    Magic mirror is not showing up
    37 Posts 4 Posters 16.7k Views 4 Watching
      CoopDog1712 @sdetweil
      @sdetweil after i installed electron@17.2.0 then started it, this came up 2022-04-24-084424_1920x1080_scrot.png
      then i did start pm2 start 4, and it started, but was still a blank screen
        sdetweil @CoopDog1712
        @CoopDog1712 says something is still running…
        you didn’t do pm2 stop all
        after doing test
        ps -ef | grep -i magicmirror
        should return nothing
          @sdetweil whoops…
          ok is did pm2 stop all and then entered that line of code you gave me and got this 2022-04-24-084933_1920x1080_scrot.png
            @CoopDog1712
            ok do
            we will delete 1 entry so you don’t have 2 trying to run at the same time
            and then reboot
            pm2 delete  1
            pm2 save
            sudo reboot
              @sdetweil k i rebooted, then i started it up. nothing came up, still a blank screen so i did pm2 stop all and then did pm2 logs --lines=50 and these came up2022-04-24-090948_1920x1080_scrot.png
                @CoopDog1712
                pm2 status again
                also, how did you install mm? manual or my automated script?
                did you setup MM autostart before adding pm2?
                  @sdetweil i installed it manually, and no it didnt
                    @CoopDog1712 what is the output of pm2 status?
                        @CoopDog1712 ok, pm2 flush
                        then
                        npm start
                          @sdetweil k i did that and it was still a blank screen, so i stoped it and did pm2 logs --lines=50 and got this 2022-04-24-091953_1920x1080_scrot.png
                          also would it be worth a try to just completely delete everything and then start from scratch?
                            @CoopDog1712 yeh, I don’t know whats going on
                            do
                            pm2 delete 4
                            pm2 save -f
                            rm -rf MagicMirror
                            then run my install script
                            see
                            it will prompt if u want pm2 again
                            and for turn off screen saver
                            does everything
                            C 3 Replies Last reply Reply Quote 0
                              @sdetweil do you mean 0 in stead of 4?
                                @CoopDog1712 whatever the number is . it was 4…
                                or use the name
                                MagicMirror
                                whatever shows in
                                pm2 status
                                    @CoopDog1712 come on man…
                                    pm2 status
                                    whatever the number is or use the NAME of the entry instead of the number
                                      @sdetweil that worked, thank you so much!!! just a few more questons, do you know how to flip the magic mirror the other way?
                                      S AssassinsA 2 Replies Last reply Reply Quote 0
                                        @CoopDog1712 u mean from left right to up down?
                                        in the latest PI OS,
                                        desktop
                                        top left menu
                                        preferences
                                        screen configuration
                                        pick left/right/invert
                                        • AssassinsA Offline
                                          Assassins @CoopDog1712
                                          @CoopDog1712 Look with Rotating the Screen from Desktop : Rotate Screen
