    Any modules that could display a livestream
    32 Posts 6 Posters 15.0k Views 6 Watching
    • T
      tanvir586 @JerryP
      @JerryP I installed it today but I get black screen. I wanted to display a website (not youtube or any live stream site). Can you post your config if it’s ok with you.
      JerryPJ S 2 Replies Last reply
      • JerryPJ
        JerryP @tanvir586
        @tanvir586
        the config is on top
          sdetweil @tanvir586
          @tanvir586 black screen see
          T 1 Reply Last reply
          • T
            tanvir586 @sdetweil
            @sdetweil thanks mate. It worked. But unfortunately my website is not showing. Its showing everything els but not mine.
              sdetweil @tanvir586
              @tanvir586 open the developers window, ctrl-shift-i, select the console tab and scroll up to see any error messages, usually red text
              T 2 Replies Last reply
              • T
                tanvir586 @sdetweil
                @sdetweil 0|MagicMir | [26.03.2022 18:28.36.253] [ERROR] (node:19533) electron: Failed to load URL: https://mawaqit.net/en/shah-jalal-mosque-cardiff-cf24-4nj-united-kingdom with error: ERR_BLOCKED_BY_RESPONSE
                  sdetweil @tanvir586
                  @tanvir586 yep. basically they check to see if you requested the info from their site page
                  https://stackoverflow.com/questions/69243166/err-blocked-by-response-notsameorigin-cors-policy-javascript
                  • T
                    tanvir586 @sdetweil
                    • T
                      tanvir586 @sdetweil
                      @sdetweil is there anything I can do to get it work?
                      thgmirrorT 1 Reply Last reply
                      • thgmirrorT
                        thgmirror @tanvir586
                        @tanvir586 another idea: have a look at my old post https://forum.magicmirror.builders/topic/14422/solved-displaying-part-of-a-website-google-sheets-graph/2?_=1648325230070 and align it to your needs.
                        Thomas
                        • T
                          tanvir586 @thgmirror
                          @thgmirror hi I still didn’t work. I’m posting my html and cofig. and there is no error on log.
                          Chart
                          and config
                          	module: 'MMM-iFrame-Ping',
                          	position: 'middle_center',	// This can be any of the regions.
                          		url: "/modules/mychart.html", //url to display
                          		height:"100%",
                          		width:"100%",
                          		autoRefresh: true, //set to false for video
                          		updateInterval: 1, //in min. Only if autoRefresh: true
                          		displayLastUpdate: true,
                          		width: "100%", // Optional. Default: 100%
                          		height: "400px", //Optional. Default: 100px
                          		scrolling: "no"
                          • T
                            tanvir586 @tanvir586
                            • thgmirrorT
                              @tanvir586 Can you please post the https://maga… link here…it will be easier to check it:-)
                                sdetweil @thgmirror
                                @thgmirror he posted here
                                https://forum.magicmirror.builders/topic/16533/any-modules-that-could-display-a-livestream/10?_=1648232499632
                                • thgmirrorT
                                  thgmirror @sdetweil
                                  @tanvir586 OK, no chance with my way…your webside prohibits to display it in an iframe…
                                  • T
                                    @thgmirror thanks for trying 😊
                                    wishmaster270W 1 Reply Last reply
                                    • wishmaster270W
                                      wishmaster270 Module Developer @tanvir586
                                      @tanvir586
                                      i use MMM-WebView (Repository) to display my NodeRed-Dashboard. Did a quick check and it looks like the Webpage you want to show on your mirror gets displayed.
                                      Maybe you want to give it a try.
                                      Make sure you set the electron options as suggested in the Readme.
                                      I use this configuration:
                                              electronOptions: {
                                      		webPreferences: {
                                      			webSecurity: false,
                                      			webviewTag: true,
                                      			module: 'MMM-WebView',
                                      			position: 'top_center',
                                      			  url: 'https://www.bbc.co.uk/iplayer/live/bbcone',
                                      			  width: '500px',
                                      			  height: '1000px',
                                      Edit: Checked the Mega-Link as well and it works too.
                                      T A 2 Replies Last reply
                                      • T
                                        tanvir586 @wishmaster270
                                        @wishmaster270 Hi. Thanks mate. But I’m using mmm.widget2 as website got web widget. It’s working fine but just facing one problem now. When the module refresh I get cookies. I don’t wanna to accept it all the time. Is there any way I can auto accept the cookies? Screenshot_20220329-012930_VNC Viewer.jpg
                                        This is my widget link aswell.
                                        code: <iframe src="https://mawaqit.net/en/w/al-falah-centre-cardiff?showOnly5PrayerTimes=0" width="100%" height="375" frameborder="0" scrolling="no" class="widget"></iframe>,
                                        • thgmirrorT
                                          @tanvir586 second try:-)
                                          <HTML>
                                          <HEAD>
                                          <TITLE>YYYYY</TITLE>
                                          </HEAD>
                                          <body bgcolor=#000000>
                                          <div style="border: none; overflow: hidden; max-width: 900px; max-height: 370px">
                                          <iframe scrolling="no" src="https://mawaqit.net/en/w/al-falah-centre-cardiff?showOnly5PrayerTimes=0"
                                          style="border: none;  margin-top: 0px; margin-left: -6px; height: 1200px; width: 900px">
                                          </iframe>
                                          </div>
                                          </body>
                                          </HTML>
                                          Store this as a local html-file and add it as url to you prefered module. I hide the cookie-question outside the visible region. So it is still there but it will not bother you. Good luck!!!
                                          Thomas
                                          • T
                                            @thgmirror hi, could you double check this for me please. Don’t know where I made mistake it’s not working.
