    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 849.3k Views 59 Watching
      sdetweil @CheapDad
      @CheapDad use PM2 to auto launch
      this is a node application
      • mumblebajM Offline
        @sdetweil Don’t think it is an easy straight forward setup for PM2 on Windows to launch the mirror or am I mistaken? Would he have to setup pm2-windows-service and then perform some other setups to get PM2 to work to launch MM on Windows at startup?
          sdetweil @mumblebaj
          @mumblebaj pm2 setup does all that …
            @sdetweil :thumbs_up:
              sdetweil @mumblebaj
              @mumblebaj I was wrong for windows, and setup
              see here
              https://stackoverflow.com/questions/42758985/windows-auto-start-pm2-and-node-apps
              still pm2 is the easiest and same on every platform…
                @CheapDad Here is a great tutorial to set up PM2 on Windows.
                https://blog.cloudboost.io/nodejs-pm2-startup-on-windows-db0906328d75
                • C CheapDad referenced this topic on
                  Bobrae
                  When following your instructions on both Windows 7 and 10 machines, I get the following error message:
                  magicmirror@2.20.0 start C:\Users\Admin\MagicMirror
                  ‘DISPLAY’ is not recognized as an internal or external command,
                  operable program or batch file.
                  The error log gives the following:
                  1 verbose cli [
                  1 verbose cli ‘C:\Program Files\nodejs\node.exe’,
                  1 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
                  1 verbose cli ‘start’
                  1 verbose cli ]
                  2 info using npm@6.14.4
                  3 info using node@v13.14.0
                  4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                  5 info lifecycle magicmirror@2.20.0~prestart: magicmirror@2.20.0
                  6 info lifecycle magicmirror@2.20.0~start: magicmirror@2.20.0
                  7 verbose lifecycle magicmirror@2.20.0~start: unsafe-perm in lifecycle true
                  8 verbose lifecycle magicmirror@2.20.0~start: PATH: C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;C:\Users\Admin\MagicMirror\node_modules.bin;C:\Users\Admin\bin;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\local\bin;C:\Program Files\Git\usr\bin;C:\Program Files\Git\usr\bin;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\bin;C:\Users\Admin\bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files\Intel\Intel® Management Engine Components\DAL;C:\Program Files\Intel\Intel® Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel® Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel® Management Engine Components\IPT;C:\php;C:\Program Files\Calibre2;C:\Program Files\nodejs;C:\Program Files\Git\cmd;C:\Users\Admin\AppData\Roaming\npm;C:\Program Files\Git\usr\bin\vendor_perl;C:\Program Files\Git\usr\bin\core_perl
                  9 verbose lifecycle magicmirror@2.20.0~start: CWD: C:\Users\Admin\MagicMirror
                  10 silly lifecycle magicmirror@2.20.0~start: Args: [
                  10 silly lifecycle ‘/d /s /c’,
                  10 silly lifecycle ‘DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js’
                  10 silly lifecycle ]
                  11 silly lifecycle magicmirror@2.20.0~start: Returned: code: 1 signal: null
                  12 info lifecycle magicmirror@2.20.0~start: Failed to exec start script
                  13 verbose stack Error: magicmirror@2.20.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                  13 verbose stack Exit status 1
                  13 verbose stack at EventEmitter. (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\index.js:332:16)
                  13 verbose stack at EventEmitter.emit (events.js:315:20)
                  13 verbose stack at ChildProcess. (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\lib\spawn.js:55:14)
                  13 verbose stack at ChildProcess.emit (events.js:315:20)
                  13 verbose stack at maybeClose (internal/child_process.js:1026:16)
                  13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                  14 verbose pkgid magicmirror@2.20.0
                  15 verbose cwd C:\Users\Admin\MagicMirror
                  16 verbose Windows_NT 6.1.7601
                  17 verbose argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “start”
                  18 verbose node v13.14.0
                  19 verbose npm v6.14.4
                  20 error code ELIFECYCLE
                  21 error errno 1
                  22 error magicmirror@2.20.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                  22 error Exit status 1
                  23 error Failed at the magicmirror@2.20.0 start script.
                  23 error This is probably not a problem with npm. There is likely additional logging output above.
                  24 verbose exit [ 1, true ]
                    sdetweil @Bobrae
                    @Bobrae see
                    https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1659891805957
                    • Cliff365C Offline
                      Cliff365 @Mykle1
                      @Mykle1 First off, thanks so much for a great guide. I’m having what is likely a simple issue, but I can’t figure out how to resolve it. I am getting the following error message with the npm start command. Not concerned about the warnings, but how do resolve the DISPLAY issue?
