Unsolved Problem with Google generated .ics link
@ankonaskiff17 ok, we need to see which one is causing the problem… so edit config.js and change loglevel like this
logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"], // Add "DEBUG" for even more logging
then run MM like this
cd ~/MagicMirror npm start >somefile.txt
wait for cal to come up
ctrl-c to end MM
then examine someflle.txt
u may need to send me the file
same userid at gmail. I don’t share
my event looks like this
BEGIN:VEVENT DTSTART:20220126T150000Z DTEND:20220126T210000Z DTSTAMP:20220425T000759Z UID:6oq3edpnc9ijeb9nc9h30b9k6tj3ibb2c5j3eb9k75hj6opk6dhjce32cg@google.com CREATED:20220111T023256Z DESCRIPTION: LAST-MODIFIED:20220111T023256Z LOCATION: SEQUENCE:0 STATUS:CONFIRMED SUMMARY:drive to ft stockton TRANSP:OPAQUE END:VEVENT
@sdetweil Check your email
@ankonaskiff17 replied
@sdetweil Sent another email. Do you want copy of log files referenced in terminal
@ankonaskiff17 Also, this laptop of mine keeps dropping its wifi connection so bear that in mind, generally momentary but aggravating.
@ankonaskiff17 i think this dropping is power control…
there is a commandline to turn power control for wifi off
I have the same problem on a pi 0 2 w (one of 3)
@sdetweil Every device in home is fine but laptop.
2nd HP I’ve had this happen to. -
@ankonaskiff17 I’m using VNC to access Pi. It’s just chugging along no wifi issues whatsoever
@ankonaskiff17 My mistake starting over fresh
