    Avoidance of Troubleshooting Q
    11 Posts 3 Posters 2.9k Views 2 Watching
      sdetweil @ankonaskiff17
      @ankonaskiff17 should not be any issues w config.js or custom.css
      I havent tried the 64 bit myself yet.
      glad to hear you are back from COVID. I spent 7 weeks in hospital early last year …
      • mumblebajM Offline
        mumblebaj Module Developer @ankonaskiff17
        @ankonaskiff17 SO I believe a few things have changed since. Some deprecated modules they got rid off i.e. request and some others. Modules that use them would be a problem. My suggestion would be to use Sam’s upgrade script which would check each module directory and fixup the missing dependencies for you.
          sdetweil @mumblebaj
          @mumblebaj good catch
          also the direct reference
          ankonaskiff17A 1 Reply Last reply Reply Quote 0
          • ankonaskiff17A Offline
            ankonaskiff17 @sdetweil
            @sdetweil I did use your install script for the core installation and that is all fine and functional. I decided to give 64 bit a try because figured if the base MM didn’t like it, just reformat card and do 32 bit.
            Hoping I can put MM SD card in laptop card reader and portable drive with files plug in to USB on laptop and it just be a copy/paste exercise in VSC.
            Most of modules I use are pretty basic. I had found a setup I liked and hoping it’s plug and play.
            @sdetweil Glad you made it out of hospital.
              @ankonaskiff17 that should work…
              u might want to look at my backup/restore scripts.
              they backup config.js and custom.css and the URLs of all the modules u have installed
              so 3 small files.
              and then on restore copies back the 2 files and uses the URLs to reinstall all the modules and (fix the missing dependencies too)…
              https://github.com/sdetweil/MagicMirror-backup-restore
              I need to make them so they can be executed from the repo… but haven’t done that yet…
              i made it so the 3 files are in a git repo, so you version them and then can restore any particular version…
              and push the git repo to your github (in a private repo)
                @sdetweil I was just reading the topic about fix for black screen and while I need to read several more times to get my arms around it, I was wondering if I can do those scripts on the files before I copy them over. Instead of ssh’ing in to Pi open terminal go to drive and see if they are problematic before moving?
                I would back up exiting files in case I blew something up.
                  @ankonaskiff17 u can run the backup script on your sd folder… it takes a -s parm for source
                  (-h shows the syntax)
                  this would create the 3 files…
                  then u could run the restore on the new system by copying the backup folder to the new system
                  (and -h shows syntax)
                  this reinstalls the modules from github… not copies any of their files…
                    @sdetweil Found my first 3rd party module lacking “request”. Your tutorial worked like a charm
                      ankonaskiff17 @ankonaskiff17
                      @ankonaskiff17 @sdetweil Found a new way scorch a Pi on this project.
                      Had a snap together case I put Pi in, snapped closed and I’ll admit, it to some muscle to snap case closed.
                      Shortly thereafter I caught the unmistakable odor of burning electronics.
                      I snapped the SD card so it was bent like 90°
                      The Pi did not like that.
                        @ankonaskiff17 same here, oops… just snap the cover on…
