RPi 3B+ with 'Bullseye' can't rotate screen?
I have a RPi 3B+ with Buster on it, and it works ok, though I canât have screencast and remote installed at the same time. So I wanted to make a new install, and I downloaded the RaspberryOS Bullseye 32bit.
With that I can run the two modules together, but now I canât rotate the screen to portrait.
The old version was just a question of adding display_hdmi_rotate=1 to the /boot/config.txt, but this doesnât work with bullseye.
So how do I rotate the screen on the Bullseye?
I tried doing it from inside âXâ by using the Screen Configuration app, but when I do that (rotation=left), the screen goes black, and nothing happens, I canât press the âverifyâ button, so if I reboot it, it is still in landscape mode.
What can I do? -
@fribse on my pi4 w bullets I see this config setting app
left menu, preferences, screen configuration
configure menu
@sdetweil Iâve never seen that on a 3, FWIW.
@fribse I do not know. maybe a bad HDMI cable or a bad adapter if using HDMI to DVI, or a bad monitor?
all my monitors and TVâs work in any orientation.
@fribse and is work on rpi3 to đ
@fribse I donât actually have a 3 with Bullseye, however, My next step would be to try the other GL drivers through
raspiconfig. -
@sdetweil That would be odd, as it works with previous versions of Raspberry Pi OS?
@BKeyport That is worth a try, didnât think of that!
@fribse Hmm, canât make this work. I can get it to work on a RPi4, but not on a RPi3 with the âScreenconfigurationâ app.
Itâs really annoying, I would like to have screencast and remote-control modules enabled, so that Home Assistant can integrate to it, through the remote-control module, but that doesnât work on Buster (the integration fails to set up), it fails because of some weird problem in the integration combined with the screencast, which the author canât reproduce, which is very odd, as I can show it every time.
I can get the integration to work on Bullseye together with the remote-control module and the screencast, but not on a RPi3, only on a RPi4, and even rotate the screen, but I donât want to place a very hot and overly powerfull RPi4 behind the magicmirror.
Damned if I do, and damned if I donât.
@fribse Ok, so now Iâve gotten a second RPi3b+. Apparently the monitor doesnât like the way that Bullseye rotate the screen (by using the âScreen orientationâ in the GUI).
So how do I rotate the screen in âthe old wayâ which works fine on the monitor.
My guess is that itâs modifying the refresh rate beyond the capabilities of the monitor.
Itâs usually running on 60Hz, and I tried changing it to 50Hz, but that didnât change anything.So what do I do now? I would really like to use the bullseye, as I canât get Home Assistant to control the mirror if I have screencast installed on the mirror under Buster.
@fribse I use a RPi3 B+ and Bullseye and I do the rotate in the boot/config.txt and it works ok for me.
I have no solution for your problem but if you use the WebUI to change screen settings in bullseye the changes are made here:
pi@pi4:~ $ cat /usr/share/dispsetup.sh #!/bin/sh if ! grep -q 'Raspberry Pi' /proc/device-tree/model || (grep -q okay /proc/device-tree/soc/v3d@7ec00000/status 2> /dev/null || grep -q okay /proc/device-tree/soc/firmwarekms@7e600000/status 2> /dev/null || grep -q okay /proc/device-tree/v3dbus/v3d@7ec04000/status 2> /dev/null) ; then if xrandr --output HDMI-1 --primary --mode 1920x1080 --rate 60.000 --pos 0x0 --rotate normal --output HDMI-2 --off --dryrun ; then xrandr --output HDMI-1 --primary --mode 1920x1080 --rate 60.000 --pos 0x0 --rotate normal --output HDMI-2 --off fi fi if [ -e /usr/share/tssetup.sh ] ; then . /usr/share/tssetup.sh fi exit 0So you could play with the
xrandrcommand, may this helps ⌠-
@N6NG Ok, and what are you writing in the config for it to work? That would be a big help for me :-)
@fribse itâs not in the mirror config. you have to change the rasperrypiâs actual configuration
@kayakbabe Yes, Iâm referring to /boot/config.txt, not Magicmirror/config/config.yaml :-)
@fribse It is in the boot/config.txt file itself. Not in the MagicMirror/config/config.js file.
Just cd /boot and sudo nano config.txt and either find the display_rotate=0 and change it to display_rotate=1
or add the line display_rotate=1 I added it under the #config_hdmi_boost=4 line but I suspect you could add it just about anywhereâŚ
Dennis N6NG -
@karsten13 said in RPi 3B+ with 'Bullseye' can't rotate screen?:
The created file looks different in my case.
#!/bin/sh if ! raspi-config nonint is_pi || raspi-config nonint is_kms ; then if xrandr --output HDMI-1 --primary --mode 1920x1080 --rate 60.000 --pos 0x0 --rotate right --dryrun ; then xrandr --output HDMI-1 --primary --mode 1920x1080 --rate 60.000 --pos 0x0 --rotate right fi fi if [ -e /usr/share/tssetup.sh ] ; then . /usr/share/tssetup.sh fi if [ -e /usr/share/ovscsetup.sh ] ; then . /usr/share/ovscsetup.sh fi exit 0I configure my MM with ansible. All old settings via /boot/config.txt donât work anymore with my RPi3 B+ and Bullseye.
Using dispsetup.sh is the only working solution.I also had to set this in /boot/config.txt:
... # Enable DRM VC4 V3D driver #dtoverlay=vc4-kms-v3d ... [all] dtoverlay=vc4-fkms-v3d -
@doctore Ok, Iâll try to see if that works, thankyou!
K karsten13 referenced this topic on
With your input, this post could be even better đ
