    MMM-RemoteControl or vcgencmd Issue
    16 Posts 7 Posters 9.9k Views 8 Watching
      sdetweil @Stroke 0
      @Stroke-0 my pi4 doesn’t have an issue
      off command is
      (sudo /usr/bin/vcgencmd display_power 0) >/dev/null
      on command is
      (sudo /usr/bin/vcgencmd display_power 1) >/dev/null
      commands issued over ssh
      • O Offline
        OberfragGER @sdetweil
        • O Offline
          OberfragGER @Stroke 0
          @Stroke-0 No Problems here. Im using MMM-RemoteControl and a PI4. I also use MMM-NewPir to turn the Monitor off.
          • bdeelmanB Offline
            bdeelman @Stroke 0
            @Stroke-0
            A (or my) Rpi4 has two HDMI ports. So you should add also the HDMI port 0 or 1 (or id 2 and id 7). docs
            Status screen:
            vcgencmd display_power -1 2 | grep -q "1" && echo "on" || echo "off"
            vcgencmd display_power -1 7 | grep -q "1" && echo "on" || echo "off"
            Regards,
            Bert
              MiPraSo
              I had the same issue, I use MMM-PIR-Sensor-Lite to switch the monitor off and on again. On the command line “vcgencmd display_power 0” does not work, the return is always: “display_power=1”.
              I have tried a few things, they all did not work.
              Edit the “config.txt” in the “/boot” directory.
              Go to:
              “# Enable DRM VC4 V3D driver
              dtoverlay=vc4-kms-v3d
              max_framebuffers=2”
              And change “dtoverlay=vc4-kms-v3d” to “dtoverlay=vc4-fkms-v3d”.
              There is a bug in the “vc4-kms-v3d” driver.
              After changing in the “config.txt” “vcgencmd display_power 0” returns a “display_power=0”.
              MMM-PIR-Sensor-Lite now works as desired.
              S G M 3 Replies Last reply Reply Quote 1
                Stroke 0 @MiPraSo
                @MiPraSo Well done! Thank you. Your solution works perfectly. I do not understand why others are not experiencing the same issue however, they now have a solution. Thank you, again.
                  sdetweil @OberfragGER
                  @OberfragGER do you have it set for cec-client mode? it does all 4 approaches
                  • O Offline
                    @sdetweil I dont have any proble with CEC e.g…? Or do you just mistakenly quotet me…?
                      @OberfragGER no, I was just asking how you used NEW-Pir
                      • O Offline
                        @sdetweil I just use the Standard setting in my config.js.
                        Standard = use vgencmd
                        https://wiki.bugsounet.fr/en/EXT-Screen
                          @OberfragGER we have discovered that some pi firmware (updated under the covers by some kernel updates) causes the vcgencmd to not work,
                          https://forum.magicmirror.builders/topic/17185/pir-sensor-problem-after-restart-raspi/20?_=1663206370580
                          • G Offline
                            grena Module Developer @MiPraSo
                            Ongoing fix! More information in my last post ;-)
                            • O Offline
                              @sdetweil Thanks for your info.
                              I assume that i have an working firmware. I dont have any clue which version this is.
                                @OberfragGER right, the latest update broken then command
                                do this from a terminal window
                                rpi-update b976c54917e240630c05a9b383010f1492bc61b4
                                  magmar @MiPraSo
                                  @MiPraSo Thank you! Worked like a charm :)
                                  To be allowed to save the config.txt-file, I had to edit it in administrator-mode (sudo nano config.txt). I also had to reboot the Pi after saving the file.
                                  • T thobach referenced this topic on
