28.06.2023 13:36.52.819] [LOG] Starting node helper for: newsfeed
                                          [28.06.2023 13:36.52.820] [LOG] Sockets connected & modules started …
                                          am i supposed to do something next?
                                            sdetweil @1a2a3a
                                            @1a2a3a there is a big in the release on windows
                                            https://github.com/MichMich/MagicMirror/issues/3083
                                            you can follow the instructions to checkout the develop branch, or wait til July 1 for the next release with the fix
                                            https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                                            1 1 Reply Last reply Reply Quote 0
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
