    A module like WB-Weather with support for other weather APIs such as BOM.
    9 Posts 4 Posters 1.9k Views 4 Watching
    • U Offline
      Uskompuf
      I recently saw the amazing weather plugin WB-Weather but its hard coded to use DarkSky I was wondering if anyone would be interested in adding support for other weather APIs such as BOM?
      • N Offline
        Nalmo @Uskompuf
        @Uskompuf
        I found this but am having trouble configuring it as documentation of options is missing.
        https://github.com/frebbles/MMM-bomweather
        All I get is the location name with a line under it.
        Would appreciate any help.
        Alan
          sdetweil @Nalmo
          @Nalmo if u look at the code, it’s looking for your state abbreviation, config option locationState
            sdetweil @Nalmo
            @Nalmo also, in the place u start MagicMirror, via npm start or pm2, there will be messages output by the modules node_helper (which gets the data)
            if using pm2, then the command
            pm2 logs --lines=50
            will output the last 50 lines of messages saved
            • N Offline
              Nalmo @sdetweil
              Thanks for a quick response.
              I have not configured any options for bomweather in config.js other than location and locationState
              The log file shows it fetched the correct URL; next line says “BomForecast Forecast received”
              MM is showing the (correct) location (“Melbourne”) with a line under it, but not the forecast.
              When I set radarImage to true, I get a small square under the line.
              Can you advise what the configuration options are for this module. I have looked through the bomweather.js file but am not sure what the config options are (still a bit of a noob at this).
              • N Offline
                Nalmo @Nalmo
                • N Offline
                  Nalmo @Nalmo
                    sdetweil @Nalmo
                    @Nalmo sorry I don’t know anything about the module itself.
                    in the modulename.js is a define for defaults:{}
                    all of those are config options. sometimes modules don’t list a config option for various reasons…
                    so I look thru the code for .config. to find them
                    and the node_helper.js too…
                    • N Offline
                      Nalmo @sdetweil
                      Finally got the 7 day forecast showing with this modification from @anobleperson
                      https://github.com/frebbles/MMM-bomweather/compare/main...anobleperson:bugfix/header-update
