    Struggling with Weather... module
    34 Posts 5 Posters 18.1k Views 6 Watching
    • kayakbabeK
      kayakbabe @D3dl3g
      @D3dl3g if you get a free api key from openweathermap and then you can test with a known weather api that we all know works. (openweathermap works for me ). then you’ll narrow down the possibilities of why your particular setup isn’t working. 1) if it is the way you have installed the module, or 2) if the problem is with the weather endpoint you are trying to use. 3) maybe the uk weather api isn’t availble to you if you aren’t physically in the uk, 4) something else…
      but getting the module working first in a known working configuration… will narrow down a lot of possibilities. it doesn’t mean that you can’t use the api you want later (unless that’s the issue).
        sdetweil @D3dl3g
        @D3dl3g try lines=50
          D3dl3g @sdetweil
          many restarts as i was modifying and testing layouts and features
          couple of syntax errors, when i was playing around last night.
          (blanked out sensitve info on calendar line)
            sdetweil @D3dl3g
            @D3dl3g hm. should have had some info…
              D3dl3g @sdetweil
              :grinning_face_with_smiling_eyes: always the way.
                D3dl3g @sdetweil
                could it be *js file setup.
                been poking around on the Met Office website
                is this “request” something that could be used
                GET https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/hourly?latitude=52.################&longitude=-1.################
                Headers:
                Accept: application/json
                X-IBM-Client-Id: e52######################
                X-IBM-Client-Secret: *********
                a “Header”
                cache-control: no-cache, no-store, max-age=0, must-revalidate
                content-length: 3634
                content-type: application/json
                expires: 0
                pragma: no-cache
                x-global-transaction-id: 9####################
                x-ratelimit-limit: name=rate-limit-1,360;
                x-ratelimit-remaining: name=rate-limit-1,358;
                theres also a “Body” that starts
                    "type": "FeatureCollection",
                    "features": [
                            "type": "Feature",
                            "geometry": {
                                "type": "Point",
                                "coordinates": [
                                    -1.###,
                                    52.###,
                            "properties": {
                                "requestPointDistance": 736.6499,
                                "modelRunDate": "2022-06-28T13:00Z",
                                "timeSeries": [
                                        "time": "2022-06-28T13:00Z",
                                        "screenTemperature": 19.6,
                                        "maxScreenAirTemp": 19.6,
                                        "minScreenAirTemp": 19.1,
                                        "screenDewPointTemperature": 7.7,
                                        "feelsLikeTemperature": 16.83,
                                        "windSpeed10m": 5.1,
                                        "windDirectionFrom10m": 200,
                                        "windGustSpeed10m": 11.3,
                                        "max10mWindGust": 13.42,
                                        "visibility": 24714,
                                        "screenRelativeHumidity": 46.06,
                                        "mslp": 101420,
                                        "uvIndex": 4,
                                        "significantWeatherCode": 3,
                                        "precipitationRate": 0,
                                        "totalPrecipAmount": 0,
                                        "totalSnowAmount": 0,
                                        "probOfPrecipitation": 1
                i hashed out sensitive info BTW, the Long/lat and API Keys
                  D3dl3g
                  in addition… looking at “ukmetofficedatahub.js”
                  API Base URL looks like this…
                  apiBase: “https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/<hourly/3hourly/daily>”,
                  where as the next section down API URL is stated to be
                  “https://metoffice.apiconnect.ibmcloud.com/metoffice/production/api”
                  seems to be a mismatch although im still looking at where to test that theory…
                  i would have hoped which ever way the URL is structured its the JS info thats the important bit, not the structure of the URL
                    D3dl3g
                    I’m stumped!
                    As outlined here
                    ukmetofficedatahub.js is set to
                            // Set the default config properties that is specific to this provider
                            defaults: {
                                    apiBase: "https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/daily/",
                                    apiKey: "<myID>",
                                    apiSecret: " <my secret>",
                                    lat: <my lat>,
                                    lon: <mylong>,
                                    windUnits: "mph"
                    (lines 50-55)
                    config.js set to
                      		weatherProvider: "ukmetofficedatahub",
                      		apiKey: "<myID>",
                      		lat: <my lat>,
                      		lon: <my long>,
                     		windUnits: "mph",
                     		tempUnits: "metric",
                    (lines 20-27)
                    logs are clear… many server restarts…
                    i can curl required info and get something vaguely intelligent from the Met office Servers
                    curl --request GET \
                      --url 'https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/hourly?excludeParameterMetadata=false&includeLocationName=true&latitude=<my lat>&longitude=<my long>' \
                      --header 'X-IBM-Client-Id:  <myID>' \
                      --header 'X-IBM-Client-Secret: <my secret>' \
                      --header 'accept: application/json'
                      D3dl3g
                      any ideas?? @sdetweil
                      Is this portion of the module broke for me, do i need to use a different service?
