    Magic mirror is not showing up
    37 Posts 4 Posters 17.7k Views 4 Watching
      CoopDog1712 @sdetweil
      @sdetweil so it works now, and after i enter pm2 start MagicMirror, it loads the software for the magic mirror, the only issue is that their is nothing only a blank screen, no time, weather, nothing. all that comes up is a blank screen. any suggestions?
        sdetweil @CoopDog1712
        @CoopDog1712 have u added modules?
        if so see
        and
        pm2 logs --lines=50
        will show you what is happening
          @sdetweil i did what you said and this is what came up.
          pi@raspberrypi:~/MagicMirror/modules/default/clock $ npm init -y
          Wrote to /home/pi/MagicMirror/modules/default/clock/package.json:
          “name”: “clock”,
          “version”: “1.0.0”,
          “description”: “The clock module is one of the default modules of the MagicMirror². This module displays the current date and time. The information will be updated realtime.”,
          “main”: “clock.js”,
          “scripts”: {
          “test”: “echo "Error: no test specified" && exit 1”
          “keywords”: [],
          “author”: “”,
          “license”: “ISC”
          pi@raspberrypi:~/MagicMirror/modules/default/clock $ npm install ???
          npm ERR! code EINVALIDTAGNAME
          npm ERR! Invalid tag name “???”: Tags may not have any characters that encodeURIComponent encodes.
          npm ERR! /home/pi/.npm/_logs/2022-04-24T14_06_36_382Z-debug-0.log
          pi@raspberrypi:~/MagicMirror/modules/default/clock $ pm2 start MagicMirror
          [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 4 ])
          [PM2] MagicMirror ✓
          [PM2] Process successfully started
            @CoopDog1712 no… not in clock module… we ship that
            what was the black screen failure message from the console output?
            you read the messages and get the name of the missing library, and replace the ??? with that name
            the reason YOU have to read the messages is because there are multiple libraries missing…
            you only need to fix the ones that impact the modules you installed
              @sdetweil i dont think i saw one. i never installed any modulles, even the ones that should come with it are not showing up
                @CoopDog1712 ok, still show the messages where u start mm
                either via
                npm start
                or
                pm2
                if pm2., then
                pm2 logs --lines=50
                will show the console output
                what pi is this?
                C 2 Replies Last reply Reply Quote 0
                  @sdetweil pi 4
                      @CoopDog1712 ah yes, fun times…
                      do
                      pm2 stop all
                      npm install electron@17.2.0
                      npm start
                      mm should come up
                      minimize mm (alt-spacebar, n)
                      ctrl-c to stop running instance
                      then
                      pm2 status
                      this will show the status or pm2 managed apps.
                      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                      │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.7mb    │
                      use the name or the row number
                      pm2 start xxx
                      xxx is the name or the row number
                      for example
                      pm2 start 0
                        @sdetweil after i installed electron@17.2.0 then started it, this came up 2022-04-24-084424_1920x1080_scrot.png
                        then i did start pm2 start 4, and it started, but was still a blank screen
                          @CoopDog1712 says something is still running…
                          you didn’t do pm2 stop all
                          after doing test
                          ps -ef | grep -i magicmirror
                          should return nothing
                            @sdetweil whoops…
                            ok is did pm2 stop all and then entered that line of code you gave me and got this 2022-04-24-084933_1920x1080_scrot.png
                              @CoopDog1712
                              ok do
                              we will delete 1 entry so you don’t have 2 trying to run at the same time
                              and then reboot
                              pm2 delete  1
                              pm2 save
                              sudo reboot
                                @sdetweil k i rebooted, then i started it up. nothing came up, still a blank screen so i did pm2 stop all and then did pm2 logs --lines=50 and these came up2022-04-24-090948_1920x1080_scrot.png
                                  @CoopDog1712
                                  pm2 status again
                                  also, how did you install mm? manual or my automated script?
                                  did you setup MM autostart before adding pm2?
                                    @sdetweil i installed it manually, and no it didnt
                                      @CoopDog1712 what is the output of pm2 status?
                                          @CoopDog1712 ok, pm2 flush
                                          then
                                          npm start
                                            @sdetweil k i did that and it was still a blank screen, so i stoped it and did pm2 logs --lines=50 and got this 2022-04-24-091953_1920x1080_scrot.png
                                            also would it be worth a try to just completely delete everything and then start from scratch?
