    MMM-Remote-Control after upd MM to 2.1.0
    14 Posts 6 Posters 11.6k Views 6 Watching
    • lolobyteL Offline
      lolobyte
      when i choose “edit modules” the MMM-Remote-Control does’t show any module.
      It mean there are no modules loaded. But more than 6 modules are running at the mirror.
      Any ideas?
      • schlachtkreuzer6S Offline
        schlachtkreuzer6
        did you update the dependencies?
        lolobyteL 1 Reply Last reply Reply Quote 0
        • SteffS Offline
          Steff
          Just did the update with git pull && npm install, I can report that at least my MMM-Remote-Control works exactly as beforehand, showing all modules.
          • lolobyteL Offline
            lolobyte @schlachtkreuzer6
            @schlachtkreuzer6
            I only made a
            git pull
            and the answer was.
            Already up-to-date.
            schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
              schlachtkreuzer6 @lolobyte
              @lolobyte git pull && npm install ?
              lolobyteL 2 Replies Last reply Reply Quote 0
              • lolobyteL Offline
                @schlachtkreuzer6
                i have now also done the npm install in the remote control folder…
                The issue remain.
                I’ll try a comlete new install of the module! :-(
                  @lolobyte nonono you need to npm install the hole thing ^^ wait take a look here: https://forum.magicmirror.builders/topic/1306/v2-1-x-updates
                  • lolobyteL Offline
                    @schlachtkreuzer6
                    The problem remains.
                    pm2 logs mm, doesn’t give me a real answer about the issue.
                      jean_pol56
                      I had the same problem.
                      I deleted the option: “disabled” (Set disabled to true to skip creating the module.) ) in my modules and everything works , MMM-Remote-Control show modules.
                      • lolobyteL Offline
                        lolobyte @jean_pol56
                        @jean_pol56
                        YES, damn, more than 2 hours wasted wit this issue.
                        If you un-comment the “disabled: true.” argument, your remote module won’t work correctly.
                        If you change the status from “true” to “false”, your remote module works again.
                                            module: 'helloworld',
                                            position: 'bottom_bar',
                                            classes: 'small bright', // Add your own styling. Optional.
                                    //      disabled: true, // verursacht Fehler in MMM-Remote-Control Modul
                                                    text: 'TEST TEST TEST!',
