    Magic mirror is not showing up
    37 Posts 4 Posters 16.7k Views 4 Watching
      CoopDog1712 @sdetweil
      @sdetweil no its a pi 4
        @sdetweil so it works now, and after i enter pm2 start MagicMirror, it loads the software for the magic mirror, the only issue is that their is nothing only a blank screen, no time, weather, nothing. all that comes up is a blank screen. any suggestions?
          sdetweil @CoopDog1712
          @CoopDog1712 have u added modules?
          if so see
          and
          pm2 logs --lines=50
          will show you what is happening
            @sdetweil i did what you said and this is what came up.
            pi@raspberrypi:~/MagicMirror/modules/default/clock $ npm init -y
            Wrote to /home/pi/MagicMirror/modules/default/clock/package.json:
            “name”: “clock”,
            “version”: “1.0.0”,
            “description”: “The clock module is one of the default modules of the MagicMirror². This module displays the current date and time. The information will be updated realtime.”,
            “main”: “clock.js”,
            “scripts”: {
            “test”: “echo "Error: no test specified" && exit 1”
            “keywords”: [],
            “author”: “”,
            “license”: “ISC”
            pi@raspberrypi:~/MagicMirror/modules/default/clock $ npm install ???
            npm ERR! code EINVALIDTAGNAME
            npm ERR! Invalid tag name “???”: Tags may not have any characters that encodeURIComponent encodes.
            npm ERR! /home/pi/.npm/_logs/2022-04-24T14_06_36_382Z-debug-0.log
            pi@raspberrypi:~/MagicMirror/modules/default/clock $ pm2 start MagicMirror
            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 4 ])
            [PM2] MagicMirror ✓
            [PM2] Process successfully started
              @CoopDog1712 no… not in clock module… we ship that
              what was the black screen failure message from the console output?
              you read the messages and get the name of the missing library, and replace the ??? with that name
              the reason YOU have to read the messages is because there are multiple libraries missing…
              you only need to fix the ones that impact the modules you installed
                @sdetweil i dont think i saw one. i never installed any modulles, even the ones that should come with it are not showing up
                  @CoopDog1712 ok, still show the messages where u start mm
                  either via
                  npm start
                  or
                  pm2
                  if pm2., then
                  pm2 logs --lines=50
                  will show the console output
                  what pi is this?
                  C 2 Replies Last reply Reply Quote 0
                    @sdetweil pi 4
                        @CoopDog1712 ah yes, fun times…
                        do
                        pm2 stop all
                        npm install electron@17.2.0
                        npm start
                        mm should come up
                        minimize mm (alt-spacebar, n)
                        ctrl-c to stop running instance
                        then
                        pm2 status
                        this will show the status or pm2 managed apps.
                        │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                        │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.7mb    │
                        use the name or the row number
                        pm2 start xxx
                        xxx is the name or the row number
                        for example
                        pm2 start 0
                          @sdetweil after i installed electron@17.2.0 then started it, this came up 2022-04-24-084424_1920x1080_scrot.png
                          then i did start pm2 start 4, and it started, but was still a blank screen
                            @CoopDog1712 says something is still running…
                            you didn’t do pm2 stop all
                            after doing test
                            ps -ef | grep -i magicmirror
                            should return nothing
                              @sdetweil whoops…
                              ok is did pm2 stop all and then entered that line of code you gave me and got this 2022-04-24-084933_1920x1080_scrot.png
                                @CoopDog1712
                                ok do
                                we will delete 1 entry so you don’t have 2 trying to run at the same time
                                and then reboot
                                pm2 delete  1
                                pm2 save
                                sudo reboot
                                  @sdetweil k i rebooted, then i started it up. nothing came up, still a blank screen so i did pm2 stop all and then did pm2 logs --lines=50 and these came up2022-04-24-090948_1920x1080_scrot.png
                                    @CoopDog1712
                                    pm2 status again
                                    also, how did you install mm? manual or my automated script?
                                    did you setup MM autostart before adding pm2?
                                      @sdetweil i installed it manually, and no it didnt
                                        @CoopDog1712 what is the output of pm2 status?
                                            @CoopDog1712 ok, pm2 flush
                                            then
                                            npm start
