    Magic mirror is not showing up
    37 Posts 4 Posters 17.7k Views 4 Watching
      CoopDog1712 @sdetweil
      @sdetweil pi 4
          sdetweil @CoopDog1712
          @CoopDog1712 ah yes, fun times…
          do
          pm2 stop all
          npm install electron@17.2.0
          npm start
          mm should come up
          minimize mm (alt-spacebar, n)
          ctrl-c to stop running instance
          then
          pm2 status
          this will show the status or pm2 managed apps.
          │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
          │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.7mb    │
          use the name or the row number
          pm2 start xxx
          xxx is the name or the row number
          for example
          pm2 start 0
          C 1 Reply Last reply
            @sdetweil after i installed electron@17.2.0 then started it, this came up 2022-04-24-084424_1920x1080_scrot.png
            then i did start pm2 start 4, and it started, but was still a blank screen
              @CoopDog1712 says something is still running…
              you didn’t do pm2 stop all
              after doing test
              ps -ef | grep -i magicmirror
              should return nothing
                @sdetweil whoops…
                ok is did pm2 stop all and then entered that line of code you gave me and got this 2022-04-24-084933_1920x1080_scrot.png
                  @CoopDog1712
                  ok do
                  we will delete 1 entry so you don’t have 2 trying to run at the same time
                  and then reboot
                  pm2 delete  1
                  pm2 save
                  sudo reboot
                    @sdetweil k i rebooted, then i started it up. nothing came up, still a blank screen so i did pm2 stop all and then did pm2 logs --lines=50 and these came up2022-04-24-090948_1920x1080_scrot.png
                      @CoopDog1712
                      pm2 status again
                      also, how did you install mm? manual or my automated script?
                      did you setup MM autostart before adding pm2?
                        @sdetweil i installed it manually, and no it didnt
                          @CoopDog1712 what is the output of pm2 status?
                              @CoopDog1712 ok, pm2 flush
                              then
                              npm start
                                @sdetweil k i did that and it was still a blank screen, so i stoped it and did pm2 logs --lines=50 and got this 2022-04-24-091953_1920x1080_scrot.png
                                also would it be worth a try to just completely delete everything and then start from scratch?
                                  @CoopDog1712 yeh, I don’t know whats going on
                                  do
                                  pm2 delete 4
                                  pm2 save -f
                                  rm -rf MagicMirror
                                  then run my install script
                                  see
                                  it will prompt if u want pm2 again
                                  and for turn off screen saver
                                  does everything
                                  C 3 Replies Last reply
                                    @sdetweil do you mean 0 in stead of 4?
                                      @CoopDog1712 whatever the number is . it was 4…
                                      or use the name
                                      MagicMirror
                                      whatever shows in
                                      pm2 status
                                          @CoopDog1712 come on man…
                                          pm2 status
                                          whatever the number is or use the NAME of the entry instead of the number
                                            @sdetweil that worked, thank you so much!!! just a few more questons, do you know how to flip the magic mirror the other way?
                                            S AssassinsA 2 Replies Last reply
