Unsolved Problem with Google generated .ics link
@sdetweil Sent another email. Do you want copy of log files referenced in terminal
@ankonaskiff17 Also, this laptop of mine keeps dropping its wifi connection so bear that in mind, generally momentary but aggravating.
@ankonaskiff17 i think this dropping is power control…
there is a commandline to turn power control for wifi off
I have the same problem on a pi 0 2 w (one of 3)
@sdetweil Every device in home is fine but laptop.
2nd HP I’ve had this happen to. -
@ankonaskiff17 I’m using VNC to access Pi. It’s just chugging along no wifi issues whatsoever
@ankonaskiff17 My mistake starting over fresh
@ankonaskiff17 I rebooted pi, MM launched did pm2 stop all,
got back to MM directory and did npm start and that is ugly. Line after line of the word NULL, then a mish mash of garbage tthen saw VEVENT related to holiday calendar but MM crashed in among all that. -
@ankonaskiff17 @sdetweil check email for sample
ull,null,null,null,null,null,null,null,null,null,null,null]
[24.04.2022 21:25.05.341] [DEBUG] event.recurrences: undefined
[24.04.2022 21:25.05.359] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/c/basic.ics RangeError: Invalid time value
at Date.toISOString ()
at /home/pi/MagicMirror/modules/default/calendar/calendarutils.js:314:28
at Array.forEach ()
at Object.filterEvents (/home/pi/MagicMirror/modules/default/calendar/calendarutils.js:142:24)
at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:74:29
at processTicksAndRejections (node:internal/process/task_queues:96:5) -
@ankonaskiff17 i replied to email
