    Struggling with Weather... module
    34 Posts 5 Posters 13.0k Views 6 Watching
      D3dl3g
      hi all
      been trying for a while to get the default “weather” app to work for me and im struggling a little bit, NPM syntax check comes back clean.
      im 95% sure i have all the relevant info in the config.js file.
      But im not seeing weather output on screen. 64f3c4ef-666f-4162-b397-2dd39792e637-image.png
      Figured i’d put it here instead of Discord.
      All suggestions warmly recieved
        D3dl3g
        This “issue” is fixed.
        Advised by Sam, I ran these 2 commands to find modified files that differ from a “clean install/default” of MM.
        git status
        git diff
        Any that varied… I ran:
        git checkout <dir-tree>/file.extension
        Rebuilt my config.js and found that apiBase HAS to be commented out.
        On reflection DO NOT CHANGE ANY FILE aside from “config.js”
        I had 3 causes for this issue.
        • (edit) i had longitude set in config.js to “long:”… it should be “lon:” and the lat/lon do not have to be surrounded by any quote marks.
        • I’d modified other *.js files, that didn’t need to be modified.
        • the “apiBase” argument listed in (MagicMirror Documentation > Modules > Weather Module > Configuration Options) was, in my case, not “REQUIRED”.
        @sdetweil … Sam, publically, I cant thank you enough for your help with this. Sorry for being a n00b, your insight and help was invaluable, and you taught me some stuff, which is great!!
          sdetweil @D3dl3g
          @D3dl3g cool… can u show the messages at runtime
          where you do npm start, or if using pm2, then the command
          pm2 logs --lines=???
          will show the output
          ??? is a number, default 15, but may need to be higher to see the output…
          you can do pm2 flush to empty the log and then start again (pm2 restart all)
          thgmirrorT D 3 Replies Last reply Reply Quote 0
          • thgmirrorT Offline
            thgmirror @sdetweil
            @D3dl3g as a first check, you can use my working config-entry and extend it one by one with your needs:
            			disabled: false,
            			module: "weather",
            			header: "Wetter aktuell",
            				type: "current",
            				locationID: "2946447",
            				apiKey: "myKey",
            				showWindDirectionAsArrow: true,
            				showHumidity: true,
            				showFeelsLike: false
            Just replace the apikey.
            S D 2 Replies Last reply Reply Quote 0
              sdetweil @thgmirror
              @thgmirror nice, but he is trying a different provider.
              thgmirrorT 1 Reply Last reply Reply Quote 0
                thgmirror @sdetweil
                @sdetweil I know, but to have a first sense of achievement he will see something different than “LOADING”
                  sdetweil @thgmirror
                  @thgmirror yes, but his API key is to a different service…
                    D3dl3g @sdetweil
                      D3dl3g @thgmirror
                      @thgmirror I’d gladly try, but I’d need an API key, my friend.
                      without an API for that particular weather service, it will just come up with “loading” as the server will not give the info to you.
                      i saw the post of yours earlier, but as it didnt match my issue with UK Met Office weather service.
                      kayakbabeK 1 Reply Last reply Reply Quote 0
                        D3dl3g @sdetweil
                        @sdetweil said in Struggling with Weather... module:
                        • kayakbabeK Offline
                          kayakbabe @D3dl3g
                          @D3dl3g if you get a free api key from openweathermap and then you can test with a known weather api that we all know works. (openweathermap works for me ). then you’ll narrow down the possibilities of why your particular setup isn’t working. 1) if it is the way you have installed the module, or 2) if the problem is with the weather endpoint you are trying to use. 3) maybe the uk weather api isn’t availble to you if you aren’t physically in the uk, 4) something else…
                          but getting the module working first in a known working configuration… will narrow down a lot of possibilities. it doesn’t mean that you can’t use the api you want later (unless that’s the issue).
                          • 1 / 4
