    Struggling with Weather... module
    34 Posts 5 Posters 17.6k Views 6 Watching
      sdetweil @thgmirror
      @thgmirror nice, but he is trying a different provider.
      thgmirrorT 1 Reply Last reply Reply Quote 0
      • thgmirrorT Offline
        thgmirror @sdetweil
        @sdetweil I know, but to have a first sense of achievement he will see something different than “LOADING”
          sdetweil @thgmirror
          @thgmirror yes, but his API key is to a different service…
            D3dl3g @sdetweil
              D3dl3g @thgmirror
              @thgmirror I’d gladly try, but I’d need an API key, my friend.
              without an API for that particular weather service, it will just come up with “loading” as the server will not give the info to you.
              i saw the post of yours earlier, but as it didnt match my issue with UK Met Office weather service.
              kayakbabeK 1 Reply Last reply Reply Quote 0
                D3dl3g @sdetweil
                @sdetweil said in Struggling with Weather... module:
                you can do pm2 flush to empty the log and then start again (pm2 restart all)
                • kayakbabeK Offline
                  kayakbabe @D3dl3g
                  @D3dl3g if you get a free api key from openweathermap and then you can test with a known weather api that we all know works. (openweathermap works for me ). then you’ll narrow down the possibilities of why your particular setup isn’t working. 1) if it is the way you have installed the module, or 2) if the problem is with the weather endpoint you are trying to use. 3) maybe the uk weather api isn’t availble to you if you aren’t physically in the uk, 4) something else…
                  but getting the module working first in a known working configuration… will narrow down a lot of possibilities. it doesn’t mean that you can’t use the api you want later (unless that’s the issue).
                    sdetweil @D3dl3g
                    @D3dl3g try lines=50
                      D3dl3g @sdetweil
                      many restarts as i was modifying and testing layouts and features
                      couple of syntax errors, when i was playing around last night.
                      (blanked out sensitve info on calendar line)
                        sdetweil @D3dl3g
                        @D3dl3g hm. should have had some info…
                          D3dl3g @sdetweil
                          :grinning_face_with_smiling_eyes: always the way.
                            D3dl3g @sdetweil
                            could it be *js file setup.
                            been poking around on the Met Office website
                            is this “request” something that could be used
                            GET https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/hourly?latitude=52.################&longitude=-1.################
                            Headers:
                            Accept: application/json
                            X-IBM-Client-Id: e52######################
                            X-IBM-Client-Secret: *********
                            a “Header”
                            cache-control: no-cache, no-store, max-age=0, must-revalidate
                            content-length: 3634
                            content-type: application/json
                            expires: 0
                            pragma: no-cache
                            x-global-transaction-id: 9####################
                            x-ratelimit-limit: name=rate-limit-1,360;
                            x-ratelimit-remaining: name=rate-limit-1,358;
                            theres also a “Body” that starts
                                "type": "FeatureCollection",
                                "features": [
                                        "type": "Feature",
                                        "geometry": {
                                            "type": "Point",
                                            "coordinates": [
                                                -1.###,
                                                52.###,
                                        "properties": {
                                            "requestPointDistance": 736.6499,
                                            "modelRunDate": "2022-06-28T13:00Z",
                                            "timeSeries": [
                                                    "time": "2022-06-28T13:00Z",
                                                    "screenTemperature": 19.6,
                                                    "maxScreenAirTemp": 19.6,
                                                    "minScreenAirTemp": 19.1,
                                                    "screenDewPointTemperature": 7.7,
                                                    "feelsLikeTemperature": 16.83,
                                                    "windSpeed10m": 5.1,
                                                    "windDirectionFrom10m": 200,
                                                    "windGustSpeed10m": 11.3,
                                                    "max10mWindGust": 13.42,
                                                    "visibility": 24714,
                                                    "screenRelativeHumidity": 46.06,
                                                    "mslp": 101420,
                                                    "uvIndex": 4,
                                                    "significantWeatherCode": 3,
                                                    "precipitationRate": 0,
                                                    "totalPrecipAmount": 0,
                                                    "totalSnowAmount": 0,
                                                    "probOfPrecipitation": 1
                            i hashed out sensitive info BTW, the Long/lat and API Keys
                              D3dl3g
                              in addition… looking at “ukmetofficedatahub.js”
                              API Base URL looks like this…
                              apiBase: “https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/<hourly/3hourly/daily>”,
                              where as the next section down API URL is stated to be
                              “https://metoffice.apiconnect.ibmcloud.com/metoffice/production/api”
                              seems to be a mismatch although im still looking at where to test that theory…
                              i would have hoped which ever way the URL is structured its the JS info thats the important bit, not the structure of the URL
                                D3dl3g
                                I’m stumped!
