    Display the specified picture in the specified location
    21 Posts 2 Posters 11.2k Views 2 Watching
      sdetweil @史新瑞
      @史新瑞
      see the on-load handler , line 247 of the MMM-ImagesPhotos.js
      			img.onload=  (evt) => {
      史 1 Reply Last reply
      • 史
        史新瑞 @sdetweil
          sdetweil @史新瑞
          @史新瑞 my version
          https://github.com/sdetweil/MMM-ImagesPhotos
          • 史
            史新瑞 @sdetweil
            @sdetweil Thank you. I have downloaded your module, but there is an error when I use it. Could you please help me check it? I’m very sorrybc.png
            史 S 2 Replies Last reply
            • 史
              史新瑞 @史新瑞
              This is the config.js file
                sdetweil @史新瑞
                @史新瑞 error… you have to do
                npm install
                in the module folder
                • 史
                  史新瑞 @sdetweil
                  @sdetweil Sorry, I forgot. I’ll try again
                    sdetweil @史新瑞
                    @史新瑞 my code always uses the full screen
                    m is the margin size
                    var tw = document.body.clientWidth+(parseInt(m)*2);
                    var th = document.body.clientHeight+(parseInt(m)*2)
                    but one could get the module position( part of the config Info passed to module) and then get ITS size.
                    see the window.getComputedStyle(), used on line 221.
                    史 2 Replies Last reply
                    • 史
                      史新瑞 @sdetweil
                      @sdetweil I did the installation and configuration several times. But yesterday’s mistake has not been resolved
                      • 史
                        史新瑞 @sdetweil
                        @sdetweil Thank you very much. I’ve got the problem
                        Thank you again
                          sdetweil @史新瑞
                          @史新瑞 I do not understand
                          if you did the npm install in the newly cloned module folder then the request library would be added to the modules library list
                          • 史
                            史新瑞 @sdetweil
                            @sdetweil Sorry, there was a mistake in translation. I mean no more questions, thanks again
