Unsolved MMM-RemoteControl or vcgencmd Issue
@sdetweil I just use the Standard setting in my config.js.
Standard = use vgencmd -
@OberfragGER we have discovered that some pi firmware (updated under the covers by some kernel updates) causes the vcgencmd to not work,
Ongoing fix! More information in my last post ;-)
@sdetweil Thanks for your info.
I assume that i have an working firmware. I dont have any clue which version this is.
@OberfragGER right, the latest update broken then command
do this from a terminal window
rpi-update b976c54917e240630c05a9b383010f1492bc61b4
@MiPraSo Thank you! Worked like a charm :)
To be allowed to save the
config.txt
-file, I had to edit it in administrator-mode (sudo nano config.txt
). I also had to reboot the Pi after saving the file. -
