    MMM-CalendarExt3
    679 Posts 82 Posters 2.8m Views 86 Watching
    • luisestradaL Offline
      luisestrada @MMRIZE
      @MMRIZE It took me a while to understand how to show the calendar module without the events module, it was just by not adding the position and worked like a charm :)
      Thank you :), great module
      luisestradaL 1 Reply Last reply Reply Quote 0
      • H Offline
        hrmax
        Great work @MMRIZE ! I like how this calendar looks much better.
        I am having an issue with the eventTransformer though. I can’t seem to get it to update any of the event properties.
        Is it possible to use the same symbols/icons as set in the calendar module?
        • H Offline
          hrmax @hrmax
             module: "MMM-CalendarExt3",
             position: "bottom_center",
             title: "",
               mode: "month",
               instanceId: "basicCalendar",
               minimalDaysOfNewYear: 1,
               maxEventLines: 5,
               firstDayOfWeek: 0,
               eventFilter: (ev) => {
                 if (ev.title.isFullday) return false
                 return true
               eventTransformer: (ev) => {
                   if (ev.title.search('a') > -1)  ev.title = 'test'
                   return event
            MMRIZE @hrmax
            @hrmax
            First, Thanks for the feedback. I found there was some mistype in code. I fixed it, so update with git pull.
            Second, for eventFilter
              if (ev.isFullday) return false
              return true
            Third, for eventTransformer and symbol example.
              ev.title = `<i class="fa fa-${ev.symbol}"></i>${ev.title}`
              return ev
            Result;
            • H Offline
              hrmax @MMRIZE
              @MMRIZE This was super helpful, thank you! It resolved the issues I was having.
              I ended up modifying MMM-CalendarExt3.js so that I could better control the time format. Since I’m using this in portrait mode, I don’t much space so for time values I wanted
              4:00 PM -> 4
              5:30 PM -> 5:30
                MMRIZE @hrmax
                @hrmax
                You can adjust eventTimeOptions to format the time or date of the event.
                But not by condition.
                eventTimeOptions: {
                  hour: "numeric",
                will show only hour like 4
                or
                eventTimeOptions: {
                  hour: "numeric",
                  minute : "2-digit"
                will show the hour and minute like 4:05
                or
                eventTimeOptions: {
                  timeStyle: "short"
                will show standard locale format like 4:05 am. (It depends on which locale is applied.)
                But not conditionally. (4 or 4:05 by condition)
                One possible idea is;
                Hide the real time parts with CSS, then transform event title to include time;
                /* In your custom.css */
                .CX3 .myTime {
                  font-size: 80%;
                  color: #999;
                  font-weight: normal;
                .CX3 .event:not(.fullday) .eventTime {
                  display: none;
                /* In your config */
                  if (!ev.isFullday) {
                    let t = new Date(ev.startDate)
                    let time = (t.getMinutes() === 0) ? String(t.getHours()) : String(t.getHours() + ':' + t.getMinutes())
                    ev.title = `<span class="myTime">${time}</span> ${ev.title}`
                  return ev
                The result will be;
                H W D 3 Replies Last reply Reply Quote 0
                • H Offline
                  hrmax23 @MMRIZE
                  @MMRIZE
                  This is a much more elegant solution than what I came up with. Many thanks!
                  • AssassinsA Offline
                    Assassins
                    Will it be possible to pull out the birthday that is associated with a contact person from icloud. ???
                      luisestrada @luisestrada
                      @MMRIZE , just a note. I also use the browser to open the mirror and works in all platforms I’ve tested except one, Tizen browser (Samsung TVs). All modules work but this, no idea what happens but probably any form of javascript may not be supported by Tizen.
                      I’m quite happy with the module though
                        MMRIZE @Assassins
                        @Assassins
                        Will it be possible to pull out the birthday that is associated with a contact person from cloud. ???
                        AFAIK, impossible (at least, no automatic way);
                        First; This module is not for parsing calendar events but for showing events already parsed. It means other ics format parser (like the original default calendar module) has to do that work.
                        Second, The birthday calendar of iCloud contacts is not a general calendar which could be sharable. If you want to export the contact birthday to any normal calendar; export the contacts as VCONTACT(.vcf) format, then convert it to VEVENT(.ics) then import them to your target calendar. But I’m not sure there is any convenient converter for this job.
                        • 67
                        • 68
                        • 1 / 68