                                As outlined here
                                ukmetofficedatahub.js is set to
                                        // Set the default config properties that is specific to this provider
                                        defaults: {
                                                apiBase: "https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/daily/",
                                                apiKey: "<myID>",
                                                apiSecret: " <my secret>",
                                                lat: <my lat>,
                                                lon: <mylong>,
                                                windUnits: "mph"
                                (lines 50-55)
                                config.js set to
                                  		weatherProvider: "ukmetofficedatahub",
                                  		apiKey: "<myID>",
                                  		lat: <my lat>,
                                  		lon: <my long>,
                                 		windUnits: "mph",
                                 		tempUnits: "metric",
                                (lines 20-27)
                                logs are clear… many server restarts…
                                i can curl required info and get something vaguely intelligent from the Met office Servers
                                curl --request GET \
                                  --url 'https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/hourly?excludeParameterMetadata=false&includeLocationName=true&latitude=<my lat>&longitude=<my long>' \
                                  --header 'X-IBM-Client-Id:  <myID>' \
                                  --header 'X-IBM-Client-Secret: <my secret>' \
                                  --header 'accept: application/json'
                                  D3dl3g
                                  any ideas?? @sdetweil
                                  Is this portion of the module broke for me, do i need to use a different service?
                                    sdetweil @D3dl3g
                                    @D3dl3g I don’t KNOW for sure… the provider has its own apiBase set…
                                    * 		apiBase: "https://api-metoffice.apiconnect.ibmcloud.com/metoffice/production/v0/forecasts/point/",
                                    so comment that out in your config
                                    add // to the start of the line with apiBase:
                                    also, as this doesn’t have a node helper, we should be looking in the browser logs
                                    ctrl-shift-i, select the console tab and put
                                    weath
                                    in the filter field
                                      D3dl3g @kayakbabe
                                      @kayakbabe
                                      For some reason i glossed over your reply, apologies.
                                      Trying with a different provider will be my plan of attack today. After running some diag, as sam has suggested.
                                      I find the met office to be insanely accurate for my area when compared to other online weather services. Hence my desire to use it.
                                      One of the reasons my posts are peppered with pictures and code is to help ensure i am setting it up correctly. I didnt realise about the .js in the weather folder for 2 days i thought it was all set up from config.js…
                                      As it stands im convinced i have it set right, now, but its totally possible i have a comma in the wrong place. As im a total n00b with JS. i know sometimes it is difficult to see the forest through the trees and a fresh set of eyes can help.
                                      Thank-you for your reply, looks like im experiencing option 4 😄
                                        D3dl3g @sdetweil
                                        @sdetweil,
                                        apiBase commented out in config.
                                        server restart, and browser log request, showing loaded weather modules
                                        i still have “loading” in module location
                                        looking at source gives me the impression that i need to go and look at 2 more .js files. Previously i have been working with /default/weather/ukmetofficedatahub.js and /MagicMirror/config/config.js
                                        ill see if thes hold any info:
                                        /root/MagicMirror/modules/default/weather/weatherproviders.js
                                        (Edit: //weather provider properties: null, modified to:
                                        8bca5c6c-09d9-4987-8940-0233b5e827c7-image.png )
                                        /root/MagicMirror/modules/default/weather/weather.js
                                        (Edit: this file is set to “openweathermap”, changing to “ukmetofficedatahub”
                                        a2763dbe-9a57-47bc-b036-505bd38e8e4e-image.png )
                                        server restart, no effect noted :(
                                          D3dl3g
                                          @Kayababe @sdetweil
                                          openweathermap works… albiet the location its suggested is 3 miles down the road. (ukmetoffice has data for 2 streets away)
                                            sdetweil @D3dl3g
                                            @D3dl3g you ONLY setup from config.js
                                            please try with NO apibase set
