    Display the specified picture in the specified location
    21 Posts 2 Posters 10.9k Views 2 Watching
    • 史
      史新瑞 @sdetweil
        sdetweil @史新瑞
        @史新瑞 my version
        https://github.com/sdetweil/MMM-ImagesPhotos
        史 1 Reply Last reply Reply Quote 0
        • 史
          史新瑞 @sdetweil
          @sdetweil Thank you. I have downloaded your module, but there is an error when I use it. Could you please help me check it? I’m very sorrybc.png
          史 S 2 Replies Last reply Reply Quote 0
          • 史
            史新瑞 @史新瑞
            This is the config.js file
              sdetweil @史新瑞
              @史新瑞 error… you have to do
              npm install
              in the module folder
              • 史
                史新瑞 @sdetweil
                @sdetweil Sorry, I forgot. I’ll try again
                  sdetweil @史新瑞
                  @史新瑞 my code always uses the full screen
                  m is the margin size
                  var tw = document.body.clientWidth+(parseInt(m)*2);
                  var th = document.body.clientHeight+(parseInt(m)*2)
                  but one could get the module position( part of the config Info passed to module) and then get ITS size.
                  see the window.getComputedStyle(), used on line 221.
                  史 2 Replies Last reply Reply Quote 0
                  • 史
                    史新瑞 @sdetweil
                    @sdetweil I did the installation and configuration several times. But yesterday’s mistake has not been resolved
                    • 史
                      史新瑞 @sdetweil
                      @sdetweil Thank you very much. I’ve got the problem
                      Thank you again
                        sdetweil @史新瑞
                        @史新瑞 I do not understand
                        if you did the npm install in the newly cloned module folder then the request library would be added to the modules library list
                        • 史
                          史新瑞 @sdetweil
                          @sdetweil Sorry, there was a mistake in translation. I mean no more questions, thanks again