                        sdetweil @D3dl3g
                        @D3dl3g I don’t KNOW for sure… the provider has its own apiBase set…
                        * 		apiBase: "https://api-metoffice.apiconnect.ibmcloud.com/metoffice/production/v0/forecasts/point/",
                        so comment that out in your config
                        add // to the start of the line with apiBase:
                        also, as this doesn’t have a node helper, we should be looking in the browser logs
                        ctrl-shift-i, select the console tab and put
                        weath
                        in the filter field
                          D3dl3g @kayakbabe
                          @kayakbabe
                          For some reason i glossed over your reply, apologies.
                          Trying with a different provider will be my plan of attack today. After running some diag, as sam has suggested.
                          I find the met office to be insanely accurate for my area when compared to other online weather services. Hence my desire to use it.
                          One of the reasons my posts are peppered with pictures and code is to help ensure i am setting it up correctly. I didnt realise about the .js in the weather folder for 2 days i thought it was all set up from config.js…
                          As it stands im convinced i have it set right, now, but its totally possible i have a comma in the wrong place. As im a total n00b with JS. i know sometimes it is difficult to see the forest through the trees and a fresh set of eyes can help.
                          Thank-you for your reply, looks like im experiencing option 4 😄
                            D3dl3g @sdetweil
                            @sdetweil,
                            apiBase commented out in config.
                            server restart, and browser log request, showing loaded weather modules
                            i still have “loading” in module location
                            looking at source gives me the impression that i need to go and look at 2 more .js files. Previously i have been working with /default/weather/ukmetofficedatahub.js and /MagicMirror/config/config.js
                            ill see if thes hold any info:
                            /root/MagicMirror/modules/default/weather/weatherproviders.js
                            (Edit: //weather provider properties: null, modified to:
                            8bca5c6c-09d9-4987-8940-0233b5e827c7-image.png )
                            /root/MagicMirror/modules/default/weather/weather.js
                            (Edit: this file is set to “openweathermap”, changing to “ukmetofficedatahub”
                            a2763dbe-9a57-47bc-b036-505bd38e8e4e-image.png )
                            server restart, no effect noted :(
                              D3dl3g
                              @Kayababe @sdetweil
                              openweathermap works… albiet the location its suggested is 3 miles down the road. (ukmetoffice has data for 2 streets away)
                                sdetweil @D3dl3g
                                @D3dl3g you ONLY setup from config.js
                                please try with NO apibase set
                                  D3dl3g @sdetweil
                                  weather.js and weatherprovider.js i have set back to defaults.
                                  i have set config.js as requested
                                    weatherProvider: 'ukmetofficedatahub',
                                    lat: "52.###############",
                                    long: "-1.###############",
                                  //apiBase: 'https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/daily/',
                                    apiKey: 'e52#############################',
                                    apiSecret: 'd3a#############################',
                                  the result:-
                                    sdetweil @D3dl3g
                                    @D3dl3g send me your API key… config from config.js via email or direct message so I can debug
                                    did u look in the browser messages?
                                    my email is my same userid at gmail
                                      D3dl3g
                                      Just to update the forum, as to what happened behind closed doors
                                      Sam kindly tested my code, and it worked for him.
                                      I am recieving browser errors (previously requested but i wasnt looking in the right bit of the browser window)… he is not
                                      Issues Tab
                                      Console Tab
                                      the last 5 entries here will reoccur, im guessing at every “retry” for weather info
                                      attempted to use useCorsProxy: true to no avail
                                      Sam kindly posted into git hub issues.
                                      https://github.com/MichMich/MagicMirror/issues/271
                                      • karsten13K
                                        karsten13 @D3dl3g
                                        tested ukmetofficehub and it works out of the box (without setting the useCorsProxy flag).
                                        Looking into the provided config
                                        which is messed up. It has to be:
                                          lat: 52.###############,
                                          lon: -1.###############,
                                          sdetweil @karsten13
                                          @karsten13 I tested w those in quotes, and it worked ok
                                          • karsten13K
                                            karsten13 @sdetweil
                                            did only test without, but there is another error lon vs. long …
                                            S D 3 Replies Last reply Reply Quote 0
