    Display the specified picture in the specified location
    21 Posts 2 Posters 9.7k Views 2 Watching
    • 史 Offline
      史新瑞 @sdetweil
      @sdetweil Have you ever done a similar project? Can I refer to it:folded_hands:
        sdetweil @史新瑞
        @史新瑞 you can look at my version of MMM-ImagesPhotos
        https://github.com/sdetweil/MMM-ImagesPhotos
        I center the image in the background(fullscreen_below), retaining the image dimension ratio, which css cover and contain do not.
        to help with smoothing the transitions and not having blank screen, I use an onLoad() handler to hide the prior and visualize the just loaded image.
        I have not tried these modifications in the middle_center mm position
        史 2 Replies Last reply Reply Quote 0
        • 史 Offline
          史新瑞 @sdetweil
          @sdetweil thank you
          • 史 Offline
            史新瑞 @sdetweil
            @sdetweil I was wondering how do you set the image position in your CSS program?or automatically read fixed folder pictures and thanks for the instructions
              sdetweil @史新瑞
              @史新瑞
              see the on-load handler , line 247 of the MMM-ImagesPhotos.js
              			img.onload=  (evt) => {
              史 1 Reply Last reply Reply Quote 0
              • 史 Offline
                史新瑞 @sdetweil
                  sdetweil @史新瑞
                  @史新瑞 my version
                  • 史 Offline
                    史新瑞 @sdetweil
                    @sdetweil Thank you. I have downloaded your module, but there is an error when I use it. Could you please help me check it? I’m very sorrybc.png
                    史 S 2 Replies Last reply Reply Quote 0
                    • 史 Offline
                      史新瑞 @史新瑞
                      This is the config.js file
                        sdetweil @史新瑞
                        @史新瑞 error… you have to do
                        npm install
                        in the module folder
