    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 874.0k Views 59 Watching
      sdetweil @Cliff365
      @Cliff365 you didn’t follow all of the last line of
      https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1660158299123
      ps, I’m not @Mykle1
      Cliff365C D 2 Replies Last reply Reply Quote 0
      • Cliff365C
        Cliff365 @sdetweil
        @sdetweil Oops! Thanks sdetweil
          dude31222 @sdetweil
          Hey! @sdetweil i’ve spend more than 10 hours whit this because i didn’t read the entire thread. I’ve finally installed mm2 on a 32bit laptop whit w7 and node v16.6 but when i run npm start i just got a black screen. any ideas on how to find a solution? my cmd here:
          [08.01.2023 06:58.14.001] [LOG]   Starting MagicMirror: v2.22.0
          [08.01.2023 06:58.14.151] [LOG]   Loading config ...
          [08.01.2023 06:58.14.201] [LOG]   Loading module helpers ...
          [08.01.2023 06:58.14.231] [LOG]   No helper found for module: alert.
          [08.01.2023 06:58.14.361] [LOG]   Initializing new module helper ...
          [08.01.2023 06:58.14.371] [LOG]   Module helper loaded: updatenotification
          [08.01.2023 06:58.14.395] [LOG]   No helper found for module: clock.
          [08.01.2023 06:58.17.473] [LOG]   Initializing new module helper ...
          [08.01.2023 06:58.17.477] [LOG]   Module helper loaded: calendar
          [08.01.2023 06:58.17.497] [LOG]   No helper found for module: compliments.
          [08.01.2023 06:58.17.497] [LOG]   No helper found for module: weather.
          [08.01.2023 06:58.17.839] [LOG]   Initializing new module helper ...
          [08.01.2023 06:58.17.839] [LOG]   Module helper loaded: newsfeed
          [08.01.2023 06:58.17.849] [LOG]   No helper found for module: facts.
          [08.01.2023 06:58.17.849] [LOG]   All module helpers loaded.
          [08.01.2023 06:58.19.559] [LOG]   Starting server on port 8080 ...
          [08.01.2023 06:58.23.451] [LOG]   Launching application.
          [08.01.2023 06:58.29.838] [LOG]   Server started ...
          [08.01.2023 06:58.29.848] [LOG]   Connecting socket for: updatenotification
          [08.01.2023 06:58.29.848] [LOG]   Starting module helper: updatenotification
          [08.01.2023 06:58.29.848] [LOG]   Connecting socket for: calendar
          [08.01.2023 06:58.29.848] [LOG]   Starting node helper for: calendar
          [08.01.2023 06:58.29.858] [LOG]   Connecting socket for: newsfeed
          [08.01.2023 06:58.29.858] [LOG]   Starting node helper for: newsfeed
          [08.01.2023 06:58.29.858] [LOG]   Sockets connected & modules started ...
          [3460:0108/070022.937:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL i
          s disabled, ANGLE is
            sdetweil @dude31222
            @dude31222 never tried win7 myself… this topic was created a while ago…
            you can TRY setting an environment variable in the cmd.exe window before executing npm start
            cd MagicMirror
            set ELECTRON_DISABLE_GPU=1
            npm start
              dude31222 @sdetweil
              @sdetweil still having an empty screen but no more error messages in cmd
                sdetweil @dude31222
                @dude31222 that usually means u didn’t do the fonts install step or vendor install step
                those are extra for windows install
                  dude31222 @sdetweil
                  @sdetweil i did. Now i’ve upgraded to windows 8.1. still a black screen but a new error```
                  [0110/062053.181:ERROR:_trace_logging_minimal.win.cc<78>] provider resistration failure
                    sdetweil @dude31222
                    @dude31222 I don’t know. those are so far out of service…
                      Reila
                      Heyo!
                      I’ve done a fresh install of MM2 (on Win10), and now I’m struggling with the blank electron screen.
                      I did the vendor and font install, changed the package.json to
                      "start":"node_modules/.bin/electron js/electron.js",
                      according to the guide on page 15, and now I’m getting
                      bash: line 1: node_modules.binelectron: command not found
                      on npm start, doesn’t start up MM.
                        sdetweil @Reila
                        @Reila you did not do the package.json edit correctly.
                        windows uses slashes leaning left
                        and u need 2 in each place
                        node-modules\\.bin\\electron  js\\electron.js
                          Reila @sdetweil
                          Oh, I just copied as it was! It might have been a different guide, it was old after all… I see the backward slashes in a later post now.
                          So now I tried
                          "start": "node_modules\\.bin\\electron  js\\electron.js",
                          (with both the double and single space, just in case) and it’s giving me the same error still.
                          I tested changing the start-dev variant too.
                          I must be missing another step still.
