    Magic mirror is not showing up
    37 Posts 4 Posters 13.1k Views 4 Watching
      CoopDog1712
      when i try to start the magic mirror using pm2 start mm.sh, it says “Starting /home/pi/mm.sh in fork_mode (1 instance)”
      and then it says
      “Done”
      and then table that this looks like this shows up
      id │ name │ mode │ ↺ │ status │ cpu │ memory │
      │ 0 │ mm │ fork │ 0 │ online │ 0% │ 2.4mb
      then nothing happens. I have watched countless videos about the whole prossess and i do everything that they do, but after the enter pm2 start mm.sh the table shows up and then the magic mirror page shows up. i dont know what to do
        sdetweil @CoopDog1712
        @CoopDog1712 ok, best thing is to use my script to set it up…
        see
        last script on the page
        but in the meantime
        pm2 stop all
        pm2 logs --lines=50
        to see what is going on
        does executing mm.sh work by itself?
        pm2 is really picky… if there is a batch (bash) script, then it MUST be named mm.sh just mm won’t work.
        then pm2 delete 0
        pm2 save -f
        then run my fixuppm2.sh script
        C 2 Replies Last reply Reply Quote 0
          CoopDog1712 @sdetweil
          @sdetweil thank you so much for replying I really appreciate your help.
          On the table that shows up, I see that one of the names is just mm, how would I change it to mm.sh. Also when I run your script all it does is create a new Id on the table, called MagicMirror and it dosent seem to do anything
            @sdetweil!
            https://share.icloud.com/photos/09aR5ulFMM0L4v-vHL3NDBRNA
              @CoopDog1712 you can’t change and entry, but you can delete it
              pm2 delete 0 or pm2 delete mm
              pm2 logs --lines=50 might tell us what us going on
              pm2 is a command
              pm2 --help will show you all the things you can do
              ps, you can attach pics here… the third icon from the right above the editor here
                @CoopDog1712 i couldnt see much of that image
                  after typing in pm2 logs --lines=50, all that is coming up is a repeating of these couple lines
                    @CoopDog1712 yes, sometimes, the install messes up
                    pm2 stop all
                    npm install electron@17.2.0
                    to test
                    npm start
                    if all looks good
                    ctrl-c to stop
                    then
                    pm2 start MagicMirror
                    I should have asked, what pi is this on ? not pi 0 w, right?
                      @sdetweil no its a pi 4
                        @sdetweil so it works now, and after i enter pm2 start MagicMirror, it loads the software for the magic mirror, the only issue is that their is nothing only a blank screen, no time, weather, nothing. all that comes up is a blank screen. any suggestions?
                        • 1 / 4
