Solved Updating did nothing but gave fatal error warning.
MM reports being 119 commits behind. OK!
Went to https://docs.magicmirror.builders/getting-started/upgrade-guide.html
Did the suggested backups OK
Went to:~/MagicMirror $ entered git pull && npm install --only=prod --omit=dev
Got this:
fatal: Unable to read current working directory: No such file or directory
Looked at sdetweil’s script, not sure from the instructions if it need to be
run from :~/MagicMirror $ or elsewhere?Thank you.
I now have coloured icons in the calendar:
Code now looks like this:
/* Calendar: config.js set to symbol: 'fa-light fa-calendar', */ .calendar .fa-calendar-day { color: #00d255 /* 55=Green FF=Blue */ } /* Calendar: config.js set to symbol: 'fa-light fa-trash-can', */ .calendar .fa-trash { color: #C97F7F /* Brown */ }
@Richard238 You can run Sam’s script from pretty much anywhere. I usually run it from the MagicMirror folder.
@Richard238 my script is made to run from anywhere… it 'assume’s you are NOT in the MagicMirror folder
so, its simple… open a command prompt and paste…
note that upgrade is a 2 part process… (You wouldn’t want me destroying your work for something u forgot about, right?)
so, 1st run TESTS the ability to apply the update, but makes NO changes to anything running.
it reports… files changed but might be overlayed… etc…
if all is good and u feel comfortable,
then you run it a second time with the ‘apply’ parameterto actually DO the upgrade process
Tried the script, and got this node error:
pi@magicmirror:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" No LSB modules are available. doing test run = true, NO updates will be applied! update log will be in /home/pi/MagicMirror/installers/upgrade.log Check current Node installation ... Node currently installed. Checking version number. Minimum Node version: v16.9.1 Installed Node version: v16.1.0 Node should be upgraded. A Node process is currently running. Can't upgrade. Please quit all Node processes and restart the update. running process(s) are pi 15102 15101 0 Jan08 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js pi@magicmirror:~ $
@Richard238 right. MagicMirror is running. you have to stop it before u can update
as it appears we need to upgrade node and npm as well…
pm2 stop all
@sdetweil And then rerun the script?
@Richard238 yes
pi@magicmirror:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" No LSB modules are available. doing test run = true, NO updates will be applied! update log will be in /home/pi/MagicMirror/installers/upgrade.log Check current Node installation ... Node currently installed. Checking version number. Minimum Node version: v16.9.1 Installed Node version: v16.1.0 Node should be upgraded. Node.js upgrade defered, doing test run Check current NPM installation ... NPM currently installed. Checking version number. Minimum npm version: V7.11.2 Installed npm version: V7.11.2 No npm upgrade necessary. saving custom.css upgrading from version 2.18.0 to 2.19.0 fetching latest revisions there are 5 local files that are different than the master repo config/config.js.sample fonts/package-lock.json modules/default/newsfeed/newsfeed.js package-lock.json vendor/package-lock.json any *-lock.json files do not need to be saved do you want to save these files for later (Y/n)? Checking for modules with removed libraries processing dependency changes for active modules with package.json files processing for module MMM-MysqlQuery please wait ---------------------------------- skipped processing for MMM-MysqlQuery, doing test run processing complete for module MMM-MysqlQuery restoring custom.css test run, restoring files stashed pi@magicmirror:~ $
pi@magicmirror:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply No LSB modules are available. doing test run = false update log will be in /home/pi/MagicMirror/installers/upgrade.log Check current Node installation ... Node currently installed. Checking version number. Minimum Node version: v16.9.1 Installed Node version: v16.1.0 Node should be upgraded. Installing Node.js ... gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg' Reading package lists... Done Building dependency tree Reading state information... Done nodejs is already the newest version (17.3.1-deb-1nodesource1). The following package was automatically installed and is no longer required: python-colorzero Use 'sudo apt autoremove' to remove it. 0 upgraded, 0 newly installed, 0 to remove and 63 not upgraded. node version is Node.js installation Done! version=v16.1.0 Check current NPM installation ... NPM currently installed. Checking version number. Minimum npm version: V7.11.2 Installed npm version: V7.11.2 No npm upgrade necessary. saving custom.css upgrading from version 2.18.0 to 2.19.0 fetching latest revisions there are 2 local files that are different than the master repo config/config.js.sample modules/default/newsfeed/newsfeed.js do you want to save these files for later (Y/n)? updating MagicMirror runtime, please wait > magicmirror@2.19.0 install > echo "Installing vendor files ... > " && cd vendor && npm install --loglevel=error Installing vendor files ... changed 3 packages, and audited 10 packages in 22s found 0 vulnerabilities > magicmirror@2.19.0 postinstall > npm run install-fonts && echo "MagicMirror² installation finished successfully! > " > magicmirror@2.19.0 install-fonts > echo "Installing fonts ... > " && cd fonts && npm install --loglevel=error Installing fonts ... added 2 packages, removed 1 package, and audited 3 packages in 5s found 0 vulnerabilities MagicMirror² installation finished successfully! > magicmirror@2.19.0 prepare > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed. no husky installed. added 3 packages, removed 4 packages, changed 35 packages, and audited 266 packages in 2m 20 packages are looking for funding run `npm fund` for details found 0 vulnerabilities npm notice npm notice New major version of npm available! 7.11.2 -> 8.6.0 npm notice Changelog: <https://github.com/npm/cli/releases/tag/v8.6.0> npm notice Run `npm install -g npm@8.6.0` to update! npm notice Checking for modules with removed libraries processing dependency changes for active modules with package.json files processing for module MMM-MysqlQuery please wait ---------------------------------- npm ERR! code ERESOLVE npm ERR! ERESOLVE unable to resolve dependency tree npm ERR! npm ERR! While resolving: mmm-mysqlquery@1.0.0 npm ERR! Found: stylelint@8.4.0 npm ERR! node_modules/stylelint npm ERR! dev stylelint@"^8.3.0" from the root project npm ERR! npm ERR! Could not resolve dependency: npm ERR! peer stylelint@"14.x" from grunt-stylelint@0.18.0 npm ERR! node_modules/grunt-stylelint npm ERR! dev grunt-stylelint@"latest" from the root project npm ERR! npm ERR! Fix the upstream dependency conflict, or retry npm ERR! this command with --force, or --legacy-peer-deps npm ERR! to accept an incorrect (and potentially broken) dependency resolution. npm ERR! npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2022-04-08T13_34_50_165Z-debug.log processing complete for module MMM-MysqlQuery restoring custom.css we stashed a set of files that appear changed from the latest repo versions. you should review them see installers/stashed_files for the list you can use git checkout stash@{0} -- filename to extract one file from the stash or git stash pop to restore them all WARNING.. WARNING.. either will overlay the file just installed by the update WARNING.. pi@magicmirror:~ $
Then did
pm2 start all
and now have a black screen on the Pi, and ‘Unable to connect’ on the desktop browser. :-(
