    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • luisestradaL
      luisestrada
      @MMRIZE said in MMM-CalendarExt3:
      /* In your custom.css */
      .CX3 .cellDate .dateParts.literal {
      margin-left: 5px;
      Thank you so much, muchas gracias :)
        MMRIZE
        1.1.0 (2022-05-29)
        • ADDED : control interval of refreshing on fetching calendar
          • config option waitFetch for waiting for too frequent fetching.
          • config option refreshInterval for refresh view by force.
          • config option glanceTime for focusing temporal moment then returning to current moment
          • config option animationSpeed for update animation
        • ADDED : calendar symbol can be used. (config option useSymbole)
        • ADDED : weather forecast could be displayable. (From MM 2.20 released or MM 2.19 develop branch)
        • CHANGED : Now, month view could has a fit weeks by the days not fixed 6 weeks.
        1.1.0
        • A
          almightyyoshi
          Just a couple of quick questions. First, how do you remove icons from events? I see in the sample pics that it’s been done, but I can’t seem to make it happen. Second, in CalExt2, I could style event borders and would show/color those instead of having a completely filled in event color. I could also show only certain borders (for full day I only had the left and bottom, but single day events only had the left border). Is that possible with CalExt3?
            MMRIZE @almightyyoshi
            @almightyyoshi
            1. Not to use symbol: useSymbol: false
            // config of your module;
              useSymbol: false,
            1. Is this what you wanted?
            /* in your custom.css */
            .CX3 .event.fullday,
            .CX3 .event.multiday {
              border-left: 4px solid var(--calendarColor);
              border-bottom: 1px solid var(--calendarColor);
              background-color: rgba(0, 0, 0, 0.2);
            .CX3 .event.singleday {
              border-left:4px solid var(--calendarColor);
            .CX3 .event.singleday:not(.useSymbol)::before {
              content: '';
            • A
              almightyyoshi @MMRIZE
              @MMRIZE That’s perfect. Thanks. I just wasn’t sure if those attributes were available and I honestly just didn’t feel like experimenting at that moment. Last question (think): Is there a way to hide the default calendar module and still populate CX3. I found a way to hide the module (by editing the calendar module’s base config) on startup, but then CX3 doesn’t have any events. Here’s what I used (courtesy of @sdetweil from a thread a couple of years ago):
              hidden: false,
              suspend: function(){
                  this.hidden=true
              restore: function(){
                   this.hidden=false
              notificationReceived: function(notification, payload, source){
                 // this comes before the first call to getDom()
                 if(notification === "ALL_MODULES_STARTED")
                    this.hidden=true;
              getDom: function (){
              var wrapper=document.createElement('div')
              if(this.hidden==false){
                   //create normal content
              return wrapper;
                sdetweil @almightyyoshi
                @almightyyoshi I think you will have to use css to hide, vs code
                  @almightyyoshi
                  You can hide it with CSS, or just drop out “position”.
                  • A
                    @MMRIZE Dropping position worked. I thought I’d get an error or blank screen for that. Thanks again!
                    luisestradaL 1 Reply Last reply Reply Quote 0
                    • luisestradaL
                      luisestrada @almightyyoshi
                      @almightyyoshi Every time i think this is fixed then it comes back again…
                      I have 3 calendars so I renamed calendar1 and calendar2, as I don’t want these calendars to conflict with CX3.
                      Then I have my calendar module and dropped the position as I don’t want to show it.
                      My CX3 loads empty and after a while the information appears, then it goes and then it comes back. I think I have not set up properly the refresh. I’ve tried many combinations but nothing works
                      module: “MMM-CalendarExt3”,
                      position: “bottom_bar”,
                      title: “Calendario”,
                      waitFetch: 10000, // (ms) waiting the fetching of last calendar to prevent flickering view by too frequent fetching.
                      refreshInterval: 1000 * 60 * 1, // (ms) refresh view by force if you need it.
                      glanceTime: 1000 * 60 * 1, // (ms) Return to original view when you move to other moment by notification.
                      //animationSpeed: 2000, // (ms) Refreshing the view smoothly.
                      rotateInterval: 0,
                      eventTimeOptions: {
                      timeStyle: “short”
                      fetchInterval: 1000,
                      mode: “week”,
                      instanceId: “WeeklyCalendar”,
                      locale: ‘es-CO’,
                      maxEventLines: 3,
                      firstDayOfWeek: 0,
                      weekIndex: 0,
                      weeksInView: 4,
                      broadcastPastEvents: true, // <= IMPORTANT to see past events
                      calendarSet: [‘Cal1’, ‘Cal2’, ‘Cal3’, 'Cal4, ‘Cal5’],
                      And Go Jays Go!! :beaming_face_with_smiling_eyes:
                        sdetweil @luisestrada
                        @luisestrada do you have 3 instances of
                        module:‘calendar’
                        • luisestradaL
                          luisestrada @sdetweil
                          @sdetweil said in MMM-CalendarExt3:
                          module:‘calendar’
                          Yes, I have 3 modules, the holidays (shows 3), the birthday calendar (shows 2) and the normal calendar (shows 8).
