    Magic mirror is not showing up
    37 Posts 4 Posters 18.2k Views 4 Watching
      CoopDog1712 @sdetweil
      @sdetweil whoops…
      ok is did pm2 stop all and then entered that line of code you gave me and got this 2022-04-24-084933_1920x1080_scrot.png
        sdetweil @CoopDog1712
        @CoopDog1712
        ok do
        we will delete 1 entry so you don’t have 2 trying to run at the same time
        and then reboot
        pm2 delete  1
        pm2 save
        sudo reboot
        C 1 Reply Last reply
          @sdetweil k i rebooted, then i started it up. nothing came up, still a blank screen so i did pm2 stop all and then did pm2 logs --lines=50 and these came up2022-04-24-090948_1920x1080_scrot.png
            @CoopDog1712
            pm2 status again
            also, how did you install mm? manual or my automated script?
            did you setup MM autostart before adding pm2?
            ps -ef | grep -i magicmirror
              @sdetweil i installed it manually, and no it didnt
                @CoopDog1712 what is the output of pm2 status?
                    @CoopDog1712 ok, pm2 flush
                    then
                    npm start
                      @sdetweil k i did that and it was still a blank screen, so i stoped it and did pm2 logs --lines=50 and got this 2022-04-24-091953_1920x1080_scrot.png
                      also would it be worth a try to just completely delete everything and then start from scratch?
                        @CoopDog1712 yeh, I don’t know whats going on
                        do
                        pm2 delete 4
                        pm2 save -f
                        rm -rf MagicMirror
                        then run my install script
                        see
                        it will prompt if u want pm2 again
                        and for turn off screen saver
                        does everything
                        C 3 Replies Last reply
                          @sdetweil do you mean 0 in stead of 4?
                            @CoopDog1712 whatever the number is . it was 4…
                            or use the name
                            MagicMirror
                            whatever shows in
                            pm2 status
                                @CoopDog1712 come on man…
                                pm2 status
                                whatever the number is or use the NAME of the entry instead of the number
                                  @sdetweil that worked, thank you so much!!! just a few more questons, do you know how to flip the magic mirror the other way?
                                  S AssassinsA 2 Replies Last reply
                                    @CoopDog1712 u mean from left right to up down?
                                    in the latest PI OS,
                                    desktop
                                    top left menu
                                    preferences
                                    screen configuration
                                    pick left/right/invert
                                    • AssassinsA
                                      Assassins @CoopDog1712
                                      @CoopDog1712 Look with Rotating the Screen from Desktop : Rotate Screen
