    Magic mirror is not showing up
    37 Posts 4 Posters 17.7k Views 4 Watching
      sdetweil @CoopDog1712
      @CoopDog1712 you can’t change and entry, but you can delete it
      pm2 delete 0 or pm2 delete mm
      pm2 logs --lines=50 might tell us what us going on
      pm2 is a command
      pm2 --help will show you all the things you can do
      ps, you can attach pics here… the third icon from the right above the editor here
        @CoopDog1712 i couldnt see much of that image
          CoopDog1712 @sdetweil
          after typing in pm2 logs --lines=50, all that is coming up is a repeating of these couple lines
            @CoopDog1712 yes, sometimes, the install messes up
            pm2 stop all
            npm install electron@17.2.0
            to test
            npm start
            if all looks good
            ctrl-c to stop
            then
            pm2 start MagicMirror
            I should have asked, what pi is this on ? not pi 0 w, right?
            C 2 Replies Last reply Reply Quote 0
              @sdetweil no its a pi 4
                @sdetweil so it works now, and after i enter pm2 start MagicMirror, it loads the software for the magic mirror, the only issue is that their is nothing only a blank screen, no time, weather, nothing. all that comes up is a blank screen. any suggestions?
                  @CoopDog1712 have u added modules?
                  if so see
                  and
                  pm2 logs --lines=50
                  will show you what is happening
                    @sdetweil i did what you said and this is what came up.
                    pi@raspberrypi:~/MagicMirror/modules/default/clock $ npm init -y
                    Wrote to /home/pi/MagicMirror/modules/default/clock/package.json:
                    “name”: “clock”,
                    “version”: “1.0.0”,
                    “description”: “The clock module is one of the default modules of the MagicMirror². This module displays the current date and time. The information will be updated realtime.”,
                    “main”: “clock.js”,
                    “scripts”: {
                    “test”: “echo "Error: no test specified" && exit 1”
                    “keywords”: [],
                    “author”: “”,
                    “license”: “ISC”
                    pi@raspberrypi:~/MagicMirror/modules/default/clock $ npm install ???
                    npm ERR! code EINVALIDTAGNAME
                    npm ERR! Invalid tag name “???”: Tags may not have any characters that encodeURIComponent encodes.
                    npm ERR! /home/pi/.npm/_logs/2022-04-24T14_06_36_382Z-debug-0.log
                    pi@raspberrypi:~/MagicMirror/modules/default/clock $ pm2 start MagicMirror
                    [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 4 ])
                    [PM2] MagicMirror ✓
                    [PM2] Process successfully started
                      @CoopDog1712 no… not in clock module… we ship that
                      what was the black screen failure message from the console output?
                      you read the messages and get the name of the missing library, and replace the ??? with that name
                      the reason YOU have to read the messages is because there are multiple libraries missing…
                      you only need to fix the ones that impact the modules you installed
                        @sdetweil i dont think i saw one. i never installed any modulles, even the ones that should come with it are not showing up
                          @CoopDog1712 ok, still show the messages where u start mm
                          either via
                          npm start
                          or
                          pm2
                          if pm2., then
                          pm2 logs --lines=50
                          will show the console output
                          what pi is this?
                            @sdetweil pi 4
                                @CoopDog1712 ah yes, fun times…
                                do
                                pm2 stop all
                                npm start
                                mm should come up
                                minimize mm (alt-spacebar, n)
                                ctrl-c to stop running instance
                                then
                                pm2 status
                                this will show the status or pm2 managed apps.
                                │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.7mb    │
                                use the name or the row number
                                pm2 start xxx
                                xxx is the name or the row number
                                for example
                                pm2 start 0
                                  @sdetweil after i installed electron@17.2.0 then started it, this came up 2022-04-24-084424_1920x1080_scrot.png
                                  then i did start pm2 start 4, and it started, but was still a blank screen
                                    @CoopDog1712 says something is still running…
                                    you didn’t do pm2 stop all
                                    after doing test
                                    ps -ef | grep -i magicmirror
                                    should return nothing
                                      @sdetweil whoops…
                                      ok is did pm2 stop all and then entered that line of code you gave me and got this 2022-04-24-084933_1920x1080_scrot.png
                                        @CoopDog1712
                                        ok do
                                        we will delete 1 entry so you don’t have 2 trying to run at the same time
                                        and then reboot
                                        pm2 delete  1
                                        pm2 save
                                        sudo reboot
                                          @sdetweil k i rebooted, then i started it up. nothing came up, still a blank screen so i did pm2 stop all and then did pm2 logs --lines=50 and these came up2022-04-24-090948_1920x1080_scrot.png
                                            @CoopDog1712
                                            pm2 status again
                                            also, how did you install mm? manual or my automated script?
                                            did you setup MM autostart before adding pm2?
