MMM-TrainConnections
9 Posts 5 Posters 5.1k Views 3 Watching
    clebo99
    So if I wanted to try this with say trains here in the US, where would I even start looking to obtain that information? I still such a noob but like how would I even Google what to look for?
    C 1 Reply Last reply May 25, 2016, 4:08 PM Reply Quote 0
      CommanderB @clebo99
      I think this one is Europe only - taker a look at localtransport module. This uses the Google APIs and works with many global transit systems.
        clebo99
        So I cloned the GoogleMaps one. Two questions.
        The directory is off the root of the Module Directory, not in the default directory. Is that correct?
        I’m about to run the NPM Install command. That’s not going to write over anything I have right? That just “adds” to what I already have, correct?
        C 1 Reply Last reply May 27, 2016, 2:31 AM Reply Quote 0
          CommanderB @clebo99
          @clebo99 correct
            shgmongohh
            Have I to clone TrainConnections in MagicMirror/Modules or only in MagicMirror?
            I only get a black screen on my MagicMirror Version2.
              Bangee Module Developer
              You will need to clon it in to ~/MagicMirror/modules
              and add the config to your config/config.js file
              Bangee
                shgmongohh
                The Problem was Thatcher the Module folder had a wrong Name, MMM-trainconnetions.
                I renamed it to trainconnections and it works.
                • G Offline
                  geeflaxx
                  i can’t use the command ‘sudo command install’ cause it isn’t a right command
                  (i install it in the modules order)
                  but then i can change the api.php (have to add 2 api’s right)
                  then i have to change my config (add the modul)
                  but how i can get german api’s ?
                  i wrote a email on DBOpenData@deutschebahn.com to give me the api’s
                  but where should i add then the api’s in api.php ?
                  • G Offline
                    geeflaxx
                    okay i can’t edit my post…
                    how can i change the connection.php script so that i see when my train come to late ?
                    i only wanna see my train from my city (for example berlin) to frankfurt
                    with the lateness time
                    but only the way to the city (like that https://forum.magicmirror.builders/uploads/files/1462363258197-mm_st.jpg)
                    not the way back
                    from the “Deutsche Bahn” i only got that (with apikey)
                    http://download-data.deutschebahn.com/static/apis/fahrplan/Fpl-API-Doku-Open-Data-BETA-0_81_2.pdf
