    Display the specified picture in the specified location
    21 Posts 2 Posters 11.2k Views 2 Watching
      sdetweil @史新瑞
      @史新瑞 use middle_center position?
      史 1 Reply Last reply
      • 史
        史新瑞 @sdetweil
        @sdetweil Do you have a specific routine? I am a novice, not familiar with it, thank you
          sdetweil @史新瑞
          @史新瑞 what do you mean routine?
          mm is a web page, using normal css and styles
          there are some predefined positions. see css/main.css
          史 2 Replies Last reply
          • 史
            史新瑞 @sdetweil
            @sdetweil example:beaming_face_with_smiling_eyes: :beaming_face_with_smiling_eyes:
            • 史
              史新瑞 @sdetweil
              @sdetweil Have you ever done a similar project? Can I refer to it:folded_hands:
                sdetweil @史新瑞
                @史新瑞 you can look at my version of MMM-ImagesPhotos
                https://github.com/sdetweil/MMM-ImagesPhotos
                I center the image in the background(fullscreen_below), retaining the image dimension ratio, which css cover and contain do not.
                to help with smoothing the transitions and not having blank screen, I use an onLoad() handler to hide the prior and visualize the just loaded image.
                I have not tried these modifications in the middle_center mm position
                • 史
                  史新瑞 @sdetweil
                  @sdetweil thank you
                  • 史
                    史新瑞 @sdetweil
                    @sdetweil I was wondering how do you set the image position in your CSS program?or automatically read fixed folder pictures and thanks for the instructions
                      sdetweil @史新瑞
                      @史新瑞
                      see the on-load handler , line 247 of the MMM-ImagesPhotos.js
                      			img.onload=  (evt) => {
                      • 史
                        史新瑞 @sdetweil
                          sdetweil @史新瑞
                          @史新瑞 my version
                          • 史
                            史新瑞 @sdetweil
                            @sdetweil Thank you. I have downloaded your module, but there is an error when I use it. Could you please help me check it? I’m very sorrybc.png
                            史 S 2 Replies Last reply
                            • 史
                              史新瑞 @史新瑞
                              This is the config.js file
                                sdetweil @史新瑞
                                @史新瑞 error… you have to do
                                npm install
                                in the module folder
                                • 史
                                  史新瑞 @sdetweil
                                  @sdetweil Sorry, I forgot. I’ll try again
                                    sdetweil @史新瑞
                                    @史新瑞 my code always uses the full screen
                                    m is the margin size
                                    var tw = document.body.clientWidth+(parseInt(m)*2);
                                    var th = document.body.clientHeight+(parseInt(m)*2)
                                    but one could get the module position( part of the config Info passed to module) and then get ITS size.
                                    see the window.getComputedStyle(), used on line 221.
                                    • 史
                                      史新瑞 @sdetweil
                                      @sdetweil I did the installation and configuration several times. But yesterday’s mistake has not been resolved
                                      • 史
                                        史新瑞 @sdetweil
                                        @sdetweil Thank you very much. I’ve got the problem
                                        Thank you again
                                          sdetweil @史新瑞
                                          @史新瑞 I do not understand
                                          if you did the npm install in the newly cloned module folder then the request library would be added to the modules library list
                                          • 史
                                            史新瑞 @sdetweil
                                            @sdetweil Sorry, there was a mistake in translation. I mean no more questions, thanks again
