    A module like WB-Weather with support for other weather APIs such as BOM.
    9 Posts 4 Posters 2.2k Views 4 Watching
      sdetweil @Nalmo
      @Nalmo also, in the place u start MagicMirror, via npm start or pm2, there will be messages output by the modules node_helper (which gets the data)
      if using pm2, then the command
      pm2 logs --lines=50
      will output the last 50 lines of messages saved
      • N Offline
        Nalmo @sdetweil
        Thanks for a quick response.
        I have not configured any options for bomweather in config.js other than location and locationState
        The log file shows it fetched the correct URL; next line says “BomForecast Forecast received”
        MM is showing the (correct) location (“Melbourne”) with a line under it, but not the forecast.
        When I set radarImage to true, I get a small square under the line.
        Can you advise what the configuration options are for this module. I have looked through the bomweather.js file but am not sure what the config options are (still a bit of a noob at this).
        • N Offline
          Nalmo @Nalmo
          • N Offline
            Nalmo @Nalmo
              sdetweil @Nalmo
              @Nalmo sorry I don’t know anything about the module itself.
              in the modulename.js is a define for defaults:{}
              all of those are config options. sometimes modules don’t list a config option for various reasons…
              so I look thru the code for .config. to find them
              and the node_helper.js too…
              • N Offline
                Nalmo @sdetweil
                Finally got the 7 day forecast showing with this modification from @anobleperson
                https://github.com/frebbles/MMM-bomweather/compare/main...anobleperson:bugfix/header-update
