    Display the specified picture in the specified location
    21 Posts 2 Posters 10.7k Views 2 Watching
    • 史 Offline
      史新瑞 @sdetweil
      @sdetweil thank you
      • 史 Offline
        史新瑞 @sdetweil
        @sdetweil I was wondering how do you set the image position in your CSS program?or automatically read fixed folder pictures and thanks for the instructions
          sdetweil @史新瑞
          @史新瑞
          see the on-load handler , line 247 of the MMM-ImagesPhotos.js
          			img.onload=  (evt) => {
          史 1 Reply Last reply Reply Quote 0
          • 史 Offline
            史新瑞 @sdetweil
              sdetweil @史新瑞
              @史新瑞 my version
              https://github.com/sdetweil/MMM-ImagesPhotos
              • 史 Offline
                史新瑞 @sdetweil
                @sdetweil Thank you. I have downloaded your module, but there is an error when I use it. Could you please help me check it? I’m very sorrybc.png
                史 S 2 Replies Last reply Reply Quote 0
                • 史 Offline
                  史新瑞 @史新瑞
                  This is the config.js file
                    sdetweil @史新瑞
                    @史新瑞 error… you have to do
                    npm install
                    in the module folder
                    • 史 Offline
                      史新瑞 @sdetweil
                      @sdetweil Sorry, I forgot. I’ll try again
                        sdetweil @史新瑞
                        @史新瑞 my code always uses the full screen
                        m is the margin size
                        var tw = document.body.clientWidth+(parseInt(m)*2);
                        var th = document.body.clientHeight+(parseInt(m)*2)
                        but one could get the module position( part of the config Info passed to module) and then get ITS size.
                        see the window.getComputedStyle(), used on line 221.
                        史 2 Replies Last reply Reply Quote 0
                        • 史 Offline
                          史新瑞 @sdetweil
                          @sdetweil I did the installation and configuration several times. But yesterday’s mistake has not been resolved
                          • 史 Offline
                            史新瑞 @sdetweil
                            @sdetweil Thank you very much. I’ve got the problem
                            Thank you again
                              sdetweil @史新瑞
                              @史新瑞 I do not understand
                              if you did the npm install in the newly cloned module folder then the request library would be added to the modules library list
                              • 史 Offline
                                史新瑞 @sdetweil
                                @sdetweil Sorry, there was a mistake in translation. I mean no more questions, thanks again
