    Display the specified picture in the specified location
    21 Posts 2 Posters 11.2k Views 2 Watching
    • 史
      史新瑞 @sdetweil
      @sdetweil Have you ever done a similar project? Can I refer to it:folded_hands:
        sdetweil @史新瑞
        @史新瑞 you can look at my version of MMM-ImagesPhotos
        https://github.com/sdetweil/MMM-ImagesPhotos
        I center the image in the background(fullscreen_below), retaining the image dimension ratio, which css cover and contain do not.
        to help with smoothing the transitions and not having blank screen, I use an onLoad() handler to hide the prior and visualize the just loaded image.
        I have not tried these modifications in the middle_center mm position
        史 2 Replies Last reply
        • 史
          史新瑞 @sdetweil
          @sdetweil thank you
          • 史
            史新瑞 @sdetweil
            @sdetweil I was wondering how do you set the image position in your CSS program?or automatically read fixed folder pictures and thanks for the instructions
              sdetweil @史新瑞
              @史新瑞
              see the on-load handler , line 247 of the MMM-ImagesPhotos.js
              			img.onload=  (evt) => {
              史 1 Reply Last reply
              • 史
                史新瑞 @sdetweil
                  sdetweil @史新瑞
                  @史新瑞 my version
                  • 史
                    史新瑞 @sdetweil
                    @sdetweil Thank you. I have downloaded your module, but there is an error when I use it. Could you please help me check it? I’m very sorrybc.png
                    史 S 2 Replies Last reply
                    • 史
                      史新瑞 @史新瑞
                      This is the config.js file
                        sdetweil @史新瑞
                        @史新瑞 error… you have to do
                        npm install
                        in the module folder
                        • 史
                          史新瑞 @sdetweil
                          @sdetweil Sorry, I forgot. I’ll try again
                            sdetweil @史新瑞
                            @史新瑞 my code always uses the full screen
                            m is the margin size
                            var tw = document.body.clientWidth+(parseInt(m)*2);
                            var th = document.body.clientHeight+(parseInt(m)*2)
                            but one could get the module position( part of the config Info passed to module) and then get ITS size.
                            see the window.getComputedStyle(), used on line 221.
                            • 史
                              史新瑞 @sdetweil
                              @sdetweil I did the installation and configuration several times. But yesterday’s mistake has not been resolved
                              • 史
                                史新瑞 @sdetweil
                                @sdetweil Thank you very much. I’ve got the problem
                                Thank you again
                                  sdetweil @史新瑞
                                  @史新瑞 I do not understand
                                  if you did the npm install in the newly cloned module folder then the request library would be added to the modules library list
                                  • 史
                                    史新瑞 @sdetweil
                                    @sdetweil Sorry, there was a mistake in translation. I mean no more questions, thanks again
