MMM-Remote-Control after upd MM to 2.1.0
14 Posts 6 Posters 10.4k Views 6 Watching
  • L Offline
    lolobyte
    when i choose “edit modules” the MMM-Remote-Control does’t show any module.
    It mean there are no modules loaded. But more than 6 modules are running at the mirror.
    Any ideas?
      schlachtkreuzer6
      did you update the dependencies?
      L 1 Reply Last reply Jan 2, 2017, 5:51 PM Reply Quote 0
        Steff
        Just did the update with git pull && npm install, I can report that at least my MMM-Remote-Control works exactly as beforehand, showing all modules.
        • L Offline
          lolobyte @schlachtkreuzer6
          @schlachtkreuzer6
          I only made a
          git pull
          and the answer was.
          Already up-to-date.
          S 1 Reply Last reply Jan 2, 2017, 5:56 PM Reply Quote 0
            schlachtkreuzer6 @lolobyte
            @lolobyte git pull && npm install ?
            L 2 Replies Last reply Jan 2, 2017, 6:00 PM Reply Quote 0
            • L Offline
              @schlachtkreuzer6
              i have now also done the npm install in the remote control folder…
              The issue remain.
              I’ll try a comlete new install of the module! :-(
              S 1 Reply Last reply Jan 2, 2017, 6:04 PM Reply Quote 0
                @lolobyte nonono you need to npm install the hole thing ^^ wait take a look here: https://forum.magicmirror.builders/topic/1306/v2-1-x-updates
                • L Offline
                  @schlachtkreuzer6
                  The problem remains.
                  pm2 logs mm, doesn’t give me a real answer about the issue.
                    jean_pol56
                    I had the same problem.
                    I deleted the option: “disabled” (Set disabled to true to skip creating the module.) ) in my modules and everything works , MMM-Remote-Control show modules.
                    L 1 Reply Last reply Jan 2, 2017, 10:30 PM Reply Quote 0
                    • L Offline
                      lolobyte @jean_pol56
                      @jean_pol56
                      YES, damn, more than 2 hours wasted wit this issue.
                      If you un-comment the “disabled: true.” argument, your remote module won’t work correctly.
                      If you change the status from “true” to “false”, your remote module works again.
                                          module: 'helloworld',
                                          position: 'bottom_bar',
                                          classes: 'small bright', // Add your own styling. Optional.
                                  //      disabled: true, // verursacht Fehler in MMM-Remote-Control Modul
                                                  text: 'TEST TEST TEST!',