                      $ npm start
                      npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
                      'DISPLAY' is not recognized as an internal or external command,
                      cliff@BNC-LAB01 MINGW64 ~/MagicMirror (master)
                        sdetweil @Cliff365
                        @Cliff365 see the end of the post I just linked to in the prior post
                        also, do not run under mingw… just cmd.exe
                        • Cliff365C Offline
                          Cliff365 @Mykle1
                          @Mykle1 Thanks for your help on the DISPLAY issue. I changed the line in packages.json file to:
                          “start”: “node_modules/.bin/electron js/electron.js”,
                          I get the following error message back:
                          'node_modules' is not recognized as an internal or external command,
                            sdetweil @Cliff365
                            @Cliff365 you didn’t follow all of the last line of
                            https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1660158299123
                            ps, I’m not @Mykle1
                            Cliff365C D 2 Replies Last reply Reply Quote 0
                            • Cliff365C Offline
                              Cliff365 @sdetweil
                              @sdetweil Oops! Thanks sdetweil
                                dude31222 @sdetweil
                                Hey! @sdetweil i’ve spend more than 10 hours whit this because i didn’t read the entire thread. I’ve finally installed mm2 on a 32bit laptop whit w7 and node v16.6 but when i run npm start i just got a black screen. any ideas on how to find a solution? my cmd here:
                                [08.01.2023 06:58.14.001] [LOG]   Starting MagicMirror: v2.22.0
                                [08.01.2023 06:58.14.151] [LOG]   Loading config ...
                                [08.01.2023 06:58.14.201] [LOG]   Loading module helpers ...
                                [08.01.2023 06:58.14.231] [LOG]   No helper found for module: alert.
                                [08.01.2023 06:58.14.361] [LOG]   Initializing new module helper ...
                                [08.01.2023 06:58.14.371] [LOG]   Module helper loaded: updatenotification
                                [08.01.2023 06:58.14.395] [LOG]   No helper found for module: clock.
                                [08.01.2023 06:58.17.473] [LOG]   Initializing new module helper ...
                                [08.01.2023 06:58.17.477] [LOG]   Module helper loaded: calendar
                                [08.01.2023 06:58.17.497] [LOG]   No helper found for module: compliments.
                                [08.01.2023 06:58.17.497] [LOG]   No helper found for module: weather.
                                [08.01.2023 06:58.17.839] [LOG]   Initializing new module helper ...
                                [08.01.2023 06:58.17.839] [LOG]   Module helper loaded: newsfeed
                                [08.01.2023 06:58.17.849] [LOG]   No helper found for module: facts.
                                [08.01.2023 06:58.17.849] [LOG]   All module helpers loaded.
                                [08.01.2023 06:58.19.559] [LOG]   Starting server on port 8080 ...
                                [08.01.2023 06:58.23.451] [LOG]   Launching application.
                                [08.01.2023 06:58.29.838] [LOG]   Server started ...
                                [08.01.2023 06:58.29.848] [LOG]   Connecting socket for: updatenotification
                                [08.01.2023 06:58.29.848] [LOG]   Starting module helper: updatenotification
                                [08.01.2023 06:58.29.848] [LOG]   Connecting socket for: calendar
                                [08.01.2023 06:58.29.848] [LOG]   Starting node helper for: calendar
                                [08.01.2023 06:58.29.858] [LOG]   Connecting socket for: newsfeed
                                [08.01.2023 06:58.29.858] [LOG]   Starting node helper for: newsfeed
                                [08.01.2023 06:58.29.858] [LOG]   Sockets connected & modules started ...
                                [3460:0108/070022.937:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL i
                                s disabled, ANGLE is
                                  sdetweil @dude31222
                                  @dude31222 never tried win7 myself… this topic was created a while ago…
                                  you can TRY setting an environment variable in the cmd.exe window before executing npm start
                                  cd MagicMirror
                                  set ELECTRON_DISABLE_GPU=1
                                  npm start
                                    dude31222 @sdetweil
                                    @sdetweil still having an empty screen but no more error messages in cmd
                                      sdetweil @dude31222
                                      @dude31222 that usually means u didn’t do the fonts install step or vendor install step
                                      those are extra for windows install
                                        dude31222 @sdetweil
                                        @sdetweil i did. Now i’ve upgraded to windows 8.1. still a black screen but a new error```
                                        [0110/062053.181:ERROR:_trace_logging_minimal.win.cc<78>] provider resistration failure
                                          sdetweil @dude31222
                                          @dude31222 I don’t know. those are so far out of service…
                                            Reila
                                            Heyo!
                                            I’ve done a fresh install of MM2 (on Win10), and now I’m struggling with the blank electron screen.
                                            I did the vendor and font install, changed the package.json to
                                            "start":"node_modules/.bin/electron js/electron.js",
                                            according to the guide on page 15, and now I’m getting
                                            bash: line 1: node_modules.binelectron: command not found
                                            on npm start, doesn’t start up MM.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
