    MMM-RemoteControl or vcgencmd Issue
    16 Posts 7 Posters 10.5k Views 8 Watching
      Stroke 0
      I’m using a Raspberry Pi 4 Model B Rev 1.2 for my mirror. In attempting to shut off the hdmi to the mirror using both MMM-RemoteControl, or a bash file using vcgencmd display_power 0/1, the monitor turns back on within 12 seconds. Research indicates that it’s due to kernel control on the P1 4 model. Oddly, no one in the forum seems to be experiencing this. Any suggestions or tips that I can employ? Thank you.
      S O bdeelmanB 3 Replies Last reply Reply Quote 0
        sdetweil @Stroke 0
        @Stroke-0 my pi4 doesn’t have an issue
        off command is
        (sudo /usr/bin/vcgencmd display_power 0) >/dev/null
        on command is
        (sudo /usr/bin/vcgencmd display_power 1) >/dev/null
        commands issued over ssh
        • O
          OberfragGER @sdetweil
          • O
            OberfragGER @Stroke 0
            @Stroke-0 No Problems here. Im using MMM-RemoteControl and a PI4. I also use MMM-NewPir to turn the Monitor off.
            • bdeelmanB
              bdeelman @Stroke 0
              @Stroke-0
              A (or my) Rpi4 has two HDMI ports. So you should add also the HDMI port 0 or 1 (or id 2 and id 7). docs
              Status screen:
              vcgencmd display_power -1 2 | grep -q "1" && echo "on" || echo "off"
              vcgencmd display_power -1 7 | grep -q "1" && echo "on" || echo "off"
              Regards,
              Bert
                MiPraSo
                I had the same issue, I use MMM-PIR-Sensor-Lite to switch the monitor off and on again. On the command line “vcgencmd display_power 0” does not work, the return is always: “display_power=1”.
                I have tried a few things, they all did not work.
                Edit the “config.txt” in the “/boot” directory.
                Go to:
                “# Enable DRM VC4 V3D driver
                dtoverlay=vc4-kms-v3d
                max_framebuffers=2”
                And change “dtoverlay=vc4-kms-v3d” to “dtoverlay=vc4-fkms-v3d”.
                There is a bug in the “vc4-kms-v3d” driver.
                After changing in the “config.txt” “vcgencmd display_power 0” returns a “display_power=0”.
                MMM-PIR-Sensor-Lite now works as desired.
                S G M 3 Replies Last reply Reply Quote 1
                  Stroke 0 @MiPraSo
                  @MiPraSo Well done! Thank you. Your solution works perfectly. I do not understand why others are not experiencing the same issue however, they now have a solution. Thank you, again.
                    sdetweil @OberfragGER
                    @OberfragGER do you have it set for cec-client mode? it does all 4 approaches
                    • O
                      @sdetweil I dont have any proble with CEC e.g…? Or do you just mistakenly quotet me…?
                        @OberfragGER no, I was just asking how you used NEW-Pir
                        • O
                          @sdetweil I just use the Standard setting in my config.js.
                          Standard = use vgencmd
                          https://wiki.bugsounet.fr/en/EXT-Screen
                            @OberfragGER we have discovered that some pi firmware (updated under the covers by some kernel updates) causes the vcgencmd to not work,
                            https://forum.magicmirror.builders/topic/17185/pir-sensor-problem-after-restart-raspi/20?_=1663206370580
                            • G
                              grena Module Developer @MiPraSo
                              Ongoing fix! More information in my last post ;-)
                              • O
                                @sdetweil Thanks for your info.
                                I assume that i have an working firmware. I dont have any clue which version this is.
                                  @OberfragGER right, the latest update broken then command
                                  do this from a terminal window
                                  rpi-update b976c54917e240630c05a9b383010f1492bc61b4
                                    magmar @MiPraSo
                                    @MiPraSo Thank you! Worked like a charm :)
                                    To be allowed to save the config.txt-file, I had to edit it in administrator-mode (sudo nano config.txt). I also had to reboot the Pi after saving the file.
                                    • T thobach referenced this topic on
