    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 891.3k Views 59 Watching
      sdetweil @swvalenti
      @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
      electron js\electron.js
      u still have it wrong
      “node_modules/.bin/electron electron.js”
      electron is not in the path, so you have to give it the path to the executable
      once again different versions of node and npm require slightly different solutions…
      this is not an MM problem… they keep messing it up (in my opinion)
      https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
      swvalentiS 1 Reply Last reply
      • swvalentiS
        swvalenti Project Sponsor @sdetweil
        @sdetweil oh well I give up I tried all the steps, thanks for all the help and patience
        • swvalentiS
          • swvalentiS
            @sdetweil the only thing that isn’t working now is when I run npm init-y in each module folder the module in the dev window is still asking for replace instead of request
            S 2 Replies Last reply
            Reply Quote -1
              sdetweil @swvalenti
              @swvalenti you don’t run npm init unless u need to. only if u need to install a library that mm doesn’t reference anymore
                sdetweil @swvalenti
                what?
                words not clear
                • swvalentiS
                  @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                  what?
                  words not clear
                  Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                      at cmpVersions (module.js:525)
                      at Function.Module.register (module.js:502)
                      at MMM-OpenWeatherForecast.js:41
                  I did what you said but still get this error for some reason
                    sdetweil @swvalenti
                    @swvalenti ok, sometimes this is because of a typo in the config position for the module
                      DanClarkCBET3
                        DanClarkCBET3
                          sdetweil @DanClarkCBET3
                          @DanClarkCBET3 see
                            DanClarkCBET3
                            Is there a way to make a desktop shortcut to start MagicMirror?
                              @DanClarkCBET3 sure. create a batch file
                              mm.cmd
                              in the installers folder, and then use that for the shortcut
                              mm.cmd should do
                              @npm start
                                CheapDad
                                My apologies if the answer to my question is located somewhere in this long thread. As a quick method of bringing some MM functionality to my kids in college, I’d like to install MM onto their laptops and have it autorun at start (like a batch file) and run in a small window.
                                I see that I can install it on their laptops and I know how to create a batch file, but what I don’t know is how to ensure that a linux program starts in a windows batch file and how to get it to autosize to a small window.
                                Has anyone done that?
                                  sdetweil @CheapDad
                                  @CheapDad use PM2 to auto launch
                                  this is a node application
                                  mumblebajM 1 Reply Last reply
                                  • mumblebajM
                                    @sdetweil Don’t think it is an easy straight forward setup for PM2 on Windows to launch the mirror or am I mistaken? Would he have to setup pm2-windows-service and then perform some other setups to get PM2 to work to launch MM on Windows at startup?
                                      sdetweil @mumblebaj
                                      @mumblebaj pm2 setup does all that …
                                      • mumblebajM
                                        @sdetweil :thumbs_up:
                                          sdetweil @mumblebaj
                                          @mumblebaj I was wrong for windows, and setup
                                          see here
                                          https://stackoverflow.com/questions/42758985/windows-auto-start-pm2-and-node-apps
                                          still pm2 is the easiest and same on every platform…
                                          • mumblebajM
                                            @CheapDad Here is a great tutorial to set up PM2 on Windows.
                                            https://blog.cloudboost.io/nodejs-pm2-startup-on-windows-db0906328d75
                                            • C CheapDad referenced this topic on
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
