    Any modules that could display a livestream
    32 Posts 6 Posters 14.7k Views 6 Watching
    • JerryPJ Offline
      JerryP @adrien00
      @adrien00
      		module: 'MMM-iFrame-Ping',
      		position: 'middle_center',	// This can be any of the regions.
      			url: "https://", //url to display
      			height:"100%",
      			width:"100%",
      			autoRefresh: false, //set to false for video
      			updateInterval: 1, //in min. Only if autoRefresh: true
      			displayLastUpdate: true,
      			width: "100%", // Optional. Default: 100%
      			height: "400px", //Optional. Default: 100px
      			scrolling: "no"
      • T Offline
        tanvir586 @JerryP
        @JerryP does it work with the latest mm?
        JerryPJ 1 Reply Last reply Reply Quote 0
        • JerryPJ Offline
          JerryP @tanvir586
          @tanvir586
          For me in Holland is the BBC live stream no go. Butt YouTube or a other site is working at mini mirror version 2.18
          • T Offline
            tanvir586 @JerryP
            @JerryP I installed it today but I get black screen. I wanted to display a website (not youtube or any live stream site). Can you post your config if it’s ok with you.
            JerryPJ S 2 Replies Last reply Reply Quote 0
            • JerryPJ Offline
              JerryP @tanvir586
              @tanvir586
              the config is on top
                sdetweil @tanvir586
                @tanvir586 black screen see
                • T Offline
                  tanvir586 @sdetweil
                  @sdetweil thanks mate. It worked. But unfortunately my website is not showing. Its showing everything els but not mine.
                    sdetweil @tanvir586
                    @tanvir586 open the developers window, ctrl-shift-i, select the console tab and scroll up to see any error messages, usually red text
                    T 2 Replies Last reply Reply Quote 0
                    • T Offline
                      tanvir586 @sdetweil
                      @sdetweil 0|MagicMir | [26.03.2022 18:28.36.253] [ERROR] (node:19533) electron: Failed to load URL: https://mawaqit.net/en/shah-jalal-mosque-cardiff-cf24-4nj-united-kingdom with error: ERR_BLOCKED_BY_RESPONSE
                        sdetweil @tanvir586
                        @tanvir586 yep. basically they check to see if you requested the info from their site page
                        https://stackoverflow.com/questions/69243166/err-blocked-by-response-notsameorigin-cors-policy-javascript
                        • T Offline
                          tanvir586 @sdetweil
                          • T Offline
                            tanvir586 @sdetweil
                            @sdetweil is there anything I can do to get it work?
                            thgmirrorT 1 Reply Last reply Reply Quote 0
                            • thgmirrorT Offline
                              thgmirror @tanvir586
                              @tanvir586 another idea: have a look at my old post https://forum.magicmirror.builders/topic/14422/solved-displaying-part-of-a-website-google-sheets-graph/2?_=1648325230070 and align it to your needs.
                              Thomas
                              • T Offline
                                tanvir586 @thgmirror
                                @thgmirror hi I still didn’t work. I’m posting my html and cofig. and there is no error on log.
                                Chart
                                and config
                                		url: "/modules/mychart.html", //url to display
                                		height:"100%",
                                		width:"100%",
                                		autoRefresh: true, //set to false for video
                                		scrolling: "no"
                                • T Offline
                                  tanvir586 @tanvir586
                                    @tanvir586 Can you please post the https://maga… link here…it will be easier to check it:-)
                                      sdetweil @thgmirror
                                      @thgmirror he posted here
                                      https://forum.magicmirror.builders/topic/16533/any-modules-that-could-display-a-livestream/10?_=1648232499632
                                        thgmirror @sdetweil
                                        @tanvir586 OK, no chance with my way…your webside prohibits to display it in an iframe…
                                        • T Offline
                                          @thgmirror thanks for trying 😊
                                          • wishmaster270W Offline
                                            wishmaster270 Module Developer @tanvir586
                                            @tanvir586
                                            i use MMM-WebView (Repository) to display my NodeRed-Dashboard. Did a quick check and it looks like the Webpage you want to show on your mirror gets displayed.
                                            Maybe you want to give it a try.
                                            Make sure you set the electron options as suggested in the Readme.
                                            I use this configuration:
                                                    electronOptions: {
                                            		webPreferences: {
                                            			webSecurity: false,
                                            			webviewTag: true,
                                            			module: 'MMM-WebView',
                                            			position: 'top_center',
                                            			  url: 'https://www.bbc.co.uk/iplayer/live/bbcone',
                                            			  width: '500px',
                                            			  height: '1000px',
                                            Edit: Checked the Mega-Link as well and it works too.
                                            T A 2 Replies Last reply Reply Quote 0