                            sdetweil @Reila
                            @Reila I am away from my system at the moment be back in an hour or so.
                            what does npm -v say?
                              Reila @sdetweil
                              @sdetweil No problem! Browser version works fine for tinkering in the meantime :)
                              npm is 8.17.0
                                sdetweil @Reila
                                @Reila hm… this is what mine is set to
                                and I don’t get any errors, but electron starts full screen, black screen
                                but if I open edge and go to localhost:8080 it looks great and if I open electron
                                (the 1st part, node_modules\.bin\electron) and go to http://localhost:8080
                                it works…
                                • R Roadrunner451 referenced this topic on
                                  1a2a3a
                                  hi i need some help here. when i ran npm start, im getting this message.
                                  Starting MagicMirror: v2.23.0
                                  [28.06.2023 13:36.52.647] [LOG] Loading config …
                                  [28.06.2023 13:36.52.648] [DEBUG] config template file not exists, no envsubst
                                  [28.06.2023 13:36.52.650] [LOG] Loading module helpers …
                                  [28.06.2023 13:36.52.650] [LOG] No helper found for module: alert.
                                  [28.06.2023 13:36.52.655] [LOG] Initializing new module helper …
                                  [28.06.2023 13:36.52.655] [LOG] Module helper loaded: updatenotification
                                  [28.06.2023 13:36.52.656] [LOG] No helper found for module: clock.
                                  [28.06.2023 13:36.52.717] [LOG] Initializing new module helper …
                                  [28.06.2023 13:36.52.717] [LOG] Module helper loaded: calendar
                                  [28.06.2023 13:36.52.718] [LOG] No helper found for module: compliments.
                                  [28.06.2023 13:36.52.718] [LOG] No helper found for module: weather.
                                  [28.06.2023 13:36.52.732] [LOG] Initializing new module helper …
                                  [28.06.2023 13:36.52.733] [LOG] Module helper loaded: newsfeed
                                  [28.06.2023 13:36.52.733] [LOG] All module helpers loaded.
                                  [28.06.2023 13:36.52.737] [LOG] Starting server on port 8080 …
                                  [28.06.2023 13:36.52.779] [LOG] Launching application.
                                  [28.06.2023 13:36.52.812] [LOG] Server started …
                                  [28.06.2023 13:36.52.818] [LOG] Connecting socket for: updatenotification
                                  [28.06.2023 13:36.52.818] [LOG] Starting module helper: updatenotification
                                  [28.06.2023 13:36.52.818] [LOG] Connecting socket for: calendar
                                  [28.06.2023 13:36.52.819] [LOG] Starting node helper for: calendar
                                  [28.06.2023 13:36.52.819] [LOG] Connecting socket for: newsfeed
                                  [28.06.2023 13:36.52.819] [LOG] Starting node helper for: newsfeed
                                  [28.06.2023 13:36.52.820] [LOG] Sockets connected & modules started …
                                  am i supposed to do something next?
                                    sdetweil @1a2a3a
                                    @1a2a3a there is a big in the release on windows
                                    https://github.com/MichMich/MagicMirror/issues/3083
                                    you can follow the instructions to checkout the develop branch, or wait til July 1 for the next release with the fix
                                    https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                                    1 1 Reply Last reply Reply Quote 0
                                      1a2a3a @sdetweil
                                      @sdetweil but when i go to localhost 8080 via web browser it appears to show the screen. is that normal?
                                        sdetweil @1a2a3a
                                        @1a2a3a yes, just the initial electron browser startup was broken
                                          1a2a3a @sdetweil
                                          @sdetweil so i used your fix with the link that you provided and i can go into MM.
                                          there is something i dont get though… The MM app itself is ‘electron’?
                                          and my git cmd is ‘terminal’?
                                          when i want to install module etc, i have to close the terminal and reopen and npm start again? is there a way to work continuously on the terminal without closing and opening?
                                          right now im working on windows and subsequently i will shift to raspberry PI. how do i transit everything over to the PI? or do i have to resetup everything?
                                          and if im working on the windows, can i ‘cast’ the MM to anywhere else other than a web browser?
                                            sdetweil @1a2a3a
                                            @1a2a3a said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                            yes… mm uses a browser to display
                                            electron, chrome, edge, firefox, Midori,…
                                            no, mm only loads modules on start. u can install all you want at once, but you have to restart to load them
                                            yes, just stop MagicMirror, ctrl-c to stop the app and back to command line… work and npm start again
                                            right now im working on windows and subsequently i will shift to raspberry Pi, how do i transit everything over to the PI? or do i have to resetup everything?
                                            yes
                                            install loads different binaries for mm. and for some modules.
                                            I have scripts for Linux to Linux, but not for windows.
                                            if you can cast a application… been years since I used windows.
                                            but you can open a browser from anywhere to mm
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
