    Magic mirror is not showing up
    37 Posts 4 Posters 15.3k Views 4 Watching
      CoopDog1712 @sdetweil
      @sdetweil i did what you said and this is what came up.
      pi@raspberrypi:~/MagicMirror/modules/default/clock $ npm init -y
      Wrote to /home/pi/MagicMirror/modules/default/clock/package.json:
      “name”: “clock”,
      “version”: “1.0.0”,
      “description”: “The clock module is one of the default modules of the MagicMirror². This module displays the current date and time. The information will be updated realtime.”,
      “main”: “clock.js”,
      “scripts”: {
      “test”: “echo "Error: no test specified" && exit 1”
      “keywords”: [],
      “author”: “”,
      “license”: “ISC”
      pi@raspberrypi:~/MagicMirror/modules/default/clock $ npm install ???
      npm ERR! code EINVALIDTAGNAME
      npm ERR! Invalid tag name “???”: Tags may not have any characters that encodeURIComponent encodes.
      npm ERR! /home/pi/.npm/_logs/2022-04-24T14_06_36_382Z-debug-0.log
      pi@raspberrypi:~/MagicMirror/modules/default/clock $ pm2 start MagicMirror
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 4 ])
      [PM2] MagicMirror ✓
      [PM2] Process successfully started
        sdetweil @CoopDog1712
        @CoopDog1712 no… not in clock module… we ship that
        what was the black screen failure message from the console output?
        you read the messages and get the name of the missing library, and replace the ??? with that name
        the reason YOU have to read the messages is because there are multiple libraries missing…
        you only need to fix the ones that impact the modules you installed
          @sdetweil i dont think i saw one. i never installed any modulles, even the ones that should come with it are not showing up
            @CoopDog1712 ok, still show the messages where u start mm
            either via
            npm start
            or
            pm2
            if pm2., then
            pm2 logs --lines=50
            will show the console output
            what pi is this?
            C 2 Replies Last reply Reply Quote 0
              @sdetweil pi 4
                  @CoopDog1712 ah yes, fun times…
                  do
                  pm2 stop all
                  npm install electron@17.2.0
                  npm start
                  mm should come up
                  minimize mm (alt-spacebar, n)
                  ctrl-c to stop running instance
                  then
                  pm2 status
                  this will show the status or pm2 managed apps.
                  │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                  │ 0  │ MagicMirror        │ fork     │ 0    │ online    │ 0%       │ 2.7mb    │
                  use the name or the row number
                  pm2 start xxx
                  xxx is the name or the row number
                  for example
                  pm2 start 0
                    @sdetweil after i installed electron@17.2.0 then started it, this came up 2022-04-24-084424_1920x1080_scrot.png
                    then i did start pm2 start 4, and it started, but was still a blank screen
                      @CoopDog1712 says something is still running…
                      you didn’t do pm2 stop all
                      after doing test
                      ps -ef | grep -i magicmirror
                      should return nothing
                        @sdetweil whoops…
                        ok is did pm2 stop all and then entered that line of code you gave me and got this 2022-04-24-084933_1920x1080_scrot.png
                          @CoopDog1712
                          ok do
                          we will delete 1 entry so you don’t have 2 trying to run at the same time
                          and then reboot
                          pm2 delete  1
                          pm2 save
                          sudo reboot
                            @sdetweil k i rebooted, then i started it up. nothing came up, still a blank screen so i did pm2 stop all and then did pm2 logs --lines=50 and these came up2022-04-24-090948_1920x1080_scrot.png
                              @CoopDog1712
                              pm2 status again
                              also, how did you install mm? manual or my automated script?
                              did you setup MM autostart before adding pm2?
                                @sdetweil i installed it manually, and no it didnt
                                  @CoopDog1712 what is the output of pm2 status?
                                      @CoopDog1712 ok, pm2 flush
                                      then
                                      npm start
                                        @sdetweil k i did that and it was still a blank screen, so i stoped it and did pm2 logs --lines=50 and got this 2022-04-24-091953_1920x1080_scrot.png
                                        also would it be worth a try to just completely delete everything and then start from scratch?
                                          @CoopDog1712 yeh, I don’t know whats going on
                                          do
                                          pm2 delete 4
                                          pm2 save -f
                                          rm -rf MagicMirror
                                          then run my install script
                                          see
                                          it will prompt if u want pm2 again
                                          and for turn off screen saver
                                          does everything
                                          C 3 Replies Last reply Reply Quote 0
                                            @sdetweil do you mean 0 in stead of 4?
