    Struggling with Weather... module
    34 Posts 5 Posters 17.6k Views 6 Watching
      sdetweil @D3dl3g
      @D3dl3g hm. should have had some info…
        D3dl3g @sdetweil
        :grinning_face_with_smiling_eyes: always the way.
          D3dl3g @sdetweil
          could it be *js file setup.
          been poking around on the Met Office website
          is this “request” something that could be used
          GET https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/hourly?latitude=52.################&longitude=-1.################
          Headers:
          Accept: application/json
          X-IBM-Client-Id: e52######################
          X-IBM-Client-Secret: *********
          a “Header”
          cache-control: no-cache, no-store, max-age=0, must-revalidate
          content-length: 3634
          content-type: application/json
          expires: 0
          pragma: no-cache
          x-global-transaction-id: 9####################
          x-ratelimit-limit: name=rate-limit-1,360;
          x-ratelimit-remaining: name=rate-limit-1,358;
          theres also a “Body” that starts
              "type": "FeatureCollection",
              "features": [
                      "type": "Feature",
                      "geometry": {
                          "type": "Point",
                          "coordinates": [
                              -1.###,
                              52.###,
                      "properties": {
                          "requestPointDistance": 736.6499,
                          "modelRunDate": "2022-06-28T13:00Z",
                          "timeSeries": [
                                  "time": "2022-06-28T13:00Z",
                                  "screenTemperature": 19.6,
                                  "maxScreenAirTemp": 19.6,
                                  "minScreenAirTemp": 19.1,
                                  "screenDewPointTemperature": 7.7,
                                  "feelsLikeTemperature": 16.83,
                                  "windSpeed10m": 5.1,
                                  "windDirectionFrom10m": 200,
                                  "windGustSpeed10m": 11.3,
                                  "max10mWindGust": 13.42,
                                  "visibility": 24714,
                                  "screenRelativeHumidity": 46.06,
                                  "mslp": 101420,
                                  "uvIndex": 4,
                                  "significantWeatherCode": 3,
                                  "precipitationRate": 0,
                                  "totalPrecipAmount": 0,
                                  "totalSnowAmount": 0,
                                  "probOfPrecipitation": 1
          i hashed out sensitive info BTW, the Long/lat and API Keys
            D3dl3g
            in addition… looking at “ukmetofficedatahub.js”
            API Base URL looks like this…
            apiBase: “https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/<hourly/3hourly/daily>”,
            where as the next section down API URL is stated to be
            “https://metoffice.apiconnect.ibmcloud.com/metoffice/production/api”
            seems to be a mismatch although im still looking at where to test that theory…
            i would have hoped which ever way the URL is structured its the JS info thats the important bit, not the structure of the URL
              D3dl3g
              I’m stumped!
              As outlined here
              ukmetofficedatahub.js is set to
                      // Set the default config properties that is specific to this provider
                      defaults: {
                              apiBase: "https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/daily/",
                              apiKey: "<myID>",
                              apiSecret: " <my secret>",
                              lat: <my lat>,
                              lon: <mylong>,
                              windUnits: "mph"
              (lines 50-55)
              config.js set to
                		weatherProvider: "ukmetofficedatahub",
                		apiKey: "<myID>",
                		lat: <my lat>,
                		lon: <my long>,
               		windUnits: "mph",
               		tempUnits: "metric",
              (lines 20-27)
              logs are clear… many server restarts…
              i can curl required info and get something vaguely intelligent from the Met office Servers
              curl --request GET \
                --url 'https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/hourly?excludeParameterMetadata=false&includeLocationName=true&latitude=<my lat>&longitude=<my long>' \
                --header 'X-IBM-Client-Id:  <myID>' \
                --header 'X-IBM-Client-Secret: <my secret>' \
                --header 'accept: application/json'
                D3dl3g
                any ideas?? @sdetweil
                Is this portion of the module broke for me, do i need to use a different service?
                  sdetweil @D3dl3g
                  @D3dl3g I don’t KNOW for sure… the provider has its own apiBase set…
                  * 		apiBase: "https://api-metoffice.apiconnect.ibmcloud.com/metoffice/production/v0/forecasts/point/",
                  so comment that out in your config
                  add // to the start of the line with apiBase:
                  also, as this doesn’t have a node helper, we should be looking in the browser logs
                  ctrl-shift-i, select the console tab and put
                  weath
                  in the filter field
                    D3dl3g @kayakbabe
                    @kayakbabe
                    For some reason i glossed over your reply, apologies.
