    MMM-Remote-Control after upd MM to 2.1.0
    14 Posts 6 Posters 12.3k Views 6 Watching
      schlachtkreuzer6 @lolobyte
      @lolobyte git pull && npm install ?
      L 2 Replies Last reply
      • L
        lolobyte @schlachtkreuzer6
        @schlachtkreuzer6
        i have now also done the npm install in the remote control folder…
        The issue remain.
        I’ll try a comlete new install of the module! :-(
          @lolobyte nonono you need to npm install the hole thing ^^ wait take a look here: https://forum.magicmirror.builders/topic/1306/v2-1-x-updates
          • L
            @schlachtkreuzer6
            The problem remains.
            pm2 logs mm, doesn’t give me a real answer about the issue.
              jean_pol56
              I had the same problem.
              I deleted the option: “disabled” (Set disabled to true to skip creating the module.) ) in my modules and everything works , MMM-Remote-Control show modules.
              L 1 Reply Last reply
              • L
                lolobyte @jean_pol56
                @jean_pol56
                YES, damn, more than 2 hours wasted wit this issue.
                If you un-comment the “disabled: true.” argument, your remote module won’t work correctly.
                If you change the status from “true” to “false”, your remote module works again.
                                    module: 'helloworld',
                                    position: 'bottom_bar',
                                    classes: 'small bright', // Add your own styling. Optional.
                            //      disabled: true, // verursacht Fehler in MMM-Remote-Control Modul
                                            text: 'TEST TEST TEST!',
                • A
                  AAPS
                  Why is this necessary? Do I only need to do it for the “helloworld” module?
                  • L
                    lolobyte @AAPS
                    @AAPS
                    No, it’s surly only a example for one Module.
                    It was my intention with the command
                    disabled: true,
                    to quick disable a module in the config.js and not to comment out all single module step.
                    The problem with the remote module is, the modules aren’t really disabled, they running in the background an slow down the system.!
                      Jopyth Moderator
                      Does anyone know, what causes the problem? How do I reproduce the issue? Just a random config with one module disabled? If someone has a working small example (config), please post here or in the github issue.
                      I will see if I can fix it on the weekend.
                      • L
                        lolobyte @Jopyth
                        @Jopyth
                        This system doesen’t let me upload some file for you.
                        The this way.
                        Here is the sample config with issues.
                        /* Magic Mirror Config Sample
                        • MIT Licensed.
                        var config = {
                        port: 8080,
                        ipWhitelist: [
                        “127.0.0.1”,
                        “::ffff:127.0.0.1”,
                        “::1”,
                        “::ffff:192.168.1.1/24”,
                        language: ‘de’,
                        timeFormat: 24,
                        units: ‘metric’,
                        		module: 'alert',
                        		disabled: false,
                        		module: "updatenotification",
                        		position: "top_center",
                        		disabled: false,
                        		module: 'MMM-Advent',
                        		position: 'bottom_center',
                        		disabled: true,
                        			updateInterval: 10 * 60 * 1000,
                        			marks: 0, //default is 24
                        			height: 300,
                        			showFlameBeforeStart: false,
                        //			start: ["2016-11-27 00:00:01", "2016-12-11 00:00:01", "2016-12-18 00:00:01", "2016-12-04 00:00:01"],
                        //			end: ["2016-12-24 23:59:59", "2016-12-24 23:59:59", "2016-12-24 23:59:59", "2016-12-24 23:59:59"],
                        			start: "2016-01-01 00:00:01", //Geburtstag Anfang
                        			end: "2016-01-01 23:59:59", //Geburtstag Ende
                        //			start: "2016-12-01 00:00:01", //Eine Kerze; default is "2016-12-01 08:00:00"
                        //			end: "2016-12-24 23:59:59", //Eine Kerze; default is "2016-12-24 22:00:00"
                        			enableAnimation: true,
                        			fontColor: "#000000", //default is #000000 (black)
                        			candleColor: "#FFFFFF", //default is #FFFFFF (white)
                        		disabled: true,
                        			text: 'Alles Gute!',
                        		module: 'clock',
                        		position: 'top_left',
                        		disabled: false,
                        			displaySeconds: true,
                        			clockBold: false,
                        			showDate: true,
                        			displayType: 'digital', // Possible values: digital, analog, or both
                        			analogSize: '190px',
                        			analogFace: 'face-012', // 'simple' border, none, or face-### (value between 001 and 012)
                        			analogPlacement: 'right', // top, right, bottom, or left
                        			analogShowDate: 'top', // false, top or bottom
                        			secondsColor: '#888888', // any HTML RGB Color
                        	//		timezone: 'Etc/GMT+10', // America/New_York, America/Santiago, Etc/GMT+10
                        		module: 'MMM-Remote-Control',
                        		disabled: false,
                        	//	uncomment the following line to show the URL of the remote control on the mirror
                        		position: 'top_center'
                        	//	you can hide this module afterwards from the remote control itself
                        if (typeof module !== ‘undefined’) {module.exports = config;}
                        and this one wich is running.
                        • MIT Licensed.
                        var config = {
                        port: 8080,
                        ipWhitelist: [
                        “127.0.0.1”,
                        “::ffff:127.0.0.1”,
                        “::1”,
                        language: ‘de’,
                        timeFormat: 24,
                        units: ‘metric’,
                        		module: 'alert',
                        		disabled: false,
                        		disabled: false,
                        			height: 300,
                        		module: 'clock',
                        		disabled: false,
                        			clockBold: false,
                        			showDate: true,
                        		disabled: false,
                        [0_1483538699038_config.js.bak-abgespeckt_01](Uploading 100%)
                        [0_1483538731854_config.js.bak_abgespeckt_02](Uploading 100%)