                            @luisestrada each sends out its own list of entries. maybe calext3 is replacing a with b with c
                            • luisestradaL
                              That’s exactly what i thought, so thats why I created 3 different modules by copying the entire module in a separate folder and renaming it, similar to this: https://forum.magicmirror.builders/topic/14724/run-two-instances-of-the-same-module-sometimes-tutorial
                              but still, if I have 3 modules called, calendar, calendar1 and calendar2, it does it
                              M S 3 Replies Last reply Reply Quote 0
                                MMRIZE @luisestrada
                                @luisestrada
                                Well, I was worried about just that case when I developed this module - multiple calendar instances. I thought Nobody would use the calendar module like that. So I haven’t considered supporting that case. But I was wrong.
                                The current behaviour of this module is replacing whole events when the notification arrives, not combining each. So you cannot get proper whole events from multi-emitter of notifications.
                                I’ll modify the module in a few days to stack each event not replace it. Wait for a little.
                                  MMRIZE @luisestrada
                                  @luisestrada
                                  By the way, your configuration is not quite effective. Some options are located in the wrong place, some are invalid.
                                  • All module-specific user configuration should be placed in config: { ... }. Your waitFecth or eventTimeOptions and something more would not be applied.
                                  • there is no fetchInterval or rotateInterval option in CX3.
                                  • broadcastPastEvents is not for CX3 module but for calendar module.
                                  • refreshInterval: 1000 * 60 * 1 means redraw calendar every 1 minute. Is it really needed?
                                    @luisestrada the info inside(event broadcast) is still the same
                                    and u didn’t need to do the rename. it supports multiple instances
                                      sdetweil @MMRIZE
                                      @MMRIZE u can see in config if multiple instances and maybe the ‘from’ on notification
                                      • luisestradaL
                                        luisestrada @MMRIZE
                                        @luisestrada
                                        Thank you, I will show you my code so you all can understand the mess I did :beaming_face_with_smiling_eyes:
                                        @luisestrada
                                        It was supposed to be ten minutes but because I was trying and adding and testing, I forgot to change it back
                                        • luisestradaL
                                          All calendar were working under the same name, however i thought it was the cause of the blank CX3 so that’s why i tried to create one version for each module as a last resort
                                          • luisestradaL
                                            luisestrada
                                            My code with the changes based on your feedback (and it seems to be working for now) Thank you!
                                            //Calendar hidden Module
                                                        //position: "top_left",
                                                        header: "Eventos",
                                                            instanceId: "WeeklyCalendar",
        url: "URL1",
        name: "Cal1", // <= RECOMMENDED to assign name
        color: "#0760d1", // <= RECOMMENDED to assign color
        symbol: false
        url: "URL2",
        name: "Cal2", // <= RECOMMENDED to assign name
        color: "#2a4d56", // rgb(92%, 33%, 55%), // <= RECOMMENDED to assign color
        symbol: "birthday-cake"
        url: "URL3",
        name: "Cal3", // <= RECOMMENDED to assign name
        color: "#333", // rgb(92%, 33%, 55%), // <= RECOMMENDED to assign color
        symbol: "bank"
        url: "URL4",
        name: "Cal4", // <= RECOMMENDED to assign name
        color: "#3f0101", // <= RECOMMENDED to assign color
        symbol: "flag"
        url: "URL5",
        name: "Cal5, // <= RECOMMENDED to assign name
        color: "#765f02", //rgb(58%, 24%, 45%) // <= RECOMMENDED to assign color
        symbol: "flag"
                                            // CX3 Module
                                                        module: "MMM-CalendarExt3",
                                                        position: "bottom_bar",
                                                        title: "Calendario",
                                                            mode: "week",
                                                            locale: 'es-CO',
                                                            maxEventLines: 3,
                                                            firstDayOfWeek: 0,
                                                            weekIndex: 0,
                                                            weeksInView: 4,
                                                            waitFetch: 1000 * 10, //	(ms) waiting the fetching of last calendar to prevent flickering view by too frequent fetching.
                                                            refreshInterval: 1000 * 60 * 10, //	(ms) refresh view by force if you need it.
                                                            glanceTime: 1000 * 60 * 10,	// (ms) Return to original view when you move to other moment by notification.
                                                            eventTimeOptions: {
        timeStyle: "short"
                                                            //useSymbol: false,
                                                            calendarSet: ['Cal1', 'Cal2', 'Cal3', 'Cal4', 'Cal5'],
                                            Now these 3 calendars seem not to be conflicting with CX3
                                            			module: "calendar2",
                                            			header: "CAL2",
        url: "CAL2"
                                            				maximumEntries: "2",
                                                            wrapEvents: true
                                            			header: "CAL3",
        url: "CAL3"
                                            				maximumEntries: "3",
                                                            wrapEvents: true
                                            			header: "CAL",
        url: "CAL"
                                            				maximumEntries: "5",
                                                            wrapEvents: true
                                            Sorry for the long message
                                            • 34
                                            • 35
                                            • 2 / 35