                    Trying with a different provider will be my plan of attack today. After running some diag, as sam has suggested.
                    I find the met office to be insanely accurate for my area when compared to other online weather services. Hence my desire to use it.
                    One of the reasons my posts are peppered with pictures and code is to help ensure i am setting it up correctly. I didnt realise about the .js in the weather folder for 2 days i thought it was all set up from config.js…
                    As it stands im convinced i have it set right, now, but its totally possible i have a comma in the wrong place. As im a total n00b with JS. i know sometimes it is difficult to see the forest through the trees and a fresh set of eyes can help.
                    Thank-you for your reply, looks like im experiencing option 4 😄
                      D3dl3g @sdetweil
                      @sdetweil,
                      apiBase commented out in config.
                      server restart, and browser log request, showing loaded weather modules
                      i still have “loading” in module location
                      looking at source gives me the impression that i need to go and look at 2 more .js files. Previously i have been working with /default/weather/ukmetofficedatahub.js and /MagicMirror/config/config.js
                      ill see if thes hold any info:
                      /root/MagicMirror/modules/default/weather/weatherproviders.js
                      (Edit: //weather provider properties: null, modified to:
                      8bca5c6c-09d9-4987-8940-0233b5e827c7-image.png )
                      /root/MagicMirror/modules/default/weather/weather.js
                      (Edit: this file is set to “openweathermap”, changing to “ukmetofficedatahub”
                      a2763dbe-9a57-47bc-b036-505bd38e8e4e-image.png )
                      server restart, no effect noted :(
                        D3dl3g
                        @Kayababe @sdetweil
                        openweathermap works… albiet the location its suggested is 3 miles down the road. (ukmetoffice has data for 2 streets away)
                          sdetweil @D3dl3g
                          @D3dl3g you ONLY setup from config.js
                          please try with NO apibase set
                            D3dl3g @sdetweil
                            weather.js and weatherprovider.js i have set back to defaults.
                            i have set config.js as requested
                              weatherProvider: 'ukmetofficedatahub',
                              lat: "52.###############",
                              long: "-1.###############",
                            //apiBase: 'https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/daily/',
                              apiKey: 'e52#############################',
                              apiSecret: 'd3a#############################',
                            the result:-
                              sdetweil @D3dl3g
                              @D3dl3g send me your API key… config from config.js via email or direct message so I can debug
                              did u look in the browser messages?
                              my email is my same userid at gmail
                                D3dl3g
                                Just to update the forum, as to what happened behind closed doors
                                Sam kindly tested my code, and it worked for him.
                                I am recieving browser errors (previously requested but i wasnt looking in the right bit of the browser window)… he is not
                                Issues Tab
                                Console Tab
                                the last 5 entries here will reoccur, im guessing at every “retry” for weather info
                                attempted to use useCorsProxy: true to no avail
                                Sam kindly posted into git hub issues.
                                https://github.com/MichMich/MagicMirror/issues/271
                                • karsten13K Offline
                                  karsten13 @D3dl3g
                                  tested ukmetofficehub and it works out of the box (without setting the useCorsProxy flag).
                                  Looking into the provided config
                                  which is messed up. It has to be:
                                    lat: 52.###############,
                                    lon: -1.###############,
                                    sdetweil @karsten13
                                    @karsten13 I tested w those in quotes, and it worked ok
                                      karsten13 @sdetweil
                                      did only test without, but there is another error lon vs. long …
                                      S D 3 Replies Last reply Reply Quote 0
                                        sdetweil @karsten13
                                        @karsten13 I just copy pasted and it worked.
                                        weird
                                          D3dl3g @karsten13
                                          @karsten13
                                          i too am getting this… showing me some 80+miles SEE of my actual location
                                            D3dl3g @karsten13
                                            @karsten13
                                            also… replace the hash symbols with various numbers… im not posting my exact Lat/Long for obvious reasons…
                                            make sure ur doing
                                            lat:
                                            and
                                            lon:
                                            i had it set to lat & lon(G) which is incorrect. hence why it was 80+miles, way tf over there!
                                            quote marks or none surronding the numbers doesnt appear to matter, for me at least
