MMM-CalendarExt3
666 Posts 79 Posters 2.1m Views 83 Watching
    MMRIZE
    MMM-CalendarExt3
    New MagicMirror module for calendar view. (successor of MMM-CalendarExt2)
    Screenshot
    screenshot
    Concept
    My previous module, MMM-CalendarExt2, was always notorious for its difficulty to use. I need a more easy and light one. So I rewrite this from scratch newly.
    Features
    What’s different with CX2.
    • Only focusing on how it shows; Parsing is delegated to original MagicMirror module calendar. (It means the calendar module is REQUIRED to use this module.)
    • Only week and month views. I found that people are rarely interested in other views on CX2. So I drop out different views.
    • Respect to original MM’s hide/show mechanism. Now you can hide/show this module easily with other scheduler or control modules. (By the way, Look at this module also. - MMM-Scenes)
    • No dependency on the 3rd party modules (e.g. momentJS or Luxon, etc.). This is built with pure JS and CSS only.
    Main Features
    • week view or month view
    • locale-aware calendar
    • customizing events: filtering, sorting, transforming
    • multi-instance available. You don’t need to copy and rename the module. Just add one more configuration in your config.js.
    DETAILS : https://github.com/MMRIZE/MMM-CalendarExt3
    L B D B N 5 Replies Last reply Apr 25, 2022, 9:28 PM Reply Quote 3
    • L Offline
      luisestrada @MMRIZE
      @MMRIZE It took me a while to understand how to show the calendar module without the events module, it was just by not adding the position and worked like a charm :)
      Thank you :), great module
      L 1 Reply Last reply Apr 29, 2022, 12:23 AM Reply Quote 0
      • H Offline
        hrmax
        Great work @MMRIZE ! I like how this calendar looks much better.
        I am having an issue with the eventTransformer though. I can’t seem to get it to update any of the event properties.
        Is it possible to use the same symbols/icons as set in the calendar module?
        H 1 Reply Last reply Apr 27, 2022, 5:29 AM Reply Quote 0
        • H Offline
          hrmax @hrmax
             module: "MMM-CalendarExt3",
             position: "bottom_center",
             title: "",
               mode: "month",
               instanceId: "basicCalendar",
               minimalDaysOfNewYear: 1,
               maxEventLines: 5,
               firstDayOfWeek: 0,
               eventFilter: (ev) => {
                 if (ev.title.isFullday) return false
                 return true
               eventTransformer: (ev) => {
                   if (ev.title.search('a') > -1)  ev.title = 'test'
                   return event
          M 1 Reply Last reply Apr 27, 2022, 6:51 AM Reply Quote 0
            MMRIZE @hrmax
            @hrmax
            First, Thanks for the feedback. I found there was some mistype in code. I fixed it, so update with git pull.
            Second, for eventFilter
              if (ev.isFullday) return false
              return true
            Third, for eventTransformer and symbol example.
              ev.title = `<i class="fa fa-${ev.symbol}"></i>${ev.title}`
              return ev
            Result;
            H 1 Reply Last reply Apr 28, 2022, 3:49 AM Reply Quote 0
            • H Offline
              hrmax @MMRIZE
              @MMRIZE This was super helpful, thank you! It resolved the issues I was having.
              I ended up modifying MMM-CalendarExt3.js so that I could better control the time format. Since I’m using this in portrait mode, I don’t much space so for time values I wanted
              4:00 PM -> 4
              5:30 PM -> 5:30
              M 1 Reply Last reply Apr 28, 2022, 9:01 AM Reply Quote 0
                MMRIZE @hrmax
                @hrmax
                You can adjust eventTimeOptions to format the time or date of the event.
                But not by condition.
                eventTimeOptions: {
                  hour: "numeric",
                will show only hour like 4
                or
                eventTimeOptions: {
                  hour: "numeric",
                  minute : "2-digit"
                will show the hour and minute like 4:05
                or
                eventTimeOptions: {
                  timeStyle: "short"
                will show standard locale format like 4:05 am. (It depends on which locale is applied.)
                But not conditionally. (4 or 4:05 by condition)
                One possible idea is;
                Hide the real time parts with CSS, then transform event title to include time;
                /* In your custom.css */
                .CX3 .myTime {
                  font-size: 80%;
                  color: #999;
                  font-weight: normal;
                .CX3 .event:not(.fullday) .eventTime {
                  display: none;
                /* In your config */
                  if (!ev.isFullday) {
                    let t = new Date(ev.startDate)
                    let time = (t.getMinutes() === 0) ? String(t.getHours()) : String(t.getHours() + ':' + t.getMinutes())
                    ev.title = `<span class="myTime">${time}</span> ${ev.title}`
                  return ev
                The result will be;
                H W D 3 Replies Last reply Apr 28, 2022, 3:12 PM Reply Quote 0
                • H Offline
                  hrmax23 @MMRIZE
                  @MMRIZE
                  This is a much more elegant solution than what I came up with. Many thanks!
                    Assassins
                    Will it be possible to pull out the birthday that is associated with a contact person from icloud. ???
                    M 1 Reply Last reply Apr 29, 2022, 7:43 AM Reply Quote 0
                    • L Offline
                      luisestrada @luisestrada
                      @MMRIZE , just a note. I also use the browser to open the mirror and works in all platforms I’ve tested except one, Tizen browser (Samsung TVs). All modules work but this, no idea what happens but probably any form of javascript may not be supported by Tizen.
                      I’m quite happy with the module though
                      M 1 Reply Last reply Apr 29, 2022, 7:50 AM Reply Quote 0
                      • 66
                      • 67
                      • 1 / 67
                      1 / 67
