Solved Update script not updating
@ankonaskiff17 and the upgrade ONLY works if the mm versions are different
if u are on 2.19, and current is 2.19, then nothing to do. you can ‘force’ it do do the apply, by using force as the parm instead of apply. this was added for the case where someone started a manual upgrade, but got stuck…
but again, the script does not upgrade modules.
@sdetweil First thing I did with the MMM-Jast notification was to look if there was a section in the Readme about updating module but I think it was triggered externally.
On Github the dates are older but there is this at very top, How do I address that?
@ankonaskiff17 so in general, modules update with
cd ~/MagicMirror/modules/module_folder git pull
and if the module has a package.json, then
npm install
also in the module folder
@sdetweil I found a different module with update instructions and did
git pull
in MMM-Jast butgit pull
yielded the followingFrom https://github.com/jalibu/MMM-Jast
5a5f781..8b771b6 main -> origin/main
* [new tag] v2.6.3 -> v2.6.3
Updating 5a5f781..8b771b6
error: Your local changes to the following files would be overwritten by merge:
package-lock.json
Please commit your changes or stash them before you merge.
Aborting
pi@mirror:~/MagicMirror/modules/MMM-Jast $
@ankonaskiff17 yeh, erase package-lock.json
then git pull, npm install will update that file again -
@sdetweil That is standard/typical of how to update a module?
Resolved notification
@ankonaskiff17 yes… no one should ship a package-lock.json as part of their release
this is only used by testing systems to make sure the environment is exact
@sdetweil actually the opposite is true, everyone should ship a lock file with its repository to ensure you will get the exact same dependencies that were tested with and not something newer which can introduce issues.
But if you just run
npm install
npm will update the lock file. So the effect is like not shipping a lock file at all.Instead, you should use
npm ci
if there is a lock file https://docs.npmjs.com/cli/v8/commands/npm-ci. This makes sure that you have exactly the same dependencies no matter if there is a newer version available. -
@strawberry-3-141 however. not everyone runs the same platform as used during test, so all the parts change.
@sdetweil the hardware might be different but at least the code and dependencies are the same which increases the chances to reproduce and fix the issue
