    Magic mirror is not showing up
    37 Posts 4 Posters 16.7k Views 4 Watching
      sdetweil @CoopDog1712
      @CoopDog1712
      ok do
      we will delete 1 entry so you don’t have 2 trying to run at the same time
      and then reboot
      pm2 delete  1
      pm2 save
      sudo reboot
        CoopDog1712 @sdetweil
        @sdetweil k i rebooted, then i started it up. nothing came up, still a blank screen so i did pm2 stop all and then did pm2 logs --lines=50 and these came up2022-04-24-090948_1920x1080_scrot.png
          @CoopDog1712
          pm2 status again
          also, how did you install mm? manual or my automated script?
          did you setup MM autostart before adding pm2?
          ps -ef | grep -i magicmirror
            @sdetweil i installed it manually, and no it didnt
              @CoopDog1712 what is the output of pm2 status?
                  @CoopDog1712 ok, pm2 flush
                  then
                  npm start
                    @sdetweil k i did that and it was still a blank screen, so i stoped it and did pm2 logs --lines=50 and got this 2022-04-24-091953_1920x1080_scrot.png
                    also would it be worth a try to just completely delete everything and then start from scratch?
                      @CoopDog1712 yeh, I don’t know whats going on
                      do
                      pm2 delete 4
                      pm2 save -f
                      rm -rf MagicMirror
                      then run my install script
                      see
                      it will prompt if u want pm2 again
                      and for turn off screen saver
                      does everything
                      C 3 Replies Last reply Reply Quote 0
                        @sdetweil do you mean 0 in stead of 4?
                          @CoopDog1712 whatever the number is . it was 4…
                          or use the name
                          MagicMirror
                          whatever shows in
                          pm2 status
                              @CoopDog1712 come on man…
                              pm2 status
                              whatever the number is or use the NAME of the entry instead of the number
                                @sdetweil that worked, thank you so much!!! just a few more questons, do you know how to flip the magic mirror the other way?
                                S AssassinsA 2 Replies Last reply Reply Quote 0
                                  @CoopDog1712 u mean from left right to up down?
                                  in the latest PI OS,
                                  desktop
                                  top left menu
                                  preferences
                                  screen configuration
                                  pick left/right/invert
                                  • AssassinsA Offline
                                    Assassins @CoopDog1712
                                    @CoopDog1712 Look with Rotating the Screen from Desktop : Rotate Screen
